Question about Vector Spotlight - 1 Million Candles Power, Model# VEC127Y
I need a charging cord, can you help me? - Vector Spotlight - 1 Million Candles Power, Model# VEC127Y
Posted by Paul Cranmore on
Hi im in desperate need for a replacement charge cord unit for my Norelco T-860 nay help will be most appreciated thanks Jerry
Hello. We have the cord you need on our website, www.shaveroutlet.com. Here is a link to the item.
http://shaveroutlet.com/universal-shaver-cord-coiled-for-most-models-p-268.html
Jan 02, 2015 | Norelco Health & Beauty
My apple iPhone4 will not charge and the battery is dead....bought new cord to charge but still will not charge up! Help please.....
Hi June, You need to take it to a repair shop, i would say the Power port is damaged that's why it's not charging
Mar 28, 2014 | Apple iPhone Smartphone
My charger is loose so I need a USB charger where can I buy one
try amazon if you are looking for just the cord.
Nov 10, 2013 | Tablets & eReaders
Why won't my Sony camera charge?
Not all cameras charge from the USB cord. Also there are some USB cords for data, some for charging.
Nov 04, 2017 | Sony Alpha DSLR-A230 Digital Camera
Have a Sunrise Aspire chair w/new batterie, charged by the repairman. Want to keep it charged regularly (not let it run down). DO I NEED TO TOTALLY DISCONNECT THE POWER HOOKUPS IN THE BACK when I...
You do not need to unplug the large 9 pin beau plug in the rear or the smaller 3 pin molex plug when you charge the chair. Do not unplug them or you will not charge the chair.
Use your charging cord as you describe "plug it into the front, plug it into the wall and charge, then unplug the charger cord and GO". Hope this helps.
Jan 05, 2011 | Quickie Wheelchairs Quickie Aspire Power...
My gateway netbook wont charge, they sent me a new battery but again it will not charge, what could be wrong?
The problem might be either from the charger or from the laptop.
To confirm and repair if it is the charger, all you have to do is to plug the charger on another laptop to see if it will charge, if it does not charge, then you know the fault is from the charger, and the solution is for you to replace it with a new one, before you replace it, try to connect another power cord to the charger, because sometimes the power cord might have been burnt, that have happened to me twice and replacing the power cord solved the problem. But if replacing the power cord does not help, then you need to change the power cord.
To confirm and repair if it is the laptop, plug in a new charger to the laptop, if it does not charge, then you need to understand that the charging port of the laptop is faulty and needs to be replaced, have a repairman replace the charging port for you.
Take care and good luck
Oct 31, 2010 | Gateway LT2021u Netbook
My vivitar camera is not getting charged.
1) Check that the battery is good It may have collapsed and need replacing.
2) try connecting with another cord to see if that is the problem.
3) take the battery and the cord to a camera outlesat to check integrity of both.
Please rate my help++++Thanks for using FIXYA
Mar 21, 2010 | Vivitar ViviCam 8025 Digital Camera
Mv acer aspire 3623WXCi turns off when i unplug the power cord with battery attached, is the battery dead and do i need a new one?
when you plug the power cord check and see if the battery shows that its charging ,if the charge level is low allow it to charge fully ,after its fully charged remove the power cord and see if it will go of again .if it goes off then you know the battery is dead if not it might be of low charge or not properly fixed.hope this helps
Sep 17, 2009 | Acer Aspire 3623WXCi (NBACERC1500XX1) PC...
Power
if it is not battery operated, then you have to charge it... what kind of cord did it come with?
if you have a cord that has a usb end then yes you can charge it using your computer.
If it cord has a different end then you need to purchase a charger.
If this is a new mp3 player you should charge it 12 hr.
Hope this helps
May 14, 2008 | GPX MW3837 MP3 Player
Vector Spotlight - 1 Million Candles Power, Model# VEC127Y Logo
59 people viewed this question
Top Vector Camping, Backpacking & Hiking Experts
Marvin
Marvin
Lawrence Oravetz
Vernon Taylor
Are you a Vector Camping, Backpacking and Hiking Expert? Answer questions, earn points and help others
