Question about Nikon Coolpix 4600 Digital Camera
Dear Mr. Expert...
I'd really appreciate if you could help me.
The buttons of my Coolpix 4600 stop working after some minutes I've turned on my camera. The display works perfectly well.
Thanks for your time!
Posted by Sophie_d on
5 Related Answers
Anonymous
  • 2985 Answers
SOURCE: Nikon coolpix 4600
i don't know what this means- it's more an error in the laptop I would think Can you still see images via the review control in the camera?
Posted on Aug 14, 2007
poolseman
zdenek vajdak
  • 206 Answers
SOURCE: no image
Bad news is that it is CCD sensor that seems faulty ( and only way to repair this fault is to replace the CCD block ) but the good news is that Nikon repairs this problem free of charge on this model even if your warranty has expired. Contact Nikon and have a new CCD sensor installed.
Posted on Sep 22, 2007
Anonymous
SOURCE: digital camera
No firmware upgrade available yet, but did you set the camera settings to the TYPE of battery you are using? Go to Setup, chose Battery, then set type - alkaline, lith, metal hyd, etc and see if that helps.
Posted on Jun 06, 2009
Anonymous
  • 8 Answers
SOURCE: No audio with coolpix 4600.
hello,
1.it may be a cable fault change the av cable,
before changing the cable check it out on another camera
2.the microphone holes may be clogged (use a rubber blower to blow away the dust)
3.initialiaze the camera (set up mode)
hope this helps
Posted on Jul 14, 2009
Anonymous
SOURCE: Lens error displayed by coolpix 3700
With the lens facing downward, hit the camera a sharp tap against the palm of the hand whilst simultaneously turning the camera 'ON'. If that fails, tap against a stiffer surface (desk or table), allowing room for the lens to extend and taking care not to damage the body of the camera.
Posted on Sep 01, 2009
I've inhereted a Nikon Coolpix 4600 Camera but not the software with it. I bought a 4G SD memory card but the camera says "this card cannot be used" any ideas?
The 4600 works with SD cards. Your 4GB card is actually an SDHC card. While it fits into the slot, it is electronically incompatible and will not work. The camera is limited to SD cards, 2GB and smaller.
You can download the manual at
http://www.nikonusa.com/pdf/manuals/coolpix/4600_5600_en.pdf
You can download the current versions of all (free) Nikon software from
http://support.nikontech.com/app/answers/detail/a_id/61
Jun 16, 2011 | Nikon Cameras
Please help me turn the flash off on my Coolpix 4600. When I go to Menu I don not see an option regadring F;ash.
There should be a button on the camera with a lightning bolt icon. Press it and watch the screen.
Jun 11, 2011 | Nikon Coolpix 4600 Digital Camera
hello,
hope this helps
Jul 12, 2009 | Nikon Coolpix 4600 Digital Camera
COOLPIX 4600 CLOSED AFTER A PICTURE
Change setting to AUTO.
Use Flash.
Use High ISO
Press the buttons gently once and wait. Let the camera think , give it time to think.
Vitally
Jul 02, 2009 | Nikon Coolpix 4600 Digital Camera
Nikon Coolpix 4600 lens extended and won't turn on
Go to store and purchase a memor card reader/writer. It will allow you to put your memory card in it and download the pictures to the computer via the usb port. Make sure the reader/writer is made to accept your type of memory card.
Dec 27, 2008 | Nikon Coolpix 4600 Digital Camera
Does anyone know how to turn OFF the auto focus on the Nikon Coolpix 4600??
Hello, After doing some research on the NIkon Coolpix 4600, it seems the camera is constantly doing the autofocus thing. IOW - it can't be turned off. Hope this helps.
Dec 03, 2008 | Nikon Coolpix 4600 Digital Camera
Nikon coolpix 4600.
Hi I found this info on the Nikon Australia website:
"System Error" or "Lens Error" message in LCD monitor trnsp.gif Question My COOLPIX camera displays a "System Error" or "Lens Error" message. What should I do? trnsp.gif Answer Having a "System Error" or "Lens Error" message displayed on the camera's LCD monitor would generally indicate that your camera needs servicing. A System Error is a general error which can be caused by many things: lens problem, CF Card problem, general camera failure, etc. To troubleshoot, please try the following:
  1. Use the memory card that originally came with your camera (or a Nikon approved card).
  2. Remove and replace the battery.
On the other hand, a Lens Error generally means that an error has occured during the lens operation. To troubleshoot, please try the following:
  1. Turn off the camera.
  3. Turn on the camera.
If the above tips do not help, your camera must be sent to our Nikon Authorised Service Centres, there are no user serviceable parts in our Nikon COOLPIX cameras. We apologize for any inconvenience caused and we will do everything to repair your Nikon camera as quickly as possible. Click Here for our Nikon Authorised Service Centres details.
Seems you may just have to remove and replace the battery - sort of like a Windows Restart to fix a computer problem! - this would reset your camera's memory.
Hope this helps.
Apr 29, 2008 | Nikon Coolpix 4600 Digital Camera
Horizontal stripes Nikon Coolpix 4600
CCD failure- may be replaceable with new camera - check out Nikon support
Sep 22, 2007 | Nikon Coolpix 4600 Digital Camera
Camera won't take pictures
now u just need to replace the mainboard..... it´s pretty normal for then to go off if u don´t use it in the conditions they were made to.
Feb 07, 2007 | Nikon Coolpix 4600 Digital Camera
Nikon Coolpix 4600 Digital Camera Logo
128 people viewed this question
Top Nikon Cameras Experts
Ric Donato
Ekse
FIKRET UNALIR
FIKRET UNALIR
Level 1 Expert
Are you a Nikon Camera Expert? Answer questions, earn points and help others
