Just bought used but no manual included. Worked great until I tried setting the right margin with the Code + Margin R key. Then it locked up at the right margin and motor whirs. Daisy wheel doesn't move. Tried hitting Code + all the different "coded" keys, but not successful. Please advise if someone knows Thanks.
SOURCE: SMITH CORONA KA 13 WORD SMITH
For a manual, try Google. Just put in "Smith Corona KA 13 WORD SMITH MANUAL'. If you can't find one there, then you are prabably out of luck. To change the margin simply go to the left margin, use the "backspace" or spacebar to position the print head where you want the margin set and then push the L MAR key. To change the right margin use the same procedure and hit the R MAR key.
SOURCE: smith corona xe6100 keys locked
there is a KB ON/KB OFF switch on the right side of the keyboard, it should be in the ON position
also on the left side the switch should be in the TYPE position
if that doesn't make it work, there is a problem with the main board or power supply that will need a visit to a repair shop
SOURCE: Smith Corona SL575 typewriter no longer does corrections.
Be sure that the correction tape is a dry type general ribbon # T355 or equivelent.
DickyO
SOURCE: Backspace key stopped working
SCM's have a problem with dirt getting on the keyboard contacts.
Take the T/W apart remove the metal bottom of the ketboard, wipe off the velum and key contacts with alcohol.
DickyO
SOURCE: Lost my manual for my Smith Corona SL600
Hi there.
Here is a freebie for you.
http://www.smithcorona.com/pdf/Office2000/Office2000Chap6.pdf
Take care,
Duane ONeil
www.FJAproducts.com
800-982-9989
