Question about Vector Spotlight - 1 Million Candles Power, Model# VEC127Y
I understand this model VEC127Y is no longer available, i need a cord to charge it. Can you help me?
Posted by Paul Cranmore on
I have a crosman ck92 I need some parts for but they are no longer available can anyone help me
is there some part of 'no longer available' you fail to understand ? if they aren't available, then, that is the answer.
Oct 09, 2018 | Crosman Air Mag C11 Airsoft Pistol
Braun 5705 will not charge, no lights, or run from power cord. This just occurred as it functioned fine and charged a month ago.
If you've never changed the batteries, the old batteries have probably damaged the circuit board from corrosion or heat. If cord is good and the lights do not work, it probably can not be repaired as circuit boards are no longer available for your model number
Apr 15, 2017 | Braun Health & Beauty
How have a bissell model 3512-9 i want to replace the cord
The Genuine cord for your model is no longer available. I have replacement cords that will work but you will need to use your old connectors and strain relief or buy new ones. Cords available at thatvacguy.com.
Feb 01, 2017 | Bissell Vacuums
I am wondering if I can buy a replacement cleaning stand and power cord for the Remington Titanium R 9500? I have the shaver but no stand or power cord and please may you send me the cost of it or where...
The cleaning and charging stand is no longer available for this model. However, you can charge this model directly from the charging cord. You will find this cord available at shaversource.com with free shippin in the US. See link below
http://shaversource.com/shaver-replacement-parts/remington-rotary-tct-ms32000-more-charging-cord-p-131.html
May 19, 2011 | Remington Titanium SmartSystem R-9500...
What tip polarity do I use to connect an after market charger?
The short answer is "The tip should be set to positive (+).
I found an old Vector VEC127Y Spotlight. It appeared to be in perfect condition but the battery was dead and there was no charger. I was able to buy a replacement battery at BatteriesPlus for $21 USD. Here is the link for the battery
REPLACEMENT VECTOR VEC127Y BATTERY
I also purchased a Universal A/C adapter to use as a charger at BatteriesPlus for $17 USD. Their site does not list it yet but here is the manufacturers link. Please note the original battery was rated 6Ah. The replacement is only rated for 5Ah. Which means one less Amp hour (Ah). Which means a shorter run time, after charging, than the original battery had. Otherwise they are equal.
UNIVERSAL AC ADAPTER
I installed the new battery. I set the AC Adapter to 6V and installed the largest of the seven adapter tips that came with the charger, with TIP set to be positive (+). I opened the battery compartment of the spotlight and disconnected both the red (positive +) and black (negative -) battery leads from the battery. I then plugged the adapter tip of the Universal AC Adapter into the spotlight and plugged the AC Adapter plug to a power outlet. With a multimeter I tested the polarity of the spotlight battery leads while charging. I was able to confirm that the Adapter TIP should be set to positive (+). After reconnecting the spotlight battery leads and setting the AC Adapter to charge, I have a perfectly great spotlight in full working order.
Dec 02, 2010 | Vector Spotlight - 1 Million Candles...
What volt and amp charger does the vec127y use
It uses a Class 2 Transformer to charge the battery. The input is 120V AC 60Hz 9W. Output is 12VDC 300Ma.
Nov 09, 2010 | Vector Spotlight - 1 Million Candles...
Vector Super Sport Spot VEC127Y replacement battery
I need a new power supply for my Vector Spotlight, Model VEC127Y. Any suggestions as to where one can be purchased?
John [email protected]
Nov 03, 2008 | Vector 2M Pwr Rch Spotlight
Vector Sport Spot 1,000,000 candle power spotlight
6 Volts, here is info from site.
VEC127Y
VECTOR SPORT SPOT 1 MILLION CANDLE POWER CORDLESS-RECHARGEABLE SPOTLIGHT
  • HIGH CANDLE POWER QUARTZ HALOGEN BULB DELIVERS A BRIGHT AND TIGHT BEAM
  • AREA WORKLIGHT IN HANDLE PROVIDES UP TO 15 HOURS OF LIGHT WHEN FULLY CHARGED
  • PROVIDES CONTINUOUS SPOTLIGHT USE FOR UP TO 25 MINUTES WHEN FULLY CHARGED
  • HIGH IMPACT, BREAK RESISTANT ABS AND POLYCARBONATE HOUSING
  • TOUGH, WEATHER RESISTANT AND BUILT FOR RUGGED OUTDOOR USE
  • REPLACEABLE 6 VOLT, 6 AMP HOUR, NON-SPILLABLE, SEALED BATTERY
  • LOCKING TRIGGER FOR ON/OFF LIGHT CONTROL
  • INCLUDES AC AND DC CHARGING ADAPTERS
  • INCLUDES BUILT IN HANDS FREE WORKSTAND
Sep 07, 2008 | Vector 2M Pwr Rch Spotlight
How do i charge a video mp3 player
Hello Shelby312,
The actual charge method and power adapters available can vary from manufacturer to manufacturer and model to model. I can't give you specific advice because you didn't post which MP3 player you are referring to. However, most MP3 players are charged by connecting them to the USB port on your computer using the supplied cord. Alternatively some MP3 players may have optional wall chargers or car chargers available which would enable you to keep the item charged when you don't have a computer available.
Hope this helps.
Ken
"Go Ahead. Use Us."
Jun 24, 2008 | Audio Players & Recorders
Waring DF200 Pro - Power Cord Needed
I have contacted Waring today and they state that the power cord is no longer available or manufactured. What a way to make you buy a new deep fryer. I love my DF200 and there is nothing wrong with it., just cant find a cord myself.
Aug 31, 2007 | Waring DF200 Deep Fryer
Vector Spotlight - 1 Million Candles Power, Model# VEC127Y Logo
54 people viewed this question
Top Vector Camping, Backpacking & Hiking Experts
Marvin
Marvin
Lawrence Oravetz
Vernon Taylor
Are you a Vector Camping, Backpacking and Hiking Expert? Answer questions, earn points and help others
