Question about Sony Handycam DCR-HC42 Mini DV Digital Camcorder
4-5 Grey Lines appearing in the Playback Mode when playing tape
I notice 4-5 Grey Lines appearing in the Playback Mode when playing tape spaced equally horizantally in the initial 10 mins of the Playback mode. After that the lines slowly vanishes in the form of small square color boxes and the vision is clear.
Posted by palsanjit on
  • 1 more comment
  • whipple Nov 01, 2007
    I have the same problem. Have seen other boards on the internet where people say they have the same problem, but nobody replies with an answer. I really don't want to call tech support and deal with someone from india asking me a thousand questions before they can help.
  • throwbax Jan 21, 2008
    I have the same problem with a sony trv22 mini dv handycam, sometimes it goes away so times it doesn't,.. I noticed it when the camera itself is cold, I might try to take it in to a sony store and have it cleaned.
    Let me know if anyone else has a better solution??
    Thank You
  • Anonymous Mar 30, 2014
    grey lines in playback but ok in another camcorder
Anonymous
I have the same problem happening and can't find a straight answer. Some posts are leading me to believe that it may be dirty heads, and that the camera needs cleaning.
Posted on Dec 08, 2007
Sony how to change the bass on my sony mex bt3100u stereo
Hello Tom,
You may have to adjust the EQ7 Preset to XPLOD and then listen to the jam. Here are the instructions from the bt3100u manual:
Selecting the sound quality
- EQ7 Preset
You can select an equalizer curve from 7 equalizer curves ("XPLOD," "VOCAL," "EDGE," "CRUISE," "SPACE," "GRAVITY," "CUSTOM" or "OFF").
1 During reception/playback, press the select button.
2 Rotate the control dial until "EQ7 PRESET" appears, then press it.
3 Rotate the control dial until the desired equalizer curve appears, then press it.
4 Press (BACK).
The display returns to normal reception/play mode. To cancel the equalizer curve, repeat the first 2 steps then select "OFF" in step 3.
Tip
The equalizer curve setting can be memorized for each source.
We hope that this helps. If not please return and post how this went.
Nov 24, 2013 | Computers & Internet
Grey lines during playback.
Camcorder video head required cleaning because gray lines come in playback when video head got clogged/ dirty.
Put video head cleaning tape and playback it as per instructions.
hope this will help you.
Thanks.
Apr 03, 2010 | Sony DCR-HC38 Mini DV Digital Camcorder
Horizontal grey lines on tape playback
please state the age of your devices. It can help a great lot in solving your problems. The lines that you get aren't continuous, are they? They appear to be going up and down, are different sizes and shift as the tape plays, yes? well, this is simple. You need to clean your recording head.
Sep 23, 2009 | Canon ZR200 Mini DV Digital Camcorder
Grey lines across video display
pls rate me WELL if i have helped u !
Regards
Zohail
May 20, 2009 | Canon ZR200 Mini DV Digital Camcorder
Canon zr200
The heads are dirty, purchase a soft head cleaning tape and run it for 25 secs.
Dec 26, 2008 | Canon ZR-950 Mini DV Camcorder
Lines through the playback
Someone here recommended on another post to put the lense cap on & videotape the blackness in a quiet room for 5-10 mins. I tried this as a last resort & it worked. When I played back the tape, no more skipping or gray lines. I had 4-5 SOLID gray lines with skipping video & audio in between on every tape I put in. The person who helped me solve this said: "the speed isn't linked with the last time you recorded on it. Frames have an A/B part to them. If A is hitting B instead of A, a line appears. I would try the head cleaner first, then blacken your used tape (keep lens cap on and record in a quiet room) and try that."
My camera is a Canon zr80 digital camcorder. (Called Canon, they had me reset it & then recommended sending it in).
Oct 22, 2008 | Canon ZR100 Mini DV Digital Camcorder
Horizontal lines on playback screen
Someone here recommended on another post to put the lense cap on & videotape the blackness in a quiet room for 5-10 mins. I tried this as a last resort & it worked. When I played back the tape, no more skipping or gray lines. I had 4-5 SOLID gray lines with skipping video & audio in between on every tape I put in. I think the person who helped me solve this said that it was a result of the tape alignment going off. My camera is a Canon zr80 digital camcorder. (Called Canon, they had me reset it & then recommended sending it in).
Nov 15, 2007 | Canon ZR100 Mini DV Digital Camcorder
Lost LCD Screen
You MAY just have a dirty playback head. Purchase a head cleaning tape (Bestbuy, Target, etc., for about $20) and try cleaning your playback head. Colored lines is ONE symptom of a dirty head. A blue screen is ANOTHER. I had that symptom yesterday (9/7/07), got a cleaning tape and solved the problem. I can now again see on the LCD display what I recorded on the tape. Good luck.
Aug 21, 2007 | Samsung SC-D363 Mini DV Digital Camcorder
Will not playback tapes
a sony cleaning cassette may clear the gunk from your friend ' s possibly ? bad tapes ( do not rewind it - or the gunk will be redeposited ) ; if still no video , get an estimate to have your heads and guides cleaned . . . professionally ;
Jul 02, 2007 | Sony Handycam CCDTRV118 Camcorder
Lcd problem
Sounds like you have either a problem with the CCD block or on the mainboard where the encode/decode section is. If it is the CCD block it is defective or you have a loose or dirty connection on the ribbon cable from the CCD block. In record mode you are seeing the video E/E, which means you are looking at the video from the CCD block which has passed through the mainboard. That would explain the lines on the viewfinder. When you playback a tape you are looking at the recorded signal, but it also passes through the mainboard. It is not clear whether the tapes you are talking about playing were pre-recorded previously (prior to this problem) and played previously, with no lines present. If they were recorde previously, played back previously with no lines, and not re-recorded. They should be OK provided the problem is not tape damage. Since you say that all tapes do it, I would think it is not tape damage. The best place to start, to sort out the problem, would be to locate a known good camcorder and try your tapes in it. If they play fine the problem is on the mainboard but after the record circuitry, ie. only in the playback circuitry. If they have the lines the problem could still be on the mainboard but also could be the CCD issue I talked about. This is a tough problem to isolate and will take a good repair tech. If you are not familiar with troubleshooting camcorders you will need to locate a reputable and experienced repair facility. First you should do the test I mentioned on a known good camcorder as this will help a repair tech make a diagnosis. If there are no repair shops in your area here are several which offer free estimates: http://www.camcorderrepair.com or http://www.videotech.com or http://www.videoonerepair.com Good luck.
Jul 25, 2006 | Samsung VP-D103i Mini DV Digital Camcorder
Sony Handycam DCR-HC42 Mini DV Digital Camcorder Logo
657 people viewed this question
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Al Rush
Ekse
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
