Question about Frigidaire GLEH1642DS Front Load Stacked Washer/Dryer
Frigidaire GLEH1642D When final spin it does not spin in a fast mode.The door lock switch has been replaced.Is the problem possible w/ the spin control board assembly? Thanks
Posted by sgofc on
Anonymous
  • 100 Answers
Sure if one of the windings in the motor is bad or on the board.  There should be a tech sheet behind the washers bottom access panel that tells you how to test the motor and board.
Posted on Oct 30, 2007
Lid closes to push down lever to let machine spin how do i fix that mechanisum ?
Door or Lid Latch Assembly If the washer won't spin or agitate the lid switch assembly might be defective. This is a very common problem. The lid switch assembly can fail either mechanically or electrically. Test any electrical switches with an Ohm meter for continuity. The switches should have continuity according to their design.
Door Lock Motor and Switch Assembly If the washer won't spin or agitate the door lock assembly should be checked. The door lock can fail either mechanically or electrically. Test any switches on the door lock with an Ohm meter. The switches should have continuity according to their design.
Motor Control Board If the washer won't spin or agitate the motor control board might be defective. The motor control board provides power to the motor as well as direction and force. If the motor control board is defective the washer may not work at all or function properly.
May 07, 2015 | Washing Machines
Our whirlpool wtw5100vqo agitator doesn't work I already replaced the agitator dogs
No agitation or spin? try these:
Motor Coupling If the washer won't spin or agitate the motor coupling might have failed. The motor coupling connects the motor to the washer transmission. It is designed to fail if the washer is overloaded in order to protect both the motor and
Drive Belt If the washer won't spin or agitate, check the drive belt. If the belt is broken or if it isn't tight on the pulleys the washer won't spin or agitate properly.
Drive Motor If the washer won't spin or agitate the drive motor might be defective. This is not common. Check all of the other related parts to this symptom before replacing the motor. If the motor is visibly burned out or physically damaged, replace it.
Stator Assembly If the washer won't spin or agitate the stator assembly might be burned out. The stator is essentially one half of a motor, it interacts with the tub by creating a strong electro-magnet. If the stator burns out the washer won't spin or agitate. Check the stator for continuity. This part is often misdiagnosed.
Transmission or clutch assembly not engaging due to going out or slipping.
Apr 03, 2015 | Whirlpool Washing Machines
Replaced lid switch, water level sensor and timer. Machine fills and does nothing - no agitate / spin
Apr 03, 2015 | Washing Machines
How to replace a bad lid switch to a washermachine
Aug 31, 2014 | Whirlpool Washing Machines
Washer does not spin
Mar 23, 2014 | Amana NFW7200TW 3.5 Cu. Ft. Front Load...
Machine not spinning
Dec 26, 2013 | Asko Washing Machines
Model fwt645rhso will agitate but won't drain out, on spin cycle washer spins one way, stops goes back the other way, but water will not drain out. Does not rapidly spin on final cycle. Any...
There's an auxiliary switch in the door lock.switch assembly that is activated at the end of the wash cycle for the machine to advance to the spin cycle. The machine will NEVER advance to the spin cycle unless the auxiliary switch is activated as a safety feature to prevent the door from opening during a high-speed spin cycle that may result in physical injury. The drum tumbles back and forth while the machine control checks the auxiliary if activated but since it's not, the control will not command the motor speed control to spin the drum at high speed. These symptoms may indicate a faulty door lock/switch assembly and may need replacement. Click on the links below for the detailed troubleshooting instructions and replacement of the door lock/switch assembly.
Electrolux and Frigidaire Washers Door Lock/Switch Assembly Troubleshooting
Replacing the Door Lock/Switch Assembly on Electrolux and Frigidaire Washers
Jun 18, 2011 | Frigidaire GSTF1670A Front Load Washer
Washer is acting erratic. spin cycle works sometimes. stops half way through cycle sometimes. got a new belt. what's next? pump or timer. both are spendy $ thanks. frigidaire FTR630ASO
The control monitors the door lock prior to and during the spin cycle as a safety feature. The washer will not advance to the spin cycle when the door lock is not activated and stops when the lock is deactivated during the spin cycle.
In your case, the door lock is working intermittently causing the washer to spin intermittently. This is probably due to a faulty door lock and switch assembly or poor connection at the control board or at the assembly itself. Replace the door lock and switch assembly if necessary.
Apr 06, 2010 | Washing Machines
My front loader isn't completing the final spin-it drains, but can't seem to get into the fast final spin...help!
It sounds like you may have one or more problems. One of which could be your door lock switch, quite often this part will simply fail over time. If it is faulty it will not lock the door, and for safety reasons will not go into a spin cycle. door switch assembly part number is 131763245. Also the door strike located on the doors edge will sometime break or chip in side the latch and you will have replace both. part number for the strike is 134456600. the other possible problem could be that your motor control board or speed board is faulty and is not sending the proper amperage to your motor telling it to spin. motor control board part number is 134591200. the strike is easy to replace but the others may require a technician.hope this helps
Thanks
Oct 14, 2009 | Frigidaire ATF6000ES Front Load Washer
WHIRPOOL FRONT LOADER WASHER NOT SPINNING
Not pumping out the water - if the washer cannot pump out the water, the washer will not be able to spin...check the pump for not pumping.
Door not locking - if the door will not lock, the washer will not enter a spin mode. See if the lock light is lite on the consol.
Broken wires at one of the out off balance switches or a bad switch itself.
A fairly common trouble maker has been a burnt diode on the main control board. See diode R11.
f this has happened to your main control board ( in the consol ) , the wax motor in the door lock assembly is drawing too much hydro and must be replacing at the same time as the control board. The wax motor can check, appear and test ok but will fail when working throughout the cycle.
Feb 20, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Frigidaire GLEH1642DS Front Load Stacked Washer/Dryer Logo
130 people viewed this question
Top Frigidaire Washing Machines Experts
Gerry Harvey
Gerry Harvey
Jason Harris
Jason Harris
Marvin
Marvin
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
