Connections should be automatic. Cannot connect and have deleted both main and guest. Searched connections, tried again entering passward and still the same results.
Go to sharing center and click manage networks,once done that delete one by one the connections by rightclicking on them;go back to network you want to connect and try again.Computers save adresses automatic and when there is a few times the same connection pasword it will block the connection.Also try to switch of any anti virus and reset your modem and router
SOURCE: Wi Fi Connection
hi
u need to make sure that you are in a secure connection and moreover its asking for a gprs connection because its loosing the wifi connection. The best idea would be try some other wifi network i am sure you would be able to surf webpages.
enjoy
SOURCE: i could not connect wi-fi connection in my laptop.
(1)Make sure that your AP router WiFi device is configured properly and the LEDs showing the signals with light are on.
(2)Try to bring other laptops in the range it will tell you if the signals are being emitted and are being caught by other laptops.
(3)If all of the above are true than this might be your problem that you have to turn the Wifi button on on your laptop.If you take a look at your keyboard you will find that there are some extra buttons on top you have to figure out the one that turns on the Wifi receiver.
Good Luck!
