Question about Philips Magnavox MWR10D6 DVD Recorder
Only recording static
Cannot see picture on aux channel only static
I have a security camera outside that runs to tv with rca cables. i want to record to a vcr which is connected to tv by coax. i cant get it to record the camera picture. can u help?
The coax connection is one-way RF only from the VCR to the TV. It cannot be used to record from TV to VCR.
Run the RCA cables to the Line or Aux input on the VCR first. Watch on the TV through the coax connection to the TV. You can watch even when not recording the camera signal on the VCR by setting the output of the VCR to Line instead of a channel.
Another option would be to connect a component (RCA) output from the TV (if there is one) to the VCR Line or Aux input.
Dec 16, 2009 | Office Equipment & Supplies
I cant get my record deck to work on my technics sh-dv290 from the aux why
Is the aux imput for tape or cd only? Or is it a dedicated phono imput?
If it is for tape or CD only it won't work has the cartridge from the deck needs a magnetic pre-amp.
If the amp doesn't have a phono imput you can get a pre-amp for cartridges from your local electrical shop. This will plug into your deck and then into the socket of the amp.
If the aux on your amp is a phono socket, assuming the record deck is working, then the pre-amp (inside your amp) for the cartridge has failed. It generally is located near the imput socket, chances are it will be single IC. It's a fair bet the IC will have failed, they tend to be static sensitive types prone to fail at the drop of a hat!
Oct 19, 2009 | Technics SUV500 2-Channel Amplifier
Need the remote code for a phillips dvd player
These are the codes printed in the owners manual for your dvd/vcr player.If they do not work you will have to contact Emerson and ask them for help getting the code. The contact number should have come with the instructions for the remote. Just give them the model number of you remote and the units model number and they should be able to help you. I hope this information helps you with your problem. Switch the input selector on your TV to an appropriate external input channel (usually near channel 0).
Press a button on the TV’s original remote control that selects an external input channel until the DVD
recorder’s picture appears. Check your TV owner’s manual for details.
Admiral
Curtis Mathis
GE
Hitachi
JVC
Kenwood
LXI-Series
Magnavox
AUX
LINE1, LINE2, 00, 90, 91, 92, 93
INPUT, TV/VCR, 00, 90, 91, 92, 93
INPUT, AUX
VIDEO, VIDEO 1, VIDEO 2, VIDEO 3
AUX
00
AUX CHANNEL
Input Mode Names for Common TV Brands (Example)
Panasonic
RCA
Samsung
Sanyo
Sharp
Sony
Toshiba
Zenith
TV/VIDEO
TV/VIDEO
VIDEO
00
VIDEO1, VIDEO2, VIDEO3
TV/GAME
00
Apr 25, 2009 | Philips Magnavox MWR20V6 DVD Recorder/VCR
Sv2000 dvd recorder only
go into setup set input to ch 3
Nov 01, 2008 | Funai TruTech DVDVCR Dual Recorder
Sound interuptions with Samsung S4253
My set started having sound issues recently. Every now and then, randomly, I get a split second, static sound. It sounds like an old record player when it skips. It happens on all channels HD and digital. Also happens when I'm watching a DVD. This leads me to think that it's not my cable box (Dish Network). I have a Bose 321 aux amp plugged in. I hear it through my aux speakers, as well as directly through the tv set. Not sure what to do. Is it possible my tv's amp is burning out? What could be causing this?
Mar 28, 2008 | Samsung SPN4235 42 in. Plasma HDTV
Vcr recording
if there is a cable box hooked up to this vcr, the vcr needs to stay on channel 3 to record.the output of the vcr either hooks up to the tv from the coax out , or from one of the other possible outputs such as rca cables [red, white, yellow] to one of the tv's aux/video/line in or source inputs.
wg
Feb 05, 2008 | Televison & Video
Magnavox MWR10D6 can't record from camcorder wrong channel
OK...try this...plug your RCA cables from your camcorder into the RCA input jacks on the back of the recorder. If you have a VCR, it can be plugged into the coax input on the back of the recorder. Use the coax output and plug it into a RF modulator (about $20 at Wal Mart). Plug the RCA output cables from the recorder into the RF modulator as well (Don't ask me why, but it seems to work on mine). Connect a coax cable from the RF modulator to the TV. Make sure the TV and Recorder are both on the right channel. The RF modulator will have a channel switch to use channel 3 or 4 on the TV. Make sure the recorder is set to E1 (Rear). You can check this with the channel +/- buttons on the bottom right of the remote. Good luck.
Jan 06, 2008 | Philips Magnavox MWR10D6 DVD Recorder
Linking to a dvd recorder
Connect your camera to the DVD using 3 prong RCA cable.
The DVD recorder has 3 composit (RCA) inputs. the input names are also the channels names therefor:
Front panel input: F-1
Rear panel Aux-1: L-1
Rear panel Aux-2: L-2
Jan 04, 2008 | JVC Everio GZ-MG130 Camcorder
I am having trouble channel setting and recording.
If you have a bad or fuzzy picture when viewing tapes on VCR then you need a new video drum. I think you can buy another that is for your brand on the internet. More VCR Repair -
http://www.videouniversity.com/vcrfirst.htm
Oct 03, 2007 | Aiwa HV-MX100 VHS VCR
Poor picture quality and sound problems on Lite-on LVW 5115GHC
have you tryed replaceing scart leads plus check if there in a priority order 2 like going form dvd 2 tv then tv 2 sat recever try going via sat recever then dvd then you tv if that dose not seem 2 solve you problen it might seen you might have dry solder point inside you dvd unit if so take bk where you buy it from and explane to then wat is happening hope helped
Aug 05, 2007 | Lite On LVW-5115GHC+ DVD Recorder
Philips Magnavox MWR10D6 DVD Recorder Logo
Top Philips Televison & Video Experts
Demonic-2011
Demonic-2011
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
