Goes to limp mode after vehicle gets warmed up
SOURCE: trans gets stuck where it only has 2nd 3rd no od or 1rst gear
Do you have a code reader? If there is a message informing you that the transmission is in limp mode. You should be able to retrieve engine codes. From your symptoms I think that you either have an issue with fluid flow (clogged filter and/or screens), worn pump, low trani fluid level, trani fluid temp, possibly a correlation problem with the speed sensors, clogged air filter, dirty MAF sensor, clogged fuel filter, or blockage in the exhaust system. It will only be through diagnostics that these suggestions can be crossed out and narrowed down. Please let me know if that helps or if I can be of any more assistance, good luck.
Testimonial: "no it is none of what u said ... it must be ether remote start or i hear gm had service bullitin out and a kit to rewire something"
