Rca 52 " projection tv
Either with remote control or with button on tv set will not turn on
Posted by nahual on
Anonymous
    Scholar:
  • 148 Answers
The problem is in the powersupply of your projection tv. u can simply change the fuse of your tv or by changing capacitor depends on vary
Posted on Feb 24, 2008
My RCA 52" HDTV Rear Projection TV Model #MM52110JX1 will not turn on. Neither the remote, nor the front panel switch will turn on the TV. When you press the power button on the remote, the red indicator...
you must check the light indicator if how many times does it blink which tell the main problem or the error code of the tv. either the power supply doesn't work normally or the lamp need replacement.
Sep 23, 2013 | RCA D52W19 52" Rear Projection Television
The only control on the front of the tv that works is the on-off button. When the tv is turned on it continuously changes channels as if someone is holding down the up channel button on the remote.
I know the set well and would like to help---FIRST THING IS DISCONNECT THE POWER TO THE SET---a few minutes will be enough.
Plug set back and a good chance it will have returned to normal
If not let me know and let me know if on the front of the cabinet it has the "GUIDE PLUS" LOGO.
Dec 06, 2012 | RCA P52937 52" Rear Projection Television
RCA 52 inch fuzzy screen no buttons work no sound cable doesnt work on it just fuzz
First is you removed power by unplugging the surge protector---this may have confused the micro in the set.
Unplug the set itself (with it turned off) for a while and plug it back to see--sounds like this is your problem to me. Usually in this case only the on/off button on the set works.
Mar 27, 2012 | RCA HD52W56 52" Rear Projection HDTV
RCA projection TV
are buton on remote sticking or on tv it self clean controler tap on button
Oct 07, 2008 | RCA HD52W56 52" Rear Projection HDTV
Zoom control
Use the menu key on the set it has a size selection in the menu set it on widescreen or 16:9 I suggest buying a new original remote as even a new RCA universal remote may not have the ZOOM or aspect control on them.
Aug 20, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
I have a D52W26 RC 52 inch RCA TV
Turn the TV off then hold down the CHANNEL DOWN button on the TV and the CLEAR button on the remote at the same time.
Jun 27, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Tv will not turn on with remote or when I press the power button on the tv.
The P52960 uses the PTK195 series chassis. The most common cause of that set not starting up is a shorted flyback transformer. It is quite easy to test and replace the flyback transformer in that chassis, but that should be done by a qualified tech experienced in RCA projection sets.
Sep 18, 2007 | RCA P52960 52" Rear Projection Television
Parental controls
If you forget your password, press and hold TV on the remote and the
MENU button on the television simultaneously for 3 seconds. Parental
controls will then unlock and you can re-enter a password via Lock
Parental Controls
Aug 26, 2007 | RCA P52939 52" Rear Projection Television
Non Responsive 35" RCA
You are going to have to check all of the small tact switches behind the push buttons in the front of the TV set. In the past, someone may have cleaned the picture tube and the liquid dripped down onto the switches and corroded them, or one is stuck closed or the remote sensor is bad. The best way to test this would be to replace the entire switch panel in the front of the TV set. Good Luck
Aug 18, 2007 | RCA P52928 52" Rear Projection Television
Crazy menu, comes on periodically without using remote
believe it or noT: try replacing all of the switches on the control panel (((power button switch,menu button switch, etc...)))
Oct 27, 2006 | RCA HD52W56 52" Rear Projection HDTV
Computers & Internet Logo
Ekse
Marvin
Marvin
