Question about Sony KV-36XBR450 36" TV
No picture but has sound
My sony tv has sound when you turn it on but no picture.  We have unplugged the tv waited and the picture would finally come up. We called sony support and all they told us is to unplug. this morning when i got up the sound was there no picture but after cutting the tv off several times the picture appeared. now to come back home and have the same thing happen. after cont cutting off and on the picture will appear the sound is fine.  the red light does not blink after the tv picture appears. when you first cut the tv on it blinks then.  please help??? after the picture appears i have cut the tv off and on and the picture comes on its when you cut the tv off for a period of time there is no picture but we have sound.
Posted by newg68 on
  • 27 more comments
  • meg1968 Nov 02, 2007
    Have a LG flat screen. No picture but has sound. Picture appears when play dvd but no aerial pic or video pic
  • Anonymous Nov 03, 2007
    sony kv-36xbr400 no picture, has sound
  • Darwood Nov 04, 2007
    We moved the TV and now the picture does not come up. the standby light keeps blinking. We did not drop the tv, and did not jar it at all. The sound works fine. Any suggestions?
  • Prima_help Nov 07, 2007
    I have a Prima. Similar problem: About 3 weeks ago the picture just went black. I turn it off and on and the picture returned. I had to do this about 5 times in the past 3 weeks until last night, when turning the tv off and on did not work. Now when I turn it on, the "Prima" logo which normally comes on when I first turn on the tv, flashes across the screen for a split second and then everything turns black. I have tried many time now and still no picture. I have plugged everything out from the back, including power cord, then only plugged back in cable and power cord...but still nothing. As it stands, I have sound for cable, dvd, and vcr but no picture for any.
  • durgaprassad Nov 07, 2007
    My LG tv has sound when you turn it on but no picture. We have unplugged the tv waited and the picture would finally come up. We called sony support and all they told us is to unplug. this morning when i got up the sound was there no picture but after cutting the tv off several times the picture appeared. now to come back home and have the same thing happen. after cont cutting off and on the picture will appear the sound is fine. the red light does not blink after the tv picture appears. when you first cut the tv on it blinks then. please help??? after the picture appears i have cut the tv off and on and the picture comes on its when you cut the tv off for a period of time there is no picture but we have sound.
  • Anonymous Nov 07, 2007
    Same problem here, turn on tv to lit screen for a few seconds (w/ sound) then all disappears to black screen (w/o sound) - red light blinking.
    What is the average life span of a projection tv?
  • Anonymous Nov 13, 2007
    My sony Tv is only giving sound but no picture, to see picture the Tv has be turned off and on, but soon after the problem appears. What can be done?
  • sal148 Nov 25, 2007
    I have a samsung ps42s5h TV. It doesn't have any picture but has sound. I have tried switching it on & off. But, no luck. Any suggestion would be welcome.
  • chocfudge Nov 26, 2007
    Same problem as many out there.TV (JVC) has sound but no picture, even when linked to DVD player. Any idea what could possibly be wrong. TV is only 2+ years old.
  • trousdeloup Nov 27, 2007
    Sounds like exactly same problem I have. Sony Trinitron, 36". Sound but no picture, standby light flashes constantly.
  • jpuniq Dec 06, 2007
    I'm having the same problem with my 32". No picture and the power light just continues to blink. So it does not appear to correspond to any of the diagnostic codes. All we did was move the TV from one apartment to another. Anyone have any ideas?
  • Anonymous Dec 07, 2007
    same deal...sound, no picture
    Same problem.  Audio, no video.  Began when screen went "dull" on Dec. 6, Dec. 7 no video.  32" Sony Trinitron not even 9 months old yet!  Can't exactly take 180 pound TV set to the local repair guy.
  • AndyS-UK Dec 19, 2007
    I have a Sony TV that is around 11 years old. Also when you turn the TV on you get perfect sound but no picture at all. After about half an hour the picture then comes up and is fine. But if you turn it off, you then have to wait the half hour again ! This has only started recently, but initially you only had to wait a few minutes so it's getting worse.
  • Fed up in SD Dec 20, 2007
    I have a similar one, mine's a 32". Sam thing, no picture, but sound. It does display the channel and voume info. I can get a picture only if I grab the top of the tv and pull, with quite a bit of force, but it immediately goes away when I let up.
  • Anonymous Dec 24, 2007
    elite pro200- has sound/no picture- will work for a week then no pic. may start working for a while then go out sometime for 10 min. or days. currently out
  • duvalle Jan 12, 2008
    no pictue but have sound same problem others are having with
    Sony KV-36XBR450 36
  • tlcd Feb 24, 2008
    TV has a bright red tint. The TV will then turn off and a red light will start to blink.
  • thepinklady Feb 29, 2008
    32" LCD Polaroid TV. No picture but has sound and the Dish network
    information comes on the black screen.
    Purchased Aug 06. Has it lived it's life already?
    Unplugging, resetting to default did not work. Any more suggestons.
    Thank you,
  • Anonymous Mar 02, 2008
    I have a five year old sony 36xbr450 with a black picture. I have sound and a functioning remote. I am not able to view a dvd either.
  • paparrin Mar 30, 2008
    i cant
  • jamescamacho Apr 01, 2008
    I have a sony KV-32S40 which the the picture went out as well as the sound. The tv is eight years old. I tried unpluging it a few times but no luck.
  • malvir Apr 20, 2008
    I unplugged the direct Tv connection & plugged it again. Still no picture
  • regymart May 04, 2008
    i have a sony kv 32ls60 i have sound but no picture standby light flashes
  • Anonymous Jun 03, 2008
    i can hear the tv but cant see picture i keep turing on the power buttton but picture will not come on theres a stand by button flashing how can i turn the flashing light off HELP
    Thank You Stella
  • Anonymous Jun 20, 2008
  • ujjablonski Aug 13, 2008
    Sony large 52 or so inch floor model picture in a picture, times 9.
    We have the same problem,no picture, yes sound,
    for some now we had the picture come on after several clicks of on&off,now no picture at all the flashing light stays, it's not the remote or battery.
  • Jobserver Sep 24, 2008
    No Picture has sound Sony KV36XBR450 no result foirm the shake wire harness review other details will check all boards for bad solder any other suggestions will be appriciated thank you
  • wp4eld1 Jan 24, 2009
    how to make a factory setting?thnks
Anonymous
  • 86 Answers
Hello .this does sound like bad solder joints .all printed circuit boards do this after a while due to heating and cooling .is not advisable to try to repair yourself .possible electric shock and spiking .will do a lot of damage .take to a shop to have repaired
Posted on Feb 23, 2008
Anonymous
    Problem Solver:
Lost connection somtimes, use rubber materials or stick try to tap the board when the picture cameback thats trouble is loss connection
Anonymous
I worked. Thanks
Posted on Jan 15, 2008
Anonymous
Simple.
Remove the power from the mains socket. Leave for 1-2 minutes. Re-plug and set it for Factory Settings.
CaptainTexel Helsinki
Posted on Dec 09, 2007
Sony Trinitron TV will not switch on
Please let us know what model Sony you have. You can try unplugging the TV and waiting at least 30 minutes. Plugging in the TV and using the power switch on the TV itself.
Oct 04, 2008 | Televison & Video
No sound Sony KP-57WS510
Brain Freeze ! Sometimes the microprocessor locks up...
you may need reset = unplug ac cord, wait, then try again..
..........T.
Jul 01, 2008 | Sony KP-57WS510 57" Rear Projection HDTV
The problem can be caused by a bad sustain board (Ysus Zsus) , the popping sound is often caused by a capacitor blowing up.
The TV must be taken apart and tested before eventually replacing sustain boards.
Apr 27, 2008 | Zenith Z50PX2D 50 in. Plasma HDTV
My LG TV
switch on no picture but short period of sound then nothing
Jan 20, 2008 | Sony KP-51HW40 51" Rear Projection...
have a 42 inch rca 42PA30RQ NO PICTURE OR SOUND WHAT CAN I DO MY SELF BEFORE SPENDING A LOT OF MONEY TAKING TO A REPAIR SHOP
Dec 14, 2007 | Panasonic TC-26LX20 26 in. HD-Ready LCD...
TV Picture Goes Black
I had the same exact problem.
I removed the bulb and cleaned it. There is a small screen at the top of the bulb and it was covered with dust. Once it was cleaned I replaced the bulb and it solved the problem.
Thanks to those who posted the solutions
Jul 28, 2007 | Sony Grand WEGA KDF-60WF655 60" Rear...
Sony KV-36XBR450 36" TV Logo
Top Sony Televison & Video Experts
Muntejaya Ginting
Muntejaya Ginting
Nasir Muhammad
Nasir Muhammad
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
