Question about Polder Hardware & Accessories
Setting clock how to set clock battery operated
2 Related Answers
Anonymous
  • 12 Answers
SOURCE: Unable to set clock and or operate
You can go too the manufactures web site and download the manual for free as long as the microwave is under warantee............
Posted on May 03, 2009
Anonymous
SOURCE: Gorenje B3350E
Briefly press the first two buttons simultaneously (the button that says Timer with a picture of a bell and button with a picture of a steaming pot). You should now be able to set the time with the jog dial. It automatically starts the time a few seconds after you release the jog dial.
I have a Kleenmaid TO400 in Australia and it's the same as the Gorenje B3350E. Thankfully I have the manual as this would be impossible to guess
Posted on Jul 31, 2009
Do cuckoo clocks need to be certified to be real?
There is a Black Forest Clock Association. They certify cuckoo clocks that are made from wood and made with parts produced in the Black Forest region and that meet the standards set by the association.
Feb 11, 2013 | Home
I HAVE A CLARION CAR CD RADIO db235 BUT NO MANUAL FOR IT AND I WANT TO SET CHANNELS AND THE CLOCK.
This should do it for the 235.. you have two different mode #'s listed for some reason.
Setting the Clock
1) Press and hold the BND button, and then press the DISP button to display the clock display.
2) Press and hold the BND button, and then press the DISP button for 2 seconds or longer.
3) Press the SRCH Up button, then set the current minute.
4) Press the SRCH Down button, then set the current hour.
5) Press the BND button, then the clock is set.
Notes:
• If you select another operation mode while you are setting the clock, the clock setting operation will be canceled.
• If you remove the vehicle's battery for a check or repair, the clock will be reset, so you must set it again.
Jan 26, 2011 | Clarion DRB4475
Emerson Smartset Clock Radio setting for everyday alarm
You will need to reset the Clock/Radio's microprocessor. To do this you must unplug the Clock/Radio and remove the internal battery (CR2430). Let the Clock/Radio set without any power source for at least 2 hours. Then put the internal battery back in the Clock/Radio and plug it in to the a/c outlet. Test to see if the Clock/Radio functions have returned to normal. If the function have not returned to normal, you will need to replace the internal battery. Then let the Clock/Radio again set with out power for a period of at least 2 hours. after a 2 hour period, put the new battery in the Clock/Radio and Plug it into the a/c outlet. Test the functions to see if the microprocessor has reset to normal operation. If you are still having a problem with the Clock/Radio's operations , you will have to give the Emerson customer support a call. The Telephone number for the Customer support is 1-800-898-9020. You can call them between the hours of 7am-5pm CT. Give them the make and model number of your Clock/Radio and ask them for assistance with your problem. I hope this information helps you fix the problem with the alarm in the Clock/Radio.
Jan 30, 2009 | Emerson Smartset Clock Radio
Clarion RDB245D - owners manual
This is from the 225 but should be the same:
Setting the Clock
1) Press and hold the BND button 0, and then
press the DISP button 9 to display the clock
display.
2) Press and hold the BND button 0, and then
press the DISP button 9 for 2 seconds or
longer.
3) Press the SRCH Up button ´, then set the
current hour.
4) Press the SRCH Down button ´, then set
the current minute.
5) Press the BND button 0, then the clock is
set.
Notes:
canceled.
If you remove the vehicle’s battery for a check or
Jul 27, 2008 | Clarion DB245 CD Player
Set time on clarion DB246
1. Press and hold the [BND] button, and then
press the [DISP] button to display the clock
display.
2. Press and hold the [BND] button, and then
press the [DISP] button for 2 seconds or
longer.
3. Press the [a] or [d] button to toggle
HOUR and MINUTE selection. Then turn the
[ROTARY] knob clockwise to increase hour /
minute or counterclockwise to decrease hour
/ minute.
4. Press the [BND] button, then clock is set.
Note:
will be canceled.
again.
http://www.clarion.com/sg/en/MungoBlobs/493/1008/DB246-AS.pdf
Apr 15, 2008 | Car Audio & Video
Don't know how to set the time/clock.
Setting the Clock
Before operating the unit any further, first set the clock built
in this unit.
• When the unit is turned on with CD or tuner selected, press
DISPLAY first to show the clock indication.
1 Press and hold PROGRAM/SET
for more than 2 seconds.
The hour digits start flashing on the
display.
2 Press 4 or ¢ to adjust
the hour, then press
PROGRAM/SET.
The minute digits start flashing on the
display.
3 Press 4 or ¢ to adjust
the minute, then press
PROGRAM/SET.
If there is a power failure
The clock loses the setting and is reset to “AM 12:00.” You need to
set the clock again. If the batteries are inserted in the unit, this has
no effect on the memory.
To show the clock when CD or tuner is selected
Press DISPLAY.
• Each time you press the button, the display changes the clock
indication and the normal indication alternately. (Operating the
unit while clock indication is displayed change the display to the
normal indication.)
Feb 04, 2008 | JVC 10 Watt CD Boombox with AM/FM, Dual...
For the Clock/Radios that are having problems with the clock display and settings. You will have to reset the Clock/Radio's microprocessor. To do this you must unplug the Clock/Radio from the wall outlet and remove the internal battery. You must let the Clock/Radio set with no power for at least 1 hour to discharge the microprocessor circuits. The microprocessor should then be able to reset itself. You can then reinsert the battery and plug the Clock/Radio into the a/c wall outlet. The functions should have reset and be working normally. If this does not solve the problem, try putting in a new battery (CR2430). Before putting in the new battery, unplug the clock radio and remove the old battery and let it set again for a few hours this time to try to reset the microprocessor. If this does not solve the problem (This includes the person with the complete Clock/Radio operation failure) you can call the Emerson customer support at this telephone number 1-800-898-9020. Give them the make and model number of the Clock/Radio. Tell them the problems you are having with the operation of the Clock/Radio and ask them for assistance. I hope this information helps you solve the problems your are having with your Clock/ Radios.
Dec 17, 2007 | Emerson Smartset Clock Radio
Alarm 1 won't go off when set to AM
Sorry it took so long to answer your question about the Clock/Radio. This look like a problem with the Clock/Radio's Microprocessor. You will need to reset the microprocessor by removing all power sources to the microprocessor. This means removing the Clock/Radio from the A/C power source and removing the internal battery (CR2430). After removing all the power sources from the Clock/Radio, let the Clock/Radio set for a period of about 3 hours. This will let the power completely drain from the microprocessor and reset it to the factory settings. You can then reinsert the internal battery and plug the Clock/Radio into the A/C power source. The Clock/Radio should have reset and the functions returned to normal operations. If The Clock/Radio functions have not returned to normal. You will need to let the Clock/Radio's microprocessor drain off the power again and put a new internal battery (CR2430). Then test the Clock/Radio's functions again. The Clock/Radio functions should have returned to normal operation. If you are still having problems getting the Clock/Radio to return to normal operation. You can call the Emerson customer support at this telephone number 1-800-909-1240- Call them between the hours of 8am to 4:30pm central time USA. Give them the make and model number of your Clock/Radio and ask them for their assistance. I hope this information helps you with your problem. Thank you for using FixYa and have a nice day!
Nov 19, 2007 | Emerson Smartset Clock Radio
Hardware & Accessories Logo
29 people viewed this question
Top Polder Hardware & Accessories Experts
Gene Haynes
Terry
Terry
Attique-ur-Rehman
Attique-ur-Rehman
Are you a Polder Hardware and Accessory Expert? Answer questions, earn points and help others
