Question about Gateway M305CRV Notebook
Laptop fell on the floor (2ft drop)
As the subject says, my laptop fell to the floor and won't work now.  Mind you, the battery had already been shot by then so the battery is no help at this point.  I have an aftermarket power adapter that has a light on it that stays on all of the time.  When I plug it in to the back of the laptop now, the light turns off.  This is telling me there's got to be a short in the computer.  Where do I go from here?
Posted by Stephen Hardyway on
  • aira k Dec 19, 2008
    same thing here
    my sister was running out from our room when she dragged the cord with her
    the laptop flew of the chair and landed flat on the floor with the monitor flat on the floor (wide open)
Anonymous
    New Friend:
I had my computer sitting on a tall box and my foot was cought on it when i got up and it flew across the room now it sometimes make this really loud noise ,it kind sound like as if there was a cd in it and the cd was scratching but i have a computer that has a built in cd player on the side. and it sometimes freeze and doesnt let me turn the computer off.
Posted on Jun 02, 2010
Anonymous
Your laptop hit the floor with a velocity of almost 12 m/s (43.2 km/hr). OUCH.
Posted on Oct 23, 2008
Anonymous
    Novelist:
  • 188 Answers
Take it to someone that can disassemble it and repair the short at the jack - The jack probably got pushed into the computer when it fell and shorted. Typical repair cost at most shops is $100-$150 (although your might be more because of the short).
If you can disassemble it and take just the motherboard in to a shop labor should be a lot less since you will do 1/2 the work.
Get a recommendation for a place if you can since there are some places that are not very capable at soldering.
Posted on Dec 28, 2007
HP Laptop fell down to floor
Is that a question? Or a statement? Did it go BOOM? Rarely does anything good come from dropping a Laptop.
Sep 24, 2013 | Computers & Internet
How to tell if a105-s4074 satellite battery is bad
If thelaptop battery is more than 3 - 4 years old then the battery could be worn out.Rechargeable batteries have a finite number of charge and discharge cycles andwill lose their charge capacity over time, i.e. won't charge to 100% andgradually the charge reduces until the battery won't charge up at all. OR Thebattery shows a 100% charge but when the adapter is disconnected the batterydrops off to zero capacity in a very short time. If the battery drops to anunacceptable charge level then the battery needs to be replaced.
Apr 28, 2012 | Toshiba Satellite A105-S4074 Notebook
Battery low while already plugged in
If thelaptop battery is more than 3 - 4 years old then the battery could be worn out.Rechargeable batteries have a finite number of charge and discharge cycles andwill lose their charge capacity over time, i.e. won't charge to 100% and graduallythe charge reduces until the battery won't charge up at all. OR The batteryshows a 100% charge but when the adapter is disconnected the battery drops offto zero capacity in a very short time. If the battery drops to an unacceptablecharge level then the battery needs to be replaced.
Mar 25, 2012 | Dell Vostro 1000 Laptop
Medion E1210 notebook. Battery has suddenly stopped charging. Didn't get a fall. Laptop works fine when power supply connected, but if plugged out laptop shuts down immediately. When power plugged in...
Ifthe laptop battery is more than 3 - 4 years old then the battery could be wornout. Rechargeable batteries have a finite number of charge and discharge cyclesand will lose their charge capacity over time, i.e. won't charge to 100% andgradually the charge reduces until the battery won't charge up atall. ORThe battery shows a 100% charge but when the adapter is disconnected thebattery drops off to zero capacity in a very short time. Ifthe battery drops to an unacceptable charge level then the battery needs to bereplaced.
Jun 21, 2011 | Computers & Internet
Hi guys my Toshiba m35x s149 fell 2 feet to a wooden floor.The battery meter shows power of 63% but upon removing the power cord it switches it off.Tried another battery same response.when all is off( no...
I would think that the internal battery connections have been damaged from the fall. They may only need re-soldering. Any drop on to a hard surface from almost any height can damage your laptop.
Apr 18, 2011 | Toshiba Satellite M35X-S149 Notebook
I dropped my laptop on the floor, it fell on a corner, the screen is scrambled on the right side for 1 inch and the top right corner is black like a broken window what shouls I do? Thank you
You can either replace the screen or you can work on your laptop with a broken screen. Replacing the laptop screen is quite costly depending on your laptop model and availability of your parts.
Jul 27, 2010 | Computers & Internet
Laptop will not work
Believe it or not Laptops are very sensitive. The processors, motherboard etc. are only protected by a thin plastic covering. Your best bet is to call the brand laptop you have. (HP,Dell, Toshiba etc.) And send it in, will cost money, but if you don't wanna pay hundreds of dollars for a new one. I'd recommend sending it in.
Best of luck!
Jan 08, 2010 | HP Compaq Presario CQ60Z Notebook
Dropped laptop, now no sound. No external injury.
Does it have a sound card or adapter inside of it?May have come loose.
Jan 05, 2010 | Acer Computers & Internet
3680 2682 Laptop fell off bed to floor w/ USB drive plug in back
hi, if the port is working fine, its ok.. but do not use this port, since its damaged, it could short the pins inside while pluging the cable, left side is better
Jan 03, 2008 | Acer Aspire 3680 Laptop
Gateway M305CRV Notebook Logo
1,157 people viewed this question
Top Gateway Computers & Internet Experts
Ekse
Prashant M
Prashant M
Thomas F. Schneider
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
