Question about Panasonic PT-AE700U Multimedia Projector
Multimedia hdmi problem - Panasonic PT-AE700U Multimedia Projector
Does hdmi to m1 include audio?
Audio is carried over HDMI, make sure the sound control panel specifies the HDMI port as the sound output.
Mar 15, 2014 | Dell 3200MP Multimedia Projector
What lead should purchase
To buy a HDMI-VGA adaptor (a adaptor adjust HDMI to VGA)
Feb 15, 2014 | Toshiba TLP-ET1 Multimedia Projector
What lead to use?
to buy a HDMI-VGA adaptor (a adaptor adjust HDMI to VGA)
Have a good day!
We supply original projector parts: lamp, bulb, Lcd panel, Lens, DMD chip,color wheel,
motherboard, powersupply ... with high quality and competitive price.
Jerry China Lampdeng Limited
Tel: +86 131788 67858
E-mail: [email protected]
Skype: lampdeng.com
YM: [email protected]
http://facebook.com/lampdeng
http://www.lampdeng.com
Nec MT1060 blue screen when connected to a Hdmi source thru dvi port.Dvi setting to match Hdmi resolution.tried different cables and dvi to Hdmi adapters....any ideas..??
Hi Genaro,
Sounds like an issue with the HDMI HDCP content protection. I do not think it will be possible to connect using a DVI to HDMI cable.
Jan 19, 2014 | NEC MT1060 Multimedia Projector
Hdmi input issue - screen goes black after 20 minutes of use
Could be a defective HDMI processor word of warning to everyone never under any circumstances must you connect up any device with HDMI ability whilst they are switched on as static can and indeed does smack out the HDMI processor and can and does work out expensive in time to replace.
john
www.jvsvisual.com
Apr 16, 2013 | InFocus IN72 Multimedia Projector
Can i set up an xbox 360 on an hp mp3135 multimedia projector
if your xbox has the hdmi port, you need a hdmi to m1 cable. otherwise, you'd need the hd av to m1 cable. there is no vga port on the projector.
Aug 18, 2009 | HP mp3135 Multimedia Projector
Mitsu x400bu gives coprright indication when i go from hdmi todvi
Firmware update, yes or use component video. HDMI has embedded copy protect and is really an aggravating connection. Consider this, hdmi's benefit is embedded audio, your projector does not need this. Component video will meet you needs because the projector is not real high on res. Good luck
Mar 24, 2009 | NEC Mitsubishi LVP X400BU Multimedia...
Panasonic PT-AE700U Multimedia Projector Logo
24 people viewed this question
Top Panasonic Office Equipment & Supplies Experts
CheckitRight
CheckitRight
Norman  J Weimar Jr
Norman J Weimar Jr
Shannon Murphy
Level 1 Expert
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
