Remove the Screws: First, you'll need to remove any screws that hold the device together. Look for visible screws on the casing or housing. Use the appropriate screwdriver (usually a Phillips or Torx) to carefully unscrew them.
Open the Casing: Once the screws are removed, gently pry open the casing. Be cautious not to damage any delicate components inside. You can use a flathead screwdriver or a plastic opening tool for this step.
Access the Battery: Inside the casing, you'll find the battery. Depending on the specific Braun device, the battery may be soldered in place or connected via a connector. If it's soldered, you'll need to desolder the connections. If it's connected via a connector, carefully disconnect it.
Replace the Battery: If you have a replacement battery, insert it in place of the old one. Make sure to observe the correct polarity (positive and negative terminals). Secure the battery back in its position.
Reassemble the Device: Put the casing back together, aligning all the components properly. Screw it back in place.
Test the Device: Once reassembled, check if the device powers on. If it does, congratulations! You've successfully replaced the battery.
Wedge a plastic opening tool into the lower right corner of the Kindle Fire.
Pry the case apart and run the plastic opening tool along the perimeter of the Kindle Fire to release the clips securing the case halves to each other.
If you are having extreme difficulty inserting the plastic opening tool, carefully use a metal spudger to undo the first clip, then switch back to the opening tool to avoid scratching your case.
It is helpful to pry the bottom of the Kindle Fire away (and out from the side) from the top part. Exerting too much force attempting to split the two without pulling away can cause the tabs on the inside to crack.
Step 2
Once you have freed all the plastic clips, pull the back case off the Kindle Fire.
Step 3 - Battery
Fit the tip of the plastic opening tool between the right battery cell and the Kindle Fire's frame.
Lever the battery up and work the plastic opening tool down along its edge to release the glue securing it to the frame.
step 4
Repeat the process from the previous step to free the left battery cell.
Step 5
Lift the back of the battery up to relieve any tension in the battery connector and simultaneously use a spudger to push the battery connector out of its socket.
most cases are held together by screws, so screws maybe hidden behind the labels, manufactures information, and felt material,
and cases may also be a snap together type, you will have to force an opening slide the screw driver around the case while pyre bar type action pop the case open.
You have to watch that the buttons don't fall out of place when you open it. So use a strip of masking tape to hold them in place before you open the case.
To open the tablet it snaps in all around. You need to insert a small screw driver between the case edge and another small screwdriver to keep prying all the way around. You can hear it when it snaps open. You may need the point of a small sharp knife first. I have opened and closed mine to get the battery number. I will be replacing mine as well. You need to solder the new battery in.
Asus motherboards usually use a lithium CR2032 battery for CMOS. Also, on the top of the old CMOS battery you took out there should be the exact battery type engraved on the surface.
Batteries Plus in Wichita, KS has a good online store for purchasing your replacement battery.
The first item to check is the battery. No easy way to do it without opening the case. If you decide it is the battery, you can order a replacement from Amazon. You then should should consult YouTube videos to see how to crack open the case. Once the case is open, the battery swap is straightforward and it closes easily. If you decide it is too difficult, you can ship the device to several repair depots. They charge around $80 to replace the battery. You should include the charger as that my be why the battery has failed.
This scooter requires (2) 12 volt 15 Ah batteries. Typically you would open the case and replace the two batteries inside not the entire case and batteries.
Locate the screws that hold the case together and open it. Make a diagram of the how the batteries are connected. Obtain the new batteries locally or on-line, install and fully charge.
Hope this helps.
These cabinets(casing) are very specially made, if you try to open , and replace battery, it wont close well, however if there are mini screws, usually found concealed with a label , remove the label and see if you can open the casing
• Remove slide cover. Place calculator face down. • Using a small Phillips screwdriver, remove screws from back case. • Remove back case. • Remove discharged batteries. • Install new batteries positive side up, as shown on diagram inside case. • Run a coin across the reset pad on the upper right hand corner of the printed circuit board. • Replace back case, and then replace screws. • Press [OFF], [ON/C], [ON/C]. Note: The calculator cannot hold data in memory when batteries are removed or become discharged.
