How do i upload music to this MP3 player? i have used the sync option with Windows Media Player. you can see the songs on it when you open the player up under 'my computer' and even play the music on WMP. but it will no play independently. I have also tryed to drag and drop into the player and that wont work. The only songs that will play are the 2 songs that came on the player. thanks!
Are you using it through the usb lead if you are you should be able to open the file on the mp3 this should allow you to delete leave this file open but put the music you want on it in a shared file then open this file alongside the file on your mp3 this should allow you to drag and drop but try doing this with your mp3 switched off before you plug it in make sure its off and then when you plug it in it should switch itself on but dont touch the mp3 player and you should be able to drag and drop the files make sure their is enough free memoy on mp3 s some music files are massive you wont need to touch your mp3 player at all while it is plugged into your computer and it should work with no battery in it hope this helps
I am having the same problem but only on some of the songs and on those it says "format error"
