Question about Canon FAX-L350 Plain Paper Laser
Canon L350 fax machine set up instructions
How do i program my fax machine
Posted by airtours on
  • 1 more comment
  • love bird Jun 26, 2008
    How do I store a number and program the caller identification on my fax machine. I pressed set and imput the mumber nothing happened.
  • Anonymous Oct 02, 2008
    Where do i put the cords In to hook up my phone line to my com.
    Thanks!
  • perform Dec 04, 2008
    it will not send or recieve faxes the line connection is ok it can copy and print reports i think it some setting but i can't find a solution to it.
Anonymous
I want driver for windo XP
Posted on Oct 06, 2008
Anonymous
    Problem Solver:
  • 5 Answers
What do u need set up
Posted on Jun 10, 2008
Change the dates on the canon fax l350
Lift the flap on the right-hand side of the fax machine.
Select Data registration
use the down arrow
1. Data registration
SET
1. User Settings
SET
1. Date & Time
SET
Enter date or time
SET
Good Luck!
Hope this helps!
CreativeTECH
Dec 20, 2010 | Canon FAX-L350 Plain Paper Laser
I NEED TO RE-PROGRAM PRESET NUMBERS, BUT DON'T HAVE MANUAL FOR CANON L350 FAX MACHINE?
Open panel cover Press DATA REGISTRATION Press V to display 2. TEL REGISTRATION Press SET twice Press V (if necessary) until an empty space appears Press SET twice Enter Fax number Press SET twice Enter name using number keys (e.g. 2 = A,B,C like a mobile phone) Press > to enter next letter Press SPACE to enter a space Press * to enter a numeric Press SET To continue press DATA REGISTRATION Repeat steps 5 to 10 To end press STOP
Feb 09, 2010 | Canon FAX-L350 Plain Paper Laser
How can I change form "only fax" mode to "phon&fax" on canon L350 model?
On the key panel there is a receive mode button or press the dataregistration button.Scroll to RX setiings press set and scroll to RX mode change it to fax tel.
Nov 22, 2009 | Canon FAX-L350 Plain Paper Laser
I have a canon fax-l350 and I want to use it as printer too. so how can I adjest it with my pc and the required materials and softwares
To set up the L350 as a local printer (I'm assuming that you are not putting it on a network) you will need the Canon FAX-L350 CD-Rom which contains the Fax suite (I have version 3.11). You will also need a parallel printer cable as the fax machine only has a parallel printer port on the rear (the other side to the power cable.
When loading up the CD-Rom (which should have been supplied with your machine - if not you may have to buy one off the web), first make sure you read chapter 2 in the manuals folder on screen then install the driver from the 'program setup.exe' file.
After loading the CD-Rom onto your PC (and before making any physical connections between the PC and the Fax) make sure that the fax is switched off at the mains and also logout and switch off your PC. Next, connect up the cable (Canon recommend a cable that complies with IEEE1284). Centronics supply these cables, but if you do not have a parallel (8 bit ) port on your PC you can get a converter cable (Centronics 36) which will connect the parallel cable to a USB port on the rear of your PC. After checking the connections you can switch your fax back on and also power up your PC. Hope this helps.
Dec 23, 2008 | Canon FAX-L350 Plain Paper Laser
Changing User Information
open the side door
press data programing
data regretion
user data
Aug 12, 2008 | Canon FAX-L350 Plain Paper Laser
Change Date/Time on Canon Fax L350
Left the flap on the right hand side of the fax machine.
use the down arrow
SET
1. User Settings
SET
1. Date & Time
SET
Enter date or time
SET
Nov 16, 2007 | Canon FAX-L350 Plain Paper Laser
Fax not receiving
Sounds like you have done a through job troubleshooting and its reacting like it should. Try this first press data registration and press # press down arrow to clear and press set scroll down to ALL and set. This will wipe out all programming. Then try sending. If it still reacts the same. You may need to change the main board
Dec 04, 2006 | Canon FAX-L350 Plain Paper Laser
Canon FAX-L350 Plain Paper Laser Logo
477 people viewed this question
old marine
old marine
Ekse
Tareq Bin Mostaq...
Tareq Bin Mostaq...
