Question about Sony Ericsson Walkman® W880i Cellular Phone
Wont charge i lost my phone charger but have my usb lead but cant turn my phone on to charge it ay ideas?
Anonymous
Hey,
i've solved your problem
type this in, don't worry about the menu's you will be bringing
up.
right * left left * left *
go into "service settings"
it will say "charging off"
select this and it will change to "charging on"
and will charge from your usb lead :-)
talk soon
xx jamie
Posted on Nov 08, 2007
Anonymous
Hey,
i've solved your problem :D
right, *, left, left, *, left, *
type that in and it will bring up a menu,
don't worry about what other menu's you go into
go to service settings
and select to "charging on" and it will charge from your pc :)
xx jamie
Can't find my charge adapter for my Jazz HD 188. Will it charge by plugging into the USB port of my PC?
Some phones charge the battery in the camera like a phone, but many do not. This camera has a USB connection, which is meant to be used to transfer photos from the camera to a computer. If your (now lost) charger was plugged into the camera to charge it, and it plugged into the USB connector, then you can charge the camera with any lead that will fit the USB connector, as this will have a standard voltage. You can even charge it from the computer, without buying a separate charger.
However, if your charger charged the batteries outside the phone, by removing them from the phone and placing them in the charger, then it is very unlikely that they will charge in the phone, whatever you connect to it. I have a camera just like this, that requires an external charger.
Oct 30, 2010 | Jazz HDV-188 Camcorder
Lost power charger will a telephone charger with the right dc voltage work? jazz hdv188 also its a usb jack in camera instead of the little round holed one
Some phones charge the battery in the camera like a phone, but many do not. The USB connection is meant to be used to transfer photos from the camera to a computer. If your (now lost) charger was plugged into the camera to charge it, and it plugged into the USB connector, then you can charge the camera with any lead that will fit the USB connector, as this will have a standard voltage. You can even charge it from the computer, without buying a separate charger.
Oct 29, 2010 | Cameras
My camera needs to be charged and i have lost the battery charger. so i put my camera on the usb cord and into the computer and tried to turn it on but it wont work.
You don't say what model camera it is, so I am going to have to do some guessing. If your battery charger normally charges the battery in the camera, then it probably will charge when connected to the computer by the USB lead. However, some cameras require the battery to be taken out and charged in an external charger. If that is the case with yours, then it probably won't charge by connecting to the computer.
It is normal for a camera connected to a computer via the USB lead to go into a kind of passive mode, just acting as an external disk drive so that files can be transferred, so not being able to turn the camera on while it is so connected might be normal. However, if you mean that you left it connected for awhile to charge up, but it wouldn't turn on after you disconnected it, then it is obvious that it cannot be charged up that way.
Oct 20, 2010 | Sanyo Cameras
My samsung SGH-J700 wont turn on or charge
Time to get the ribbon cable changed. You can do this yourself with some patience after buying the cable over ebay or get it replaced at a service centre for a very cheap price.
Jul 27, 2009 | Samsung SGH-E900 Cellular Phone
I cant get my mda to turn on i hold down the power button for a while but it wont turn on i charged it for 3 days and it still wont work what should i do?
Mda Vario's don't charge when turned off, heres what you do.
cut wire off a usb lead the small end strip the red and black wires, put the red wire onto the posative connection where the battery is it tells you what side is posative and negative on the battery, use black with negative and red with posative making sure that no wires touch the other metal strips in the phone, replace battery plug usb into computer and start up the mda and wait for it to boot. once turned on leave to charge as it will charge through the wires connected to the battery, after 10 to 15 minutes plug in the actuall charger and try to remove usb wires without taking battery out. if that is not possable it is ok as the battery should have enough power to start up once it starts leave to charge and always keep some charge in the phone.
Jul 07, 2009 | T-Mobile MDA
L7 unable to charge
All cellphone run on Lithium Ion batteries. These batteries, by nature(physics) have a max charged voltage of 3.4 to 4VDC. So, of your charger, or USB cable, has less than about 5 VDC, then either charger is defective, USB cable(if charging from PC USB port) is not a FULL USB(has data leads only wire, 5V power wire not carried through, PC does not supply 5V power to USB because it is turned off by a PC setting option, or a non-powering USB Hub or other device is in series with PC and Phone.
Are you sure you have identified the GND wire correctly? Measurements must all be made with one lead of your VoltMeter referenced to GND. Another consideration, some Windows Mobile phones will not charge off the USB cable unless the latest version of WM ActiveSync or Mobile Device software is loaded and running on the PC. These WM phones also will not charge from just any AC USB generic charger. Charger has to be for that particular phone, or phone manufacture, to be 'recognized' before provideing charge.
The
Feb 20, 2009 | Motorola Mobility V710
USB cable won't charge
Could be a borker charger port. Thats what I have.
Dec 07, 2008 | Samsung SCH-u740 Cellular Phone
V3 battery
you need to get a proper battery
Dec 30, 2007 | Motorola Mobility RAZR V3
Chaging my phone
hey,
up.
talk soon
xx jamie
Oct 30, 2007 | Sony Ericsson Walkman® W880i Cellular...
Sony Ericsson Walkman® W880i Cellular Phone Logo
Top Sony Ericsson Cell Phones Experts
Ekse
Zaid Anarwala
Zaid Anarwala
Marvin
Marvin
Are you a Sony Ericsson Cell Phone Expert? Answer questions, earn points and help others
