Question about Polaroid Office Equipment & Supplies
I don't have the charger or cable for this, but I do have all the rest needed. After an extensive search for a charger I am unable to find one. Is there a separate charger I can buy for the type of battery used or an alternative that will fit into the printer. I just need to charge the battery and it seems Polaroid have made it near impossible to do so if you lose the charger.
SOURCE: how to connect the Polaroid Pogo to a computer
You can only connect the Pogo to a PC by using a Bluetooth wireless connection. Once a bluetooth connection is established between your PC and the PoGo you can print by simply using Explorer to send a JPEG file to the PoGo via Bluetooth (no printer driver needed).
Posted on May 20, 2009
SOURCE: Use of polaroid PoGo Zink printer with PC
The PoGo can connect to a PC with Bluetooth only. Once you establish a Bluetooth connection with your PC, simply copy any JPEG file to the PoGo using Explorer. No printer driver is needed, just copy the file to the PoGo over the Bluetooth connection.
If your PC doesn't have Bluetooth, you can buy a USB Bluetooth dongle for $5-$20.
SOURCE: polaroid pogo printer
Here is a link for the Polaroid PoGo User's Manual
Posted on Sep 08, 2009
SOURCE: bought today..does battery have to be charged for 3 hours before use? please advise
first of all make sure that the pogo it turned off insert the paper from the packet with the blue peice on the bottom with the barcode facing down. and the paper facing shiny side up and logo face down. when you turn the pogo on the blue paper will feed through first then the printer is all setup and aligned ready to print via bluetooth or via USB cable. hope this helps
Posted on Oct 30, 2009
