Question about RCA RTD155 System
Connecting my Medion surround sound to my Sony dvd recorder
I have a Medion 5.1 surround sound system and I would like to connect it to my Sony DVD recorder. The sub woofer has five speaker cables coming in and six cables going but the DVD has only two possible audio connections. Is there any equipment that I can buy to connect them.
  • Anonymous Mar 12, 2014
    I am trying to connect my dvd projector to the tv and also the surround sound if possible please help.
Anonymous
U need an amplifier (5.1), u put the two outputs in, and then theres loads of outputs coming out of yer amp. hey presto, im doing the same thing at my uni flat, but i need the amp. peace out x
Posted on Jan 02, 2008
Testimonial: "Excellent help Thanks"
Can I add more speakers to my HT-J5500W Samsung sound system.
The HT-J5500W can only support a 5.1 speaker system. The main part of the entertainment system supports a direct connection with the front right, front left and center speakers and sub-woofer. The wireless receiver module connects the surround right and left speakers to the rest of the system.
You would need a different amplifier/receiver to switch to a 7.1 or other speaker system using more speakers. You may be able to upgrade the individual speakers, as long as you don't exceed the power output limits of the system. The original speakers are 165 W each (front and surround speakers) and 170 W for the center speaker and the sub-woofer.
I hope this helps.
Mar 04, 2018 | Samsung Audio Players & Recorders
How can i enable surround speaker and how can i connect speaker
Muhammad, you need to go to the function that provides surround sound, have a dvd that was recorded in 5.1, have all the speakers and the sub-woofer connected.
May 30, 2013 | Yamaha DVR-S150 DVD Player
I have a Fisher RS-909 Surrond Sound amplifier. It has no "sub out" jack. I had the sub-woofer working in the past by wiring it as shown in the manual. The problem is that the system was in...
Alright i had a chance to look over things, this is how you are going to hook up the sub. first we'll be connecting the surround sound unit to the sub woofer.
surround sound unit sub woofer
left front: positive (+) <-----to------------->(+) left speaker level in
negative ( - )<- - -to- - - - - - ->( - ) left speaker level in
right front: positive (+) <-----to------------->(+) right speaker level in
negative ( - )<- - -to- - - - - - >( - ) right speaker level in
now that the surround sound unit is connected to the sub woofer you will need to connect the front surround sound speakers to the sub woofer.
sub woofer front surround sound speaker
left speaker level out (+)<-----to--------> (+) left front speaker
left speaker level out( - ) <- - - to- - - - ->( - ) left front speaker
right speaker level out (+)<-----to--------> (+) right front speaker
right speaker level out( - ) <- - - to- - - ->( - ) right front speaker
Alright now that the wires are all over the place and plugged in
turn everything on and see how it sounds. let me know if everything is working as it should. if you need help with anything else or if something does not seem right please feel free to contact me via e-mail or phone
Mark Woodring
Feb 13, 2011 | Audio Players & Recorders
TV sound only thru front and sub woofer speakers only
this might be happening because the audio format for surround is not supported by the channel or affiliate of the channel that you are viewing does this happen on all tv channels or is it on just a few? if all sound while playing a dvd is proper and in working order than there must be an issue with the sound and or format of sound from the tv source. maybe more information would help me decipher this
anyways hope it helps
Ryan
Feb 14, 2009 | Sony BRAVIA® DAV-HDX576WF Theater System...
JVC TH-M45
no, u cant use the speakers with other normal DVD player because it wont have amplification for the speakers... u can use the sub to other dvd player because its inbuilt 120 watt woofer. ur dvd player is 5-disc player as wel as 120 X 2 and 80 X 3 watts amplifier (AV receiver ).... so just the JVC better sound thru the sub and speakers... ENJOY
[email protected]
www.kanny-sounds.blogspot.com
Jan 24, 2009 | Pioneer 1000 Watt 5.1 Surround Sound...
Sound comes only fron one rear speaker
Did you try switching Speakers A and Speakers B button on the AV receiver?
Jan 10, 2009 | Bose Acoustimass 10 III System
JVC THR1 DVD Digital home cinema system.
There is other Cinema Surround systems that use the same 8 Pin setup Aldis had one retailing at £49.99 and there are plenty on E-Bay www.eserviceinfo.com will provide schematics for these systems so you can select the right one.
Jul 17, 2008 | Audio Players & Recorders
Sound problems through subwoofer
check all speakers wires andcheck test mode. every thing ok, may be input wiring problem ,check every thing after that internalcircuit may be problem..
Oct 08, 2007 | Audio Players & Recorders
RCA RTD155 System Logo
425 people viewed this question
Top RCA Audio Players & Recorders Experts
ThaMp3Doctor
ThaMp3Doctor
Ekse
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
