Volume very low won't go up
After I posted my problem, I browsed a bit further through the other posts and solutions, until I came across the solution of TrickyTrev34 and gave it a try. However, I did not slice the cable, but did it as follows:
1. Switch off power of the sound system on the subwoofer box. Disconnect the Front Right (FR) speaker box (the one with the volume control) from the subwoofer box.
2. Remove the silver coloured metal oval on which the speaker box stands. Now you'll see a small screw at the bottom of the speaker box. remove it.
3. Carefully remove the silver coloured metal protection plate (with all the little holes) from the front of the FR speaker box by wedging it from the top with a flathead screwdriver or other thin blunt object. Now you'll see the speaker and 4 holes with screws inside. Remove screws and speaker box opens up.
4. Inside you should see six wires (Red, Blue, Yellow, White, Green & Black). Carefully cut the GREEN wire only.
Insulate the both ends of the GREEN wire with electrical tape or heatshrink or similar.
5. Put the FR speaker box back together in reversed order.
6. Connect FR speaker back to the subwoofer box. Make sure the volume setting on your PC is very low, because when you switch back on the power of the subwoofer, you should be blasting again.
As TrickyTrev34 already mentioned, the only downside of this procedure is that it will disable the volume control on the FR speaker, but who cares, your sound system works again, and you can still control the volume via the PC playback control panel and/or the multi-media keyboard if you have one.
Aug 08, 2008 |
Altec Lansing Multimedia Computer Speakers
