Purchase the plastic lift lever arm first. Remove motor from pedestal with the 4x large Philips head screws underneath the back of the motor housing. Note which way around the lever is on the shaft (take a photo is a safe way) Remove split pin with some pliers, don't wreck it as you will need to re-use it. Punch out the roll pin that locates the plastic lever to the shaft. Fit the new plastic arm CORRECTLY. Punch the roll pin back where it belongs, making sure it is evenly engaged as too far in or out will make it foul. Put the rod back thru the lever and split pin it again. Check operation before you put the motor back on.
