Question about Soyo DYLT032D 32 in. LCD Television
No picture on TV
There is no picture but power when turned on
Tv tunrns on then goes to stand by flashes 4 times & repeats
turn tv on picture comes up 2to3 seconds later tv blacks out then stand by red light flashes 4 times in a row repeatedly..can not turn on or off when stand by light starts flashing but before tv blacks out you can turn tv on and off repeatedly and picture and sound work.You have to unplug power cord for 30 seconds after stand by light comes on to get tv to turn on.
Mar 13, 2009 | Sony BRAVIA KDL-32S2000 32 in. LCD HDTV
I went turn on my tv the picture came on then off
Picture turned Yellow because the Blue CRT stopped working. Power turns off because the power supply is indicating a fault. you probably lost your HT (high tension [voltage]) power supply on the blue CRT (picture tube). Professional assistance is recommended. HT power supply CAN DELIVER A LETHAL SHOCK even when the set is unplugged.
Jan 15, 2009 | Philips 46PP9302 46" Rear Projection...
Only vizio light come on then nothing. have to unplug to turn off
there a problem on power side.. chage the ic and the resistor going to ic and check also the signal diode.
Dec 30, 2008 | Vizio L32 32 in. LCD HDTV
TV won't "talk" with satellite cable
Try to see if you have 5volts for your EEPROM. If the voltage is normal try to replace your EEPROM or try to reprogram it. Your EEPROM is corrupted so that's why it will not store data.
Dec 01, 2008 | Sony KV-35S42 35" TV
No picture, but power light is on
THE POWER SUPPLY OF YOUR TV WAS THE PROBLEM,YOU COLD SOLDER THE MAINBOARD OF YOUR TV,AND THE CRT SOCKET CONNECT TO THE TUBE IS ALSO COLDSOLDER,.
Mar 13, 2008 | RCA 27F530T 27" TV
Turning on TV
It could be because you've got dry solder points on your tv's board, try resoldering the dry points.
Feb 02, 2008 | Philips 27PT5445 27" TV
Turn on power, but no picture, when you turn off power see picture for a few seconds before tv shuts off
did you ever get your problem fixed? i have the same problem and its frrustrating. i fyou can help me please email me at [email protected].
Thanks.
Dec 26, 2007 | Philips 50P8341 50" Rear Projection...
The picture on my tv is fuzzy
Check your connections Inm the Back of your Tv and Also see If your VCR got turned on By Mistake....
Jul 18, 2007 | Insignia IS 20" TV040919 TV
Soyo DYLT032D 32 in. LCD Television Logo
48 people viewed this question
Top Soyo Televison & Video Experts
Marvin
Marvin
Vish Iyer
Vish Iyer
Are you a Soyo Televison and Video Expert? Answer questions, earn points and help others
