Question about AudioBahn A3351 CD Player
AUDIOBAHN A3351 WIRING HARNESS
ANY IDEA WHERE I CAN GET A WIRING HARNESS FOR THE BACK OF THIS UNIT? HAVE CONTACTED AUDIOBAHN WITH NO RESPONSE. THANKS, RICK
Posted by SIGGY614 on
  • Anonymous Apr 11, 2008
    NEED TO GET WIRING HARNESS FOR A3351
Anonymous
  • 3 Answers
You have to find one that somebody has audiobahn dosnt carry them any more i called them today for mine but no luck
Posted on Dec 21, 2007
Hi i have whirpool awm 8900 and i have fault f11 what is this?
In your service manual it states for the f11 code
F/11 Serial Communication Error
Communication between the Central Control Unit (CCU) and the Motor Control Unit (MCU) cannot be sent correctly.
globul1a.gif Check Wire Harness connectors to the MCU, the motor, and Central Control Unit (CCU) globul1a.gif Check the Drive system for any worn or failed components globul1a.gif Check MCU globul1a.gif Check CCU globul1a.gif Check Motor globul1a.gif Check Wire Harness
If you have any further questions message me back I await your reply Thanks again Rick
Jun 20, 2011 | Whirlpool AWM8000 Front Load Washer
Kitchenaid dishwasher KUDD01DPPA0 lower drawer has no lights on start/stop badge and that drawer will not run.
hello, this is the schematic for your entire machine in case you ever do need it http://www.searspartsdirect.com/partsdirect/part-model/Kitchenaid-Parts/Dishwasher-Parts/Model-KUDD01DPPA0/0593/0130000?pathTaken=&prst=0&shdMod=KUDD01DPPA0 in your manual it would say what the start stop badge means If this unit is new do not attempt to repair the unit as it would be warrantied and you would void your warranty and I think it is still warrantied seeing how there is no manual online available yet if your unit is not warrantied and you require further diagnosis please message me back and I will look further into your situation Thanks Rick
p.s the stop badge could mean you have a blockage in your drain area but need clarification on your warranty information first Thanks again Rick
May 19, 2011 | KitchenAid 23 in. KUDD01DPPA Stainless...
I have a GHW9400PL4 that's showing an F 6 error code. Any ideas? Thanks, Rand
f 06 is a in issue with the motor control board, check the wiring harness attached to the board next to the motor youll acess the harness better form the front of the unit, try removing the 3 screws from across the front of the bottom. and drop the acess panel it will be right there may also be the motor but its rare that it is if you have any further questions message me back and please remember to rank how this opinion has helped it allows me to help others in the future Thanks Rick
Feb 04, 2011 | Whirlpool GHW9400 Front Load Washer
Need info on wiring for audiobahn aeq6q 5 band equalizer
Yes, This connects to the Blue Remote Wire. This will allow the EQ To Power on when in ACC or Start on the Ignition. Please Rate My Response! Thanks!
Feb 03, 2009 | AudioBahn AEQ6 5-Band Car Equalizer
FACTORY CAR STEREO INSTALL
Look at Schoche.com for the Number of the Wiring Harness that you need . You may be able to get it at Wal-Mart. Please Rate my Response, I need all the Help That I can Get! Thanks!
Jan 28, 2009 | Car Audio & Video
Radio wiring
The connector configuration and wiring color scheme for a Toyota Radio Harness is available here.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa
Jul 07, 2008 | 1985 Toyota Pickup
Wiring diagram needed RV rooftop coleman
Motor1258,
Thanks for the response, to be more specific, the nine pin connector was damaged, but I was able to connect the wires back to main unit panel. I am ready to hook to the hunter thermostat and do not know which wires to connect to. This is my problem and I do not want to short something out. Hope this helps, I want to get it installed again. Thanks again for caring....Jerry
Jun 17, 2008 | Coleman Mach III Air Conditioner
Audiobahn A4002T that keeps popping fuses
Does it blow them immediately when inserted, only after the headf unit is turned on or only at high volume?
Jun 07, 2008 | AudioBahn A4002T Car Audio Amplifier
Wiring
audiobahn.com under tect support you can download manuals and get wiring diagrams for free
Mar 06, 2008 | AudioBahn A2801Q Car Audio Amplifier
Audiobahn ATB8AT
try radioshack, walmart, or try ebay
Jan 06, 2008 | Audiovox BA200 Car Subwoofer
AudioBahn A3351 CD Player Logo
109 people viewed this question
Top AudioBahn Car Audio & Video Experts
Professor_V
Professor_V
Alphanso Tee
Colin Stickland
Colin Stickland
Are you an AudioBahn Car Audio and Video Expert? Answer questions, earn points and help others
