Question about Canon PIXMA MP160 All-In-One InkJet Printer
I have a problem with my Canon PIXMA MP160 All-In-One InkJet
I have a MP160 that is giving an error code E42,i thing it is a scanner error. Please tell me if i am correct and  how can i solve the problem
Posted by givanni on
  • 9 more comments
  • Anonymous Nov 07, 2007
    Error code 4, 2.
    Error 2 is 'No paper' and error 4 is 'Empty ink tank'. I know this because straight from the box I had the same 2 errors. Also when I lift the lid to replace the ink the carriage is supposed to go to the left so you can change the ink, but mine doesn't so when I move the cartridge carriage left and install the ink it still gives the errors.
  • lassecas Nov 13, 2007
    I have the same problem E42. Any help or new information?
  • chikooooo Nov 28, 2007
    I have the same problem. Also the on/off button flashes and the alarm flashes
  • Kimberly50 Dec 03, 2007
    I have the exact same problem. E42 appears and the on/off and alarm button are flashing, how do I fix it?
  • Anonymous Apr 07, 2008
    When I start my canon Pixma MP 160, The display Show E42 and any function cannot work please tell me what can I do
  • tsorin May 14, 2008
    Hello! I have exactly the same problem. Have anyone got the answer? Please help me!!!
  • Anonymous Jun 29, 2008
  • Anonymous Aug 24, 2008
    flashing a E42 error
  • arthas0729 Oct 02, 2008
    E42 problem in my Canon MP160
  • caradec Oct 20, 2008
    On my MP 160,I have 3 errors : error 2
    error 4 or error 42?
    error 5010
    Can you help me?
    Thank so much
    Best regards
    Nat
  • pasina May 11, 2010
Anonymous
Replace it, it's the easiest way. it's a scanner error
Posted on Feb 04, 2008
Anonymous
  • 34 Answers
Fiend your solution direct from Canon. Here is your solution...
http://www.canon.com/printer/prob676ijt65/solution
283
Posted on Mar 16, 2009
Anonymous
I had the exact same problem with my MP150 & it is most definitely a scanner issue.
I slowly & very carefully pulled my printer apart (remembering where the parts & screws came from). On the left hand side of the scanner a small ribbon had been disconnected (the result of pulling it apart earlier to fix a severe paper jam) I simply pushed the ribbon back in & put the printer back together.
Although this procedure is pretty basic, I wouldn't recommend doing this yourself unless you have some computer building/ repair skills up your sleeve as the parts can look a little daunting if you do not know what you are looking at.
But then again if its broken & your looking at getting another printer anyway, whats the harm of trying.
Just make sure you disconnect the power first & its usually a good idea to ground yourself or use a static strap to avoid any damage to your printer.
Posted on Feb 07, 2008
Error e42 22
Apr 24, 2011 ... E40 20 = Other hardware error. E42 22 = Scanner error. How to reset CANON WASTE INK COUNTER MP160/MP145 Before you reset the ... canonprintersink.com/error-code-printers-reset-canon-mp145-mp160.html canonprintersink.com/error-code-printers-reset-canon-mp145-mp160.html
have just checked this site and I am sure it will help you
Feb 20, 2012 | Canon Office Equipment & Supplies
My pixma mp160 doesn't want to scan and through a error messages 2,250,0. what must I do? the led flashes E 42.
E42 is a scanner error.
Turn off your printer and unplug from electrical outlet.
Wait at least 20 minutes.
This will allow the scanner lamp and components to cool.
Plug printer back in and turn on printer.
Feb 02, 2011 | Canon PIXMA MP160 All-In-One InkJet...
Eroor E42
E42 means there is a scanner error. Canon website suggests you turn off the machine, and unplug the power cord from the power source. Wait approximately ten minutes, plug the power cord back in and power on the machine.
If the error is not resolved, a machine service error may have occurred. Please contact your local Service Center.
Dec 20, 2010 | Canon PIXMA MP160 All-In-One InkJet...
ERROR E22 ON MY MP160 PRINTER
E22 = Carriage error
Aug 04, 2009 | Canon PIXMA MP160 All-In-One InkJet...
Hello there Mr Expert. I have just pulled apart my MP160 to remove some material (the printer cover) which was drawn in together with the paper. After reassembling I have an error E42. Any idea what is...
Erro code 42 error definitely caused by loose flat cable or the ribon cable, check for any loose and attach it again. Also this could be a problem with the cable it could be the contact with is damaged and need to be replaced.
This cable need to connect electronics on your printer.
Hope this helps.
micro
Jul 19, 2009 | Canon PIXMA MP160 All-In-One InkJet...
E42 Error
E 42 mean scanner error please service it by a technician
Jul 11, 2009 | Canon PIXMA MP160 All-In-One InkJet...
Mp160 E42
hi,
CANON PIXMA MP160 All-In-One InkJet Printer
has few common problems. Such as Driver CD lost, Scanner does not work, Connection problem etc. For find all these software solution just click here....
pow-e-r-28
Jun 15, 2009 | Canon PIXMA MP160 All-In-One InkJet...
Mp160 e42 error
hi,
mbhd2
Jun 14, 2009 | Canon PIXMA MP160 All-In-One InkJet...
Canon PIXMA  MP160 All-In-One InkJet Printer Logo
5,542 people viewed this question
old marine
old marine
Ekse
Tareq Bin Mostaq...
Tareq Bin Mostaq...
