Question about Epson Stylus C46 InkJet Printer
Printer lights flashing.
I have epson stylus c46,cleaned heads ok but it took a while. when i clicked on printer to print item, message box came up saying internal components worn out need replacing and the green &red lights flash alternately.pushing the red button does nothing at all printer in good condition, has been working ok till now.tried disconnecting from computer&electric then re connecting still the same,would be greatful for any assistance or advice,thanks.tate
Posted by 77iworks on
  • Anonymous Nov 12, 2007
    Printer has been working fine until recently. I was prompted to replace the BLACK ink cartridge, which I did, (non genuine Epson cartridge, been using these for a while with no problem). Shortly after replacing cartridge, both green and red lights flashing alternately, and the message: " SERVICE REQUIRED. Parts inside the printer are at the end of their service life. See your printer documentataion".
    Printer has been working fine until recently. I was prompted to change the BLACK ink cartridge, which I did, (with a non-genuine epson cartridge, been using these for a while now with No problems). Shortly after replacing the cartridge, both GREEN and RED lights began to flash alternately, and the message was displayed; " SERVICE REQUIRED - Parts in your printer are at the need of their service life. See your printer documentation".
Aeronautical
    Novelist:
    Sniper:
  • 68 Answers
Please go to my website http://www.the-inkstore.co.uk . I have the latest version of SSC Service Utility to download directly onto your computer and instructions on how to use it, what to click on etc etc. Click any of the Epson links if you can't find it, everything you need to know will be there, including printer Firmware resetting which sorts out a multitude of problems.
The 'maintenance required' problem with Epson printers has absolutely nothing to do with which cartridges you are using, it is a built in page counter in your printer firmware, which has a different maximum amount for each Epson model. Don't listen to old wives tales and heresay, we are the experts and it's an Epson scam to cause a lot of people to pay for maintenance or throw their printers away.
I haven't found a model that can't be reset with the latest version of SSC Serve or the manual reset on my site.
For Epson RX500 users there is also a manual reset on my site, as the SSC Serve software won't do it for you.
When using the program & choosing your printer from the list, it may have a weird name with 'x' in the model number, this is because some configurations are for many models in a series. For example, the C46 will be listed as C4x as it is for the C42, C44 & C46 models.
I hope this helps all Epson users to overcome the Epson scam of page counting and locking out until you pay their dealers money for maintenance.
If you like what I've done for Epson users, please show your appreciation by spreading the word and perhaps buying your ink from my site.
Happy trouble free printing
The INK Store (UK & Europe)
Posted on Jul 15, 2008
Rommel Balcita
  • 749 Answers
The secret there is that you have to RESET the printer's "internal counter" by a utility software called "SSC Service Utility" go get it and install...
http://www.ssclg.com/epsone.shtml
Posted on Oct 31, 2007
Hi, I just installed a given Stylus C46 and the green (power) and red (ink) led light alternativly. I try to print something and nothing happen... What can I do ?
Dear friend,,
It's because of the EEPROM Error.Try the following program.
http://www.mediafire.com/?xydczelivyi
download it.Run ADJprog.exe.select printer model Epson c46,destination asia,Port usb or Something you've connected.Click ok.Select Cosumables maintanece counter click reset.
Hope it'll help
Mar 07, 2011 | Epson Stylus C46 InkJet Printer
C45 how to clean nozzels
You can print the print head using the Control Panel buttons;
1. Make sure that the fontp.gif power light is on and that the font28.gif error light is off. 2. Hold down the font28.gif maintenance button for three seconds. The printer starts cleaning the print head and the fontp.gif power light begins flashing. Important - Never turn off the printer while the fontp.gif power light is flashing. Doing so may damage the printer. 3. When the fontp.gif power light stops flashing, print a nozzle check pattern to confirm that the head is clean.
Mar 06, 2011 | Epson Stylus C46 InkJet Printer
Hi! printing flight boarding passes on Epson
run it through a cleaning mode.
in ctrl panel
select printer and r click go to
properties and then the
maintenance tab.
Run clean
Run Nozzle check
When it prints correctly
ensure you select paper size as A4 and print your pass.
Pleazse rate my help++++Thanks for using Fixya
Jun 04, 2010 | Epson Stylus C46 InkJet Printer
My epson c46 is not printing black
Is the black ink cartridge empty? If not, have you tried cleaning the print heads? Sometimes, if printers are used a lot, or used and then left unused for a long period, ink can dry on the print heads. While this usually just results in bad print quality, in extreme cases it can prevent the ink from printing at all. Check this article for directions on cleaning the print head.
Feb 19, 2010 | Epson Stylus C46 InkJet Printer
I have no way of changing the ink cartridge in my printer.
Hi, the information you need is here:
http://support.epson-europe.com/onlineguides/en/sc46/index.htm
Just click on the replacing ink cartridges on the left hand side, follow the instructions and pictures there.
Jan 13, 2010 | Epson Stylus C46 InkJet Printer
I need to clear the inkjet heads on my Epson Stylus R220.
Follow the steps below to clean the print head using the Head Cleaning utility.
Make sure that the printer is turned on and the ink out light is off. Access the printer software. Click the Maintenance tab, then click the Head Cleaning button. Follow the on-screen instructions. The power light flashes while the printer performs the cleaning cycle. Never turn off the printer while the power light is flashing. Doing so may damage the printer. When the power light stops flashing, load a few sheets of paper and click Print Nozzle Check Pattern in the Head Cleaning dialog box to confirm that the print head is clean.
Apr 21, 2009 | Epson Stylus Photo R220 InkJet Printer
WHEN PRINTING PHOTOS LINES APPEAR
Hi, It is unfortunate that you are having this difficulty with your printer. One of the best solution that we can give to you is run a series of head cleaning. Please try the following steps below to clean the print head in most effective way:
1) Make sure the printer is turned on but not printing. Make sure there are no error lights or messages appearing in the LCD.
NOTE: You cannot clean the print head if the any of the cartridges are expended. Replace the appropriate ink cartridge before proceeding.
2) Load letter size paper.
3) Click on START.
For Windows 95/98/ME: Click SETTINGS, PRINTERS, then RIGHT-CLICK on the EPSON STYLUS PRINTER ICON. Select PROPERTIES from the drop-down menu. Proceed to Step 4.
For Windows 2000: Click SETTINGS, PRINTERS, then RIGHT-CLICK on the EPSON STYLUS PRINTER ICON. Select PRINTING PREFERENCES from the drop-down menu. Proceed to Step 4.
For Windows XP: Click CONTROL PANEL, PRINTERS AND FAXES. RIGHT-CLICK your EPSON STYLUS PRINTER ICON. Select PRINTING PREFERENCES from the drop-down menu. If this icon is not showing, select VIEW INSTALLED PRINTERS. Then RIGHT-CLICK the EPSON STYLUS PRINTER ICON. Select PRINTING PREFERENCES from the drop-down menu. Proceed to Step 4.
For Windows Vista: Click CONTROL PANEL, HARDWARE AND SOUND then PRINTERS. Note: these steps may vary depending on how Vista is setup. RIGHT-CLICK on the EPSON STYLUS PRINTER ICON. Select PRINTING PREFERENCES from the drop-down menu. Proceed to Step 4.
4) Click on the UTILITY or MAINTENANCE tab, then click on HEAD CLEANING.
5) Follow the instructions on the screen to clean the printhead. Cleaning takes about 30 seconds, during which time the printer makes some noise and the power light flashes. Never turn off the printer while the power light is flashing, unless the printer has not moved or made noise for more than 5 minutes.
6) When the power light stops flashing click PRINT NOZZLE CHECK PATTERN and then click NEXT.
7) If the nozzle check pattern has no gaps in its lines, click FINISH. If the pattern has any gaps, click CLEAN to clean the printhead again.
8) If the situation continues after three cleaning cycles and nozzle checks, replace one of the affected ink cartridge(s).
9) Once the cartridge(s) has been replaced, please follow steps one through seven up to three times.
If the nozzle check still has gaps after you have run at least 3 consecutive cleaning cycles and replaced the affected ink, your printer will require service.
Tirzo
Jun 13, 2008 | Epson Stylus CX6400 All-In-One InkJet...
Printing in blue only
Try cleaning printhead like shown in this video. Usually works quick.
Dec 12, 2007 | Epson Stylus CX6000 All-In-One InkJet...
Problem with my printer
well first here http://emeasupport.epson-europe.com/downloads.aspx?LNG=EN-EU&Search=1&data=1bANIZf8BRVoS83cS1PVis/kIVxbLcWZ9JD5vhjblgJTVeIjQGvfyu2+tOhzwN03 for more info & your drivers but what you need is new ink cartages
May 25, 2006 | Epson Stylus C46 InkJet Printer
Epson Stylus C46 InkJet Printer Logo
196 people viewed this question
Top Epson Office Equipment & Supplies Experts
Thomas F. Schneider
Ekse
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
