Refrigerators Logo
ThaiJen Nguyen Posted on Mar 16, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Ice maker not dispensing
Whirlpool ultraease 2 with the indoor ice/water dispenser. Awhile ago, the ice dispenser started to inconsistently not work. Sometimes, it seems like it was not detecting that I was pushing the cup arm in, which should start the ice dispensing. Subsequently, it did not work at all. Light indicators are working, and the water is coming out, but the ice does not seem to engage at all.. I don't hear any noise indicating that it's even trying to dispense ice. Anyone know what I should look at, and how to repair this? Thx.
  • John Tripp
    John Tripp Mar 19, 2014
    The model number of your refrigerator. Ultraease 2 is only the filtration system on you fridge.
John Tripp
Level 3:
  • Refrigerators Master 4,656 Answers
  • Posted on Mar 16, 2014
John Tripp
Level 3:
Answers
4656
Questions
Helped
1677638
Points
14883
This is possibly only a defective micro-switch on the Dispenser Module. Can you post the model number so I can examine the correct parts?
I am here should you need me, Thanks John Tripp Appliance 911
Contact Me Here
  • 1 more comment
  • ThaiJen Nguyen
    ThaiJen Nguyen Mar 17, 2014
    Trying to figure how to get to the dispenser module..will have that in a day or so.
  • ThaiJen Nguyen
    Are you looking for the part number of the actual dispenser motor? This would require me to take apart the motor assembly correct?
  • John Tripp
D Simon
Level 1:
New Friend:
  • Contributor 1 Answer
D Simon
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
279
Points
Have you checked inside the ice bin, if the ice froze together it will not dispense. If this is the case, lightly chisel it apart until the motor is able to spin and dispense. Remove as much of the "blocks" of ice as you can before trying to dispense
  • ThaiJen Nguyen
    yes. As mentioned, if it was frozen, i would still hear some sort of motor noise, but nothing. I also took out the ice bin, and still no sounds.
5 Related Answers
Anonymous
  • 878 Answers
  • Posted on Jul 24, 2006
SOURCE: Ice dispenser not working
Scorpio, remove the ice bin itself, dump the ice and see if you can move the bin auger by hand by turning the actuator in the rear. If the bin is ok, with the door open and the door switch held in see if the auger motor is turning when pressing the ice lever. If it's not turning the next logical step is to see whether the auger motor is getting voltage when calling for ice. Make sure the door switch is closed. The part number for the auger motor on the posted model is wr60x0202. Hope this gets you going..Catriver.
Anonymous
  • 32 Answers
  • Posted on Jul 04, 2007
SOURCE: Water Dispenser
GodofHops: The motor that you hear on the refrigerator is the water pump that carries the water to your dispenser. If no water is coming from the dispenser. You have to check 3 things: 1. If there's any water. 2. Water filter clogged. 3. Water line for dispenser clogged with minerales carried on water flow. SithPitt
Anonymous
  • 331 Answers
  • Posted on Sep 25, 2007
SOURCE: GE GSH22JFRE WW not dispensing ice
Deb, sounds like your dispenser control board has given up the ghost. The boards come in 2 models, 4 button and 5 button. The 4 button part # is WR55X10443 (~$87.00)... the 5 button part # is WR55X10437 (~$97.00). Not too difficult to replace. UNPLUG YOUR FRIDGE!!! Remove the drip tray from the dispenser, and any screws hiding in there. Then, using a flat screwdriver and starting at the bottom of the fascia, pry the fascia away from the door and remove. Then remove the screws holding the control in place and disconnect any wiring. (Don't forget to pay close attention to WHERE the wires connect and HOW the wires are routed!) Then install the new board and rebuild. Approx. repair time for your first one is ~1 hour. Good luck!
Anonymous
  • 26 Answers
  • Posted on Mar 18, 2008
SOURCE: Ice maker not working
The icemakers won't make ice if the temperature is not below a certain set point. Varies between manufacturers. Try making the temp colder.
Anonymous
  • 36 Answers
  • Posted on Jul 24, 2009
SOURCE: Kenmore Elite refrigerator ice and water dispensers not working
check for a child lockout button it will look like a tiny padlock ,press and hold for 3 sec.(could be the freezer door light switch)
The cold water dispenser in my whirlpool refrigerator stopped dispensing water about 2 years ago. Recently it just started dispensing water and does not shut of. I had to close the valve to the water and...
Hi copy;
You may like to try the Water Valve (Solenoid) sounds like it may had stuck once now has become free and stayed open allowing too continually flow. It is behind fridge where the mains water is connected into fridge... Cheers
1helpful
Whirlpool ultraease refrigerator (ED7FHG) making water sounds, and drips water onto steel pan in bottom rear of freezer side. Purchased new. This is an obvious change. Problem?
You have a water leak somewhere (I'm assuming this water sound is constant). If not write me back for other possible solutions.
The only place water comes into the freezer is for an ice maker or a door water dispenser. Check around the ice maker for a leak. If there is a water dispenser in the door then check the piping to it also.
There is a drain in the bottom of the freezer compartment which is there so when the frost is melted by the defrost heaters, it has somewhere to go. This drain drains into the "drip pan" (or condensate pan) in the bottom of the unit. Here the water will sit until it is evaporated into the air.
If this helps you, please select YES to the first two ratings questions. Thank you, and Good Luck.
Whirlpool indoor ice maker not making ice
Could not locate your model number. However, Check fill tube for icemaker inside the freezer. Iced solid? replace water valve. No ice in fill tube? Get correct model number and resubmit your request.
ICE MAKER
Your ice maker works off a different side than the water dispenser. Most times the water control valve is the problem yet it has 2 sides one for water and the other for ice. You can check the ice maker by filling with tap water. Let it freeze and if it dumps the ice and tries to refill I would say the water control valve part number 4389177 will need to be replaced. Sea Breeze
1helpful
Whirlpool water dispenser ...metalic taste
Hi!!! you seem to have a bad water valve in your refrigerator.change your water filter and the water valve on the back on the frig..
Whirlpool ultraease warm on left side, dispenses warm water
not dangerous, i would recommend vacuuming coils under and behind refrig, make sure the fan behind the unit( cooling for compressor) is running full speed. the water is probably "warmer" then usual because the waterline runs across the bottom of the refrig, which appears to be overheating as it is. this should rectify your issue
1helpful
2answers
Whirlpool Conquest UltraEase Plus Water Filtration System ice dispenser
DEAR FRIEND,
ngfam1 here for you!
I am happy to be of assistance!
It is not worth doing it your self!!!!
Sometimes its not easy to find out what part is bad on a
side X side with ice and water on the door, even for the trained tech. call service!
Here is a good service that I recommend to my customers,
in our 65 year old appliance business! they answer 24/7
Not expensive!
A&E Factory Service
1-800-905-9505 -(IN U.S.A.)
They are open to make appointments 7days/24hours
A&E is factory authorized service for most brands!
Including warranty work!!!
They will help you, and all will be well!
You will be fine now!
Thank You
Bless you,ngfam1
PS. PLEASE GIVE ME A GOOD RATING HERE ON FIXYA.COM BEFORE YOU SIGN OFF!
Whirlpool icemaker not working
the refrigerator has a duel water valve, one for the ice-maker and one for the water dispenser. the valve that the ice-maker relies on may be bad, or it could be the ice-maker itself.
another thing that could cause it would be the temperatures in the freezer. the ice-maker will not call for water until it reaches under 15 degrees.
Kenmore Side by Side Refrigerator Model #106.50544001
It's time to replace the dual water inlet valve (the part the water line connects to). A bit of sediment or other fine object can get in the seat or the material itself can deteriorate and allow a tiny amount of water to pass up to the icemaker.
Top Refrigerators Experts
ZJ Limited
ZJ Limited
john h
