Question about Navman iCN 320 GPS Receiver
Not working when i turn on my navman and want to go somewhere it just says WAITING FOR GPS could you help me with this please as why its saying that all the time
Posted by gregstar2007 on
  • 2 more comments
  • arseout Dec 08, 2007
    iam having the same problem with my navman icn 320.it is not getting a gps reading at all.anyone have a solution?
  • Anonymous Feb 10, 2008
    i bought my sat-nave 18 months ago used it once put it back into box then took it out and turned on only to discover it tells me its waiting to recieve saterlites it just jams on cant program onwards
  • Anonymous Feb 18, 2008
    Hi i get the same prob freezing on start searching for sat but no connection
    whats the solution ????
  • daza1213 Apr 20, 2008
    when i turn the navman on it says searching for gps and nothing else happens
Anonymous
  • 4 Answers
From the Main Menu press the button underneath the spanner>Demo and deselect the first square if it is ticked>Save.
With your device turned off, press and hold the "OK" button in between the arrows and press the "On" button.
On screen you should see the "Maintenance Menu". Scroll to "GPS menu" using the arrow keys and select it using the "OK" button. Select "Perform a GPS cold start". When this has finished, press the "Home" key twice (the one with the three lines on it). Turn the unit off, then go outside, raise the antenna, and turn it on again. Keep it still for 10-15 minutes and the unit will start to pick up GPS again.
Posted on Jul 16, 2008
  • Michael Balcombe Oct 04, 2013
    Where can I get my Navman serviced in Melbourne?
Anonymous
Dont know if the navman 310 is the the same as the 320 but if you press the power button and the centre nav button in the middle of the arrows you get another menu with a reset for the gps hope this helps
Posted on Apr 19, 2008
1 Related Answer
Anonymous
  • 4 Answers
SOURCE: navman tcn 320 gps
My navman icn 520 wont find a gps signal and just keeps waiting for gps
I found that if you open out the receiver at the back and make sure it is touching the windscreen it works for me. If not I don't get a signal. It is worse in one of our cars because it has a heat reflective windscreen.
Feb 05, 2013 | Navman iCN 520 GPS Receiver
My navman is giving me wrong direction
Make sure battery is fully charged before using A low battery power will cause it to say stupid things like turn left when it should be turn right etc
Please rate my help++++Thanks for using FIXYA
Apr 14, 2010 | Navman NavPix N40i GPS Receiver
Navman pin 570 navigation not working screen says gps port closed
tap on "GPS Status" (second page of GPS software) and be sure that the box is checked in the upper left hand corner. In the same screen, be sure com 8 and 9600 (baud rate) is shown.
May 28, 2009 | Navman PiN 570 GPS Receiver
Navman 1CN 330
i have just bought second hand navman icn310 need manual turns on and keeps saying waiting for gps ?
Mar 26, 2009 | Navman iCN 330 GPS Receiver
Continual "waiting for gps " message
the message should also read no mnsa data first... if these units are not in continual use,they get corrupt for some reason. all you can do is hope the gps fix will work itself out,otherwisw buy a new unit.
Dec 26, 2008 | Navman ICN510 GPS Receiver
Naveman PIN 570 gps receiver problem
i get the "waiting for gps" message if the gps unit is sending data to the main unit, but no satellite signal is found.
does the unit have sky view?
Sep 16, 2008 | Navman PiN 570 GPS Receiver
Navman tcn 320 gps
Mar 28, 2008 | Navman iCN 320 GPS Receiver
Software update
Navman in no longer offering support for it's iCN 510. I am really mad about this. I spent $400 2 years ago for something that will not have anymore update. Here is there reply when I wrote to them about it. Class action suit anyone?
Dear Henry,
Thank you for contacting Navman Technical Support.
We do apologize for the inconvenience. Navman has decided not to release further map updates for these device due to changes in technology over the last year. We have changed the chipset and software platform and are unable to update this device. The Navman 500 series was released with an updated map version last 2005.
If you need further assistance, please do not hesitate to contact us, we'll be more than happy to help.
Kind regards,
Ofelia
Technical Support Team
Navman USA
C/O Mio Technology USA Ltd.
47988 Fremont Blvd.
Fremont, CA 94538
Office: +1 (866) 962-8626
www.navman.com
Jan 26, 2008 | Navman ICN510 GPS Receiver
Navman icn510 gps reciever problem
How long are you waiting and are you moving while it is trying to acquire signal? These receivers are using older circuitry that may take up to 20 minutes to first acquire a signal from a cold start. If you are moving it may take longer!!! The good news is that after you have initially acquired a location, if you turn the unit off it will only take a minute or so to reacquire after it has "warmed" up.
Oct 22, 2007 | Navman ICN510 GPS Receiver
GPS reception
Navman in no longer offering map support for it's iCN 510. This means if there is a new road or community, this unit will not recognize it.
I am really mad about this. I spent $400 2 years ago for something that will not have anymore map updates. Here is there reply when I wrote to them about it. Class action suit anyone?
Dear Henry,
We do apologize for the inconvenience. Navman has decided not to release further map updates for these device due to changes in technology over the last year. We have changed the chipset1.gif and software1.gif platform and are unable to update this device. The Navman 500 series was released with an updated map version last 2005.
Kind regards,
Ofelia
Navman USA
47988 Fremont Blvd.
Fremont, CA 94538
www.navman.com
Jul 16, 2007 | Navman ICN510 GPS Receiver
Navman iCN 320 GPS Receiver Logo
315 people viewed this question
Top Navman GPS Experts
Ekse
Marvin
Marvin
Are you a Navman GPS Expert? Answer questions, earn points and help others
