Question about Belkin (F5D7230-4) Router (587009)
Belkin F5D77230-4 - connecting to modem
I'm trying to set-up a wireless connection on my laptop - have followed the installation guide but when it says to connect my modem to the wireless router I'm stuck as the cable and connections on my modem are USB but the Belkin Router only has connections for 'ethernet' type cables.  Do I have a cable missing? Is there something I need to do differently or an adaptor I need to buy?
Thanks..
Posted by HHought on
Anonymous
I have everything set up from the model to the router but, when the program starts to run is says that the internet is not connected.
Posted on Jan 26, 2009
ramji duraiswamy
    Scholar:
  • 193 Answers
K ur modem is usb one either u need to change the modem has ether net or get a convertor like usb to ethernet better contact isp and change the modem rate me solved if its help full
Posted on Oct 30, 2007
1 Related Answer
Benimur
Louie Role
  • 6966 Answers
SOURCE: Belkin F5D77230-4 - connecting to modem
It would seem that:
Your modem has only USB output;
Your Router has only Ethernet input with WiFi & 4 LAN port outputs; and
You want your laptop to be access the Internet through wireless connection.
There are USB to Ethernet converter/adapter, an example is shown here.
There are on the otherhand, comparable modems to what you have that provides both a USB and an Ethernet output such as the ProLink H9000 shown here .
Perhaps your best course of action is give your provider first a call and see if you can require them to replace your modem with another model/version, one that has an Ethernet output or a combination.
Alternately, a way can be configured if you have a desktop that has both a USB and Ethernet that we can set up as Gateway (but this is the long method).
Hope this be of some help/idea. Pls post back how things turned up or should you need further information.
Good luck and kind regards.
Posted on Nov 11, 2007
Setting up for use on laptop
ay6dz0yqzpfvaaaaaelftksuqmccconnect the cable on the yellow jack and the other end to your pc.
Oct 27, 2012 | Belkin N150 Enhanced Wireless Router...
It would seem that:
Nov 11, 2007 | Belkin (F5D7230-4) Router (587009)
I am connected to the internet but through the ethernet cable. The wireless on the modem isn't working. My laptop wireless is but i cant connect without my cable. Please help :)
Wireless light ont he modem would only lit up once a device had succesfully connected to it:
what is the operating system of your laptop?
you can also Try this links: complete walkthrough and screenshot is in the link... thanks...
changing wireless settings: http://support.2wire.com/?page=view&article=60
wireless configuration guide for windows XP: http://support.2wire.com/?page=view&article=224
wireless quick reference guide: http://support.2wire.com/?page=view&article=47
if your with AT&T try calling this number
AT&T ' Yahoo! High speed Internet
Call +1 877 722 3755 (877-SBC-DSL5)
Aug 08, 2011 | 2wire (2701HG-B) Wireless Router
Am i being thick? does each provider have their own type of router?? im trying to connect a d-link 615 using virgin, help please? havent got the disc for router and cant access 192.168.01 to download...
You need to connect your D-Link to a DSL or Cable modem. The ISP usually provides this modem and the configuration settings for the modem so you can connect to the Internet. To test your Internet connection connect a LAN cable from your computer to the modem and then open a browser. If you can coinnect to the Internet then you can then connect the D-Link to the modem and configure the D-Link for wireless settings so you can connect your computer/laptop to the Internet using a wireless connection.
Connect a LAN cable from the D-Link to your laptop/computer'sLAN port, open the browser on your laptop/computer and enter the D-Link'sconfiguration URL..
http://192.168.0.1
The default login = admin
The default PW = blank (just press Enter) You can now change the default password.
You can now configure the wireless settings. Now configure the wireless card in your computer/laptop withthe router's wireless settings.
To secure your wireless network from unauthorized access,please click on this link and follow my instructions :- http://www.fixya.com/support/r3559128-wireless_router_security
Aug 06, 2011 | Computers & Internet
DSL line disconnects on WRT54GS only
Try to change the LAN IP address of your router to 192.168.2.1 by accessing the router's Setup page. You also need to set your Westell modem to "full-bridge mode". You need to ask assistance from your ISP to bridge the modem. After that, set-up the Linksys router to PPPoE then power cycle it.
Apr 15, 2009 | Linksys Wireless-G WRT54G Router
Help with my wireless router
you have the internet on desktop pc and you want to connect your laptop right?
open control panel select network set up wizzard and follow instructions for shared network.
if you connect dsl to notebook you need to have installed modem device drivers and configured device and done basically everything you had to do on pc,by disconnecting dsl from pc obviosly youre gonna lose the internet.
get your self a wireless router if not already have one , that way you set up pc wired and link laptop via wireless
Jan 09, 2009 | Computers & Internet
Setup asistant will not work with Belkin wireless router & computer
Try the manual method.connect router to pc with ethernet cable
1.logon to 192.168.0.1
2.Connection type ; PPPOE
3.type in your [email protected] and pass
4.Save settings
5.Configure wireless setting(SSID,Wep)
Configure pc with the same SSID and WEP
uplug the ethernet cable and check if your are able t connect wireless
if you still have issue use this guide
Cheers !!!
Feb 23, 2008 | Belkin (F5D7230-4) Router (587009)
Can't get connected
try reset switch on back unplug it al then back in try again
Feb 04, 2008 | 2wire 2700HG-B Router (2700HGB)
Belkin (F5D7230-4) Router (587009) Logo
327 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Ekse
Jeffrey Groves
Jeffrey Groves
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
