I do not have access to specific circuit diagrams for the ESP2 Singer Steam Press. However, I can provide some general information that may be helpful.
The ESP2 Singer Steam Press operates by using an electric heating element to heat a water reservoir, which produces steam to press clothes and fabrics. The electrical circuitry of the steam press includes a power switch, heating element, thermostat, thermal fuse, and indicator lights.
The power switch controls the flow of electricity to the steam press, allowing the user to turn it on and off. The heating element heats up the water in the reservoir, producing steam that is released through a pressing plate. The thermostat controls the temperature of the heating element, ensuring that the water is heated to the desired temperature. The thermal fuse acts as a safety device, preventing the steam press from overheating and potentially causing a fire. Finally, the indicator lights inform the user of the steam press's current operating status, such as whether it is heating up or ready to use.
If you're experiencing issues with your ESP2 Singer Steam Press, it's recommended that you consult the user manual or contact a qualified technician for assistance. Modifying or repairing electrical equipment without proper knowledge or training can be dangerous and may cause injury or damage to the equipment.
There are a few possible reasons why your AOSmith 1hp lift motor starts and then trips the breaker:
Overload: The motor may be overloaded and drawing too much current. Check the load on the motor and make sure it is within the motor's capacity.
Short Circuit: A short circuit could be causing the motor to draw too much current and trip the breaker. Check the wiring for any signs of damage or wear.
Faulty Motor: The motor itself could be faulty and causing the overload or short circuit. Check the motor windings for any signs of damage or wear.
Tripped Thermal Overload: The motor may have a thermal overload switch that shuts off the motor if it gets too hot. Check the motor for any signs of overheating and reset the thermal overload switch if necessary.
Faulty Breaker: The breaker itself could be faulty and tripping prematurely. Check the breaker for any signs of wear or damage.
It is recommended to consult a licensed electrician or motor technician to diagnose and fix the issue, as working with electricity can be dangerous if not done properly.
Hello Dom - Being that you have narrow down some
possibilities, here are a few simple troubleshooting tips that may help you get
to the root cause:
1.Make sure the dryer is plugged into outlet, and
plugged in correctly.
2.Is house fuse blown or circuit
breaker tripped? Replace fuse or re-set circuit breaker.
3.Make sure that electrical circuit is not
overloaded and correct. The dryer must be on a circuit by itself.
Overloaded circuits can damage the dryer and possibly cause damage to
home. I would recommend reaching out to a Licensed Electrician check to
make sure it is on a circuit by itself.
4.Thermal limiter tripped or an internal problem
with the dryer. A thermal limiter automatically turns off the motor (electric
dryers only) in the unlikely event of an overheated situation.A service technician must replace the thermal limiter after
correcting the fault.
If these assessment measures prove to be ineffective, I
would strongly suggest contacting an authorized service technician who would be
better able to assist you in the diagnosis and repair of your unit. You can
often locate an experienced technician in your area by going to the
manufacturer website.
If your H2O mop will not steam:
1. Ensure you have followed the operating instructions.
2. Ensure you have followed the troubleshooting instructions.
If the unit fails to produce steam:
3. Switch off the power at the outlet.
4. Look at the water reservoir. Inside you will see a flexible tube with a cone on the end. Tilt the unit or give it a gentle shake to submerge the cone in water.
5. With the cone submerged, switch on the power supply and follow the normal instructions. The unit should produce steam as normal.
Note: Unless the cone is submerged in water, the unit will not steam.
When it is blinking on steam it means it is preparing the unit for steam. When the steam light goes solid your unit is ready to make steam.
Turn from standby to steam then wait for steam light to go solid.
When solid steam wand will begin dribbling then spitting out water, which will then turn to steam.
When it begins to steam, turn back to standby. NOTE: you only have 6 seconds before steaming turns off.
place steaming wand in jug and turn from standby back to steam.
You will hear pumping noises when you turn off your steam, because it releases the steam and puts the excess water in to the drip tray.
make sure your bean hopper is properly locked in to the unit. Grinder won't work if hopper not locked in.
Make sure your water filter has been prepped and locked securely in to the reservoir and your reservoir is filled.
Use fresh beans.
Sounds funny but use good quality water, do not use ordinary tap water. Make sure it is filtered or use bottled water (cooler bottles).
Try to grind your beans to a good consistancy.
Breville recomends about 10kg tamping pressure, use a set of scales to check the feel.
Tamp to about 3-5 mm below rim of grouphead (portafilter). Or the tamp has a guide on the side, that silver side on the tamp is the tamp line. Pretty vauge about that in the book.
If all else fails go to www.breville.com.au and check your model and watch some of the vid clips.
Have you checked that the controls are not set to fan only? If you have lets go to the next step. All window A/C have thermal switch.. These thermal switch keeps the compressor from overheating. In the event that the compressor is overloading it would trip then click back on as the compressor cools down. Sometimes those switches go bad but the compressor is ok. They are mounted on the compressor themselves and accesable once the A/C unit cover has been opened.
May have a tripped thermal overload or blown fuse. Some overloads reset automatically but some will have a red button to reset it with. Some have to be replaced.
what room temp do you have there? what setting have you placed on your unit? what temp are you trying to reach from what start point. this unit is overheating and tripping out on thermal overload I suspect.
I had the same problem and the solution was to manually press the thermal overload button. The button is located under the tool box next the motor head. I do not believe I tripped the thermal overload during use, but I suppose anything is possible.I’ve been using the compressor in sub 40 deg F. temperatures.I found the following in the Owner’s Manual, but had to look at the part manual to locate the switch. MOTOR THERMAL OVERLOAD PROTECTOR: The electric motor has a manual thermal overload protector. If the motor overheats for any reason, the thermal overload protector will shut off the motor. Turn pressure switch to the “off” position and wait for unit to cool before pushing the reset button and restarting the compressor. Good Luck!
I know that Karchers steam cleaners have had issues with the thermal overload. I have repaired Karcher machines that got turned on with no to little water in the tank and it would heat up really fast and trip the thermal overload. The thermal overload is to reset it self when it cools down but the problem has been the thermal overloads get stuck and dont reset. When they stick, they will give the same signs you have said. In those cases the thermal overload has needed replaced. The thermal overload did its job to trip, but it fails when reseting. I understand you don't want to throw more money into it, but that is the only thing you can do. You can get the part and do it your self, but they are tricky machines to get into and you dont want to break something trying to get in. Hope this helped.
