HP LaserJet 3050 All-In-One Printer Logo
A
Anonymous Posted on Mar 16, 2014
What is the meaning of ffc conection in laser printer
Ffc conection
2answers
How to fix C3100 Scanner carriage problem ?
Hi.
C3100: ISU home position error
It usually means the scan carriage can't move.
If it s a little MFP, you can unlock the scan with the yellow button on the left of the glass (under the DP). (This was only meant for transport reason).
Otherwise - Possible cause:
Defective FFC between CCD PWB (YC1) and control PWB (YC8).
- Replace the image scanner unit (ISU)
Defective FFC between control PWB (YC6) and scanner PWB (YC103), or improper FFC insertion:
- Reinsert the FFC. Also check for continuity within the FFC.
If none, remedy or replace the FFC.
Defective home position sensor.
- Replace the home position sensor.
Defective harness between ISU motor and scanner PWB (YC104),
or improper connector insertion.
- Reinsert the connector. Also check for continuity within the connector harness. If none, remedy or replace the harness.
Defective ISU motor.
-Replace the ISU motor.
I have a SAMSUNG 58" 1080p Plasma HDTV FP-T5884. I can still switch the TV on but the screen shows pink bars no mater which source is selected. This video from a guy on youtube shows exactly the same on...
That is a typical case of poor/weak signal getting to the display via the FFC, either is a poor (or NO) contact problem, or a defective FFC.Look for the Flat Film Cable looking similar to the one in the picture, and make sure no pinching/broken traces. And/or confirm the conection at each side. Good Luck!
How to fix an awm 20706 105c 60v vw-1
How to fix an awm 20706 105c 60v vw-1, lets see if I can decode this line of text.
AWM 20706 105C 60V VW-1 Flexible FFC Ribbon Cable how fix it. (no sure what fix means or actual damage here)
well we replace all that fail. fixing them is kinds deity like, for sure.
FFC is cable only.... so....
if you broke the 2 end connectors in the PC, then you just wrecked good mobo. $$$$$
there are 3 kinds if jacks, FFC
  1. hinge (aka rotary)
  2. just pull & push on,
  3. wedge type.
#1 and 3 takes skills not to wreck them.
do not ever yank off 1 or 3. they both must be unlocked first.
wedge just pull up the wedged. device. in the correct directon
the hinge (i hate) must be trickled to open and varies by brand
so far I have no wrecked any but fixed many from others that did.
hinge.
https://www.pcdied.com/PS3/ffc/ffc-top-kinds.jpg
Half page black
Dear the printer has the problem with cis cable(FFC) connected to main PBA.
Replace it.
Thanks.
Fatal error 1a39
Fatal error 1a39 - The description says:
"Service Call Error
Code: 1A39
Category: Hardware
Error Name: Head Error
Cause:
• Connection failure of the HEAD FFC.
• Electric parts or components are damaged due to improper HEAD FFC connection such as connecting it at an angle.
• The drive circuit in the PRINT HEAD is damaged.
• The fuse of the MAIN BOARD has blown.
Check Item:
Is the HEAD FFC connected properly without being connected at an angle and any abnormalities such as peeled terminals?
Remedy:
1. Replace the HEAD FFC. (See P.127)
2. Replace the PRINT HEAD. (See P.126)
3. Replace the MAIN BOARD. (See P.111)
As a point of reference, your three manuals are here (link below), which is where I found this info. (See the first manual listed - in the chart on page 53: Table 2-2). Good luck!
http://www.epson.com/cgi-bin/Store/support/supDetail.jsp?BV_UseBVCookie=yes&infoType=Doc&oid=220056&prodoid=63096219
HP LaserJet M1212nf MFP suddenly began printing all letters stacked on top of each other. Basically all stacked up on left margin
The problem is most likely with the laser scanning unit. Check for damage to Flat Flex. Cable between formatter PCB & laser Scanner unit. Checks the FFC ends for damages. Repair the ends / Replace FFC if required. Service or replace the laser scanner unit if problem persists.
1helpful
Error b200 in cannon pixma 258, how to fix
VH monitor error or Error Code B200
Condition: The print head voltage is abnormal.
Problems and Solutions:
  • Replace Print head and logic board (Replace them at the same time.)
  • Replace Power supply unit
  • Check and Clean Head contact pin condition of the carriage unit
  • Check Cable connection especially the carriage FFC
Regards
1helpful
Scaner error 52 in my laser jet printer printer model :-hp laser jet 3052 all in one printer
52 Scanner Error
The all-in-one has experienced an internal hardware error.
1. Turn off the power by using the power switch, and then wait at least 30 seconds.
2. If a surge protector is being used, remove it. Plug the all-in-one directly into the wall socket.
3. Check the FFC connection between the formatter and the scanner.
NOTE Do not bend or fold the FFCs during the removal or reinstallation process.
4. Try connecting the product to a different power source or surge protector.
5. Turn on the power and wait for the all-in one to initialize.
6. If the error persists, replace the laser scanner assembly.
Error code E677
677 error is printer board error.u check conection( lpt port or usb cable loose conection.printer board loose conection.remove all conection and conect all conection i mean reinsert conection ) then this error come u will service u r printer board(re insolve printer softwere).803 error is expouser lamp end side blocked change u r lamp u r 803 problem is ok
Having problem printing a report. The code ''LPT3'' keeps on coming up.
This means your conection is or should be
Parallel port no 3
check your cabling is correct
Regards
Richard.
k24674
Grand Canyon Tech
Grand Canyon Tech
