Question about Chevrolet 1996 Chevrolet Blazer S10/jimmy S15 Radio
Trans gets stuck where it only has 2nd 3rd no od or 1rst gear
Tranny shifts great till warmed up .. then it goes to limp mode .changed seliniods . what now?
Posted by chuck thompson on
Larry Blais
    Legend:
    An expert who has written 200 answers of more than 400 characters.
  • 331 Answers
Do you have a code reader? If there is a message informing you that the transmission is in limp mode. You should be able to retrieve engine codes. From your symptoms I think that you either have an issue with fluid flow (clogged filter and/or screens), worn pump, low trani fluid level, trani fluid temp, possibly a correlation problem with the speed sensors, clogged air filter, dirty MAF sensor, clogged fuel filter, or blockage in the exhaust system. It will only be through diagnostics that these suggestions can be crossed out and narrowed down. Please let me know if that helps or if I can be of any more assistance, good luck.
Posted on Mar 17, 2014
Testimonial: "no it is none of what u said ... it must be ether remote start or i hear gm had service bullitin out and a kit to rewire something"
Transmision starts out in 1st shifts to 2nd then third but will not shift into overdrive , but once it reaches 3rd gear ,it stays there when you come to a stop . after that it will only shift manually...
Sounds like your transmission is in limp mode. This is a fault mode in which the transmission either loses electrical power or the PCM deactivates all of the electronics. The transmission will default to max line pressure. The driver will have Reverse and 3rd, with manual 2nd available by putting the gearshift in 2 or 1 (doesn't matter). 1st, 4th, and TCC lockup will not be available. It will not hurt the car to drive it like this for short periods, but use manual 2nd to get the car moving, and be aware that the trans will generate more heat than normal while operating in limp-home mode due to increased torque converter slippage during 2nd gear starts and no lockup in 3rd gear.
The other from what you described, trans shifts 2nd to 3rd by itself in D or OD and locks the converter : ShiftA solenoid failed. Easy fix in the pan. Or a wiring problem from PCM to trans.. or PCM.
Thank you for using fixya and have your Safari scanned for the DTC codes that would indicate what issues your transmission is having to put you in to limp mode.
Sep 21, 2010 | 1994 GMC Safari
1996 gmc jimmy will not shift to 3rd gear
Hi, It may be in LIMP mode.
What is "limp-home mode" ? This is a fault mode in which the transmission either loses electrical power or the PCM deactivates all of the electronics. The transmission will default to max line pressure. The driver will have Reverse and 3rd, with manual 2nd available by putting the gearshift in 2 or 1 (doesn't matter). 1st, 4th, and TCC lockup will not be available. It will not hurt the car to drive it like this for short periods, but use manual 2nd to get the car moving, and be aware that the trans will generate more heat than normal while operating in limp-home mode due to increased torque converter slippage during 2nd gear starts and no lockup in 3rd gear.
Common failures on 4L60E, symptom any possible repair:
Trans shifts into gear harshly, car feels sluggish off the line, No 1st, 4th or TCC lockup available, Manual 2nd, 3rd and Reverse are only available gears, CEL is on: Transmission is either in limp-home mode or has lost electrical power. If there are lots of error codes in the PCM, check the under-hood fuse that powers the transmission, and if it pops again, look for a short in that circuit like an O2 sensor harness touching exhaust. Otherwise, check PCM codes for a particular fault in the transmission causing the PCM to put it in limp-home mode.
No 1st or 4th available; trans shifts 2nd to 3rd by itself in D or OD and locks the converter :ShiftA solenoid failed. Easy fix in the pan. Or a wiring problem from PCM to trans.. or PCM.
Car goes into gear but feels very sluggish like the brakes are dragging, but it will roll easily (starts out in 4th gear), you manually shift to 2 to get it moving, once it's moving you put it back in OD and the car shifts 3rd to 4th on its own and locks the converter at the appropriate time: ShiftB solenoid failed: Easy fix in the pan. Or a wiring problem from PCM to trans.. or PCM.
Trans seems noisy when moving in 1st and Reverse, noise goes away instantly if you shift to N or the trans goes into 3rd gear: Reaction planetary is worn out due to high miles or insufficient lubrication. Not a critical failure, but not a good sign either. R&R sooner rather than later.
3rd gear starts, can manually shift through all gears. When car has been turned off for a bit, then back on it will run normally.: VSS dropoff w/ Hi-stall converter. The rpms are too high, but VSS is showing no movement. Happens after a tire burning take-off. Doesn't store a code, will not throw a CEL (I've heard that it will store a code if it happens 3 or more times). Cure: Reprogram PCM for VSS dropoff -- PCMforLess knows about it.
If you can get the Jimmy for no more then $500.00 and the engine sounds good and body is good, you may want to invest in the repair of the jimmy. Also note that to have a close look at the fuel line along the frame on the drivers side just by the back doors, the line is know to corroded there on all the SUV's
Sep 19, 2010 | 1996 GMC Jimmy
Transmission will not shift into high gear
Before guessing at transmission problems, check the fluid level (car warmed up, engine running in Park on level ground) and have the PCM scanned for trouble codes FIRST. This guide is meant for problems that do not show up as PCM codes (like shift A&B solenoid failures, for example).
Also note that many problems that show up as transmission issues are actually PCM or electrical, and may be external to the transmission. Try a different PCM, and check for chafing where the cables come out of the PCM.
No 1st or 4th available; trans shifts 2nd to 3rd by itself in D or OD and locks the converter : ShiftA solenoid failed. Easy fix in the pan. Or a wiring problem from PCM to trans.. or PCM.
Trans shifts into gear harshly, car feels sluggish off the line, No 1st, 4th or TCC lockup available, Manual 2nd, 3rd and Reverse are only available gears, CEL is on: Transmision is either in limp-home mode or has lost electrical power. If there are lots of error codes in the PCM, check the underhood fuse that powers the transmission, and if it pops again, look for a short in that circuit like an O2 sensor harness touching exhaust. Otherwise, check PCM codes for a particular fault in the transmission causing the PCM to put it in limp-home mode.
Thank you for using fixya and good luck. Check all your fuses first to ensure it's not a simple as that before you take it to a transmission shop. Call around, most transmission shop will scan free of charge to inspect the condition of your transmission.
Apr 16, 2010 | 1998 Oldsmobile 88
My GMC has 311632 miles on it. I just changed the 4L60E transmission a few months ago and now it wont shift out of first unless I manually put it in second gear. all the gears from park rev. nuetral works...
The transmission may be in Limp mode. The transmission is on the same fuse as the MAF, O2 sensors and at least one other sensor - if an O2 shorts out, it will blow the fuse and the trans will go into limp-home mode. Be sure the trans has power and the fuse is not blown before doing anything else.
Trans does not upshift out of first, speedometer reads zero at all times: VSS failure. Easy fix on rear of transmission, but xmember must come out to access VSS.
Transmission does not shift automatically, only manually. Swap in a known-good PCM, check wiring, check other sensors such as VSS and TPS.
Here are just some of the common things you have described with the issues your transmission has. Good luck and keep me posted.
Dec 22, 2009 | 1994 GMC Sierra
Only runs in 1st and 2nd gear and reverse.
, No 1st, 4th or TCC lockup available, Manual 2nd, 3rd and Reverse are only available gears, CEL is on: Transmission is either in limp-home mode or has lost electrical power. If there are lots of error codes in the PCM, check the under hood fuse that powers the transmission, and if it pops again, look for a short in that circuit like an O2 sensor harness touching exhaust. Otherwise, check PCM codes for a particular fault in the transmission causing the PCM to put it in limp-home mode.
Dec 14, 2009 | 2006 Hummer H3
1996 gmc jimmy won`t shift from 1st to 2nd
IF the abs dash light is on and if the speedometer is sluggish or not working at all, it is probably a bad speed sensor on the transmission. and easy fix under $40 for the part. Mine was stuck in second gear for a while then worked then it stuck in first gear and i had the CHECK ENGINE light on.
Dec 03, 2009 | 1996 GMC Jimmy
Its 2 wheel drive, but the transmission won't shift unless you manuallyl put the gear shifter in low then work your way up to get the gears to change. The gears work fine it just won't change on its on. If...
Good luck and keep me posted, there are other things but these things mentioned seam like what you described.
Nov 19, 2009 | 1993 Isuzu Rodeo
4L 60E - 2001 k1500 will not shift into 3-4. Oil is not burn't and stifts great into1-2
  • No 3rd or 4th gear: “3-4” clutches are worn out. R&R. The car is safe to drive (in 2) until you can get it fixed.
  • Trans shifts into gear harshly, car feels sluggish off the line, No 1st, 4th or TCC lockup available, Manual 2nd, 3rd and Reverse are only available gears, CEL is on: Transmission is either in limp-home mode or has lost electrical power. If there are lots of error codes in the PCM, check the under hood fuse that powers the transmission, and if it pops again, look for a short in that circuit like an O2 sensor harness touching exhaust. Otherwise, check PCM codes for a particular fault in the transmission causing the PCM to put it in limp-home mode.
  • No 1st or 4th available; trans shifts 2nd to 3rd by itself in D or OD and locks the converter : Shift A solenoid failed. Easy fix in the pan. Or a wiring problem from PCM to trans.. or PCM.
Check to see if your transmission is in the limp mode, which would only give you 2nd, 3rd and reverse gears. No 1st or 4th gear.
Nov 19, 2009 | 2003 GMC Sierra 1500
Transmission in limp mode?
the neutral safty switch tells the comp. what gear is in. when its not working the light wont move and the car will not go threw the gears prop. the switch is nown to go out. it is located on the tranny or down under the shifter
Jan 05, 2009 | 1992 Honda Accord
Chevrolet 1996 Chevrolet Blazer S10/jimmy S15 Radio Logo
76 people viewed this question
Top Chevrolet Audio Players & Recorders Experts
Marvin
Marvin
Lawrence Oravetz
Glenn Smart
Glenn Smart
Are you a Chevrolet Audio Player and Recorder Expert? Answer questions, earn points and help others
