Question about Metra Ford F 150 Truck 1999
My 99 f150 you drive it down the road it starts beeping then stall out
When I drive my truck for about 4 miles it starts a beeping noise then loses power and stalls out
Robert Struzinski
    Sergeant:
  • 182 Answers
Check fuel pump, that's how the act when they go bad, the beeping is the engine stalling.
Posted on Nov 16, 2014
Why it stalls at stops and low speeds
accord stalling on every stop. (1/2) - EricTheCarGuy ...
www.ericthecarguy.com/.../8.../46884-accord-stalling-on-every-stop
The car runs good but stalls every time i come to a stop. ... a stop then it diesagain.only on the stops does the idle drop very low to the point of stalling.what ... only when I start slowing down and come to a complete stop RPM's go down and the cardies. ... The popular Honda Civic and Accord vehicles share many powertrain ...
1998 Honda Accord loses rpm/ stalls coming to a stop ...
honda-tech.com/honda-accord.../1998-honda-accord-loses-rpm-stalls-co...
Jan 10, 2013 - I just bought a 1998 4 cyl 2.3 L Honda Accord two days ago. ... 1998Honda Accord loses rpm/ stalls coming to a stop. .... Is clockwise high idle or low idle? all in all i probable rotated counterclockwide 1.5 or 2 turns. maybe this ...
1999 Accord, 130k+, stalls when slowing to a stop - Honda Accord ...
www.hondaaccordforum.com > ... > General > General Tech Help
Mar 10, 2010 - My fiancee's '99 Accord EX Coupe 4-cylinder automatic, with 130,000+ miles, has recently (in .... No low RPM & feeling like it's GOING TO stall.
99 Honda Accord - Strange Stalling Issues! HELP!
https://www.2carpros.com/.../1999-honda-accord-99-strange-stalling-issu...
My 1999 Honda Accord is having sporadic stalling problems. I've noticed a pattern. Itstalls while going slow speeds and stop and go traffic, etc. The engine just ...
Stalling or Low Engine Idle Speed Due to Dirty ... - Repair
Jan 02, 2016 | 1999 Honda Accord
I have a 2007 Suzuki xl7. When I first start down the road it seems to drive fine but within 1/2 to 1 mile it starts running very rough, leaping along. This goes for about another 1 to 3 miles. It runs...
ok and XL 7 but what engine options. gas, diesel, 2L , 2.5L?
what?
and most important , and never ever 1 time stated on this forum
what country.
leaping?
im not sure what you are saying.
it runs ok cold, and as it warms , the engine. it stalls.?
and what does same thing mean.?
my guess, it starts fine then stalls; hot.
but can you save the stall?
stalling is complex. can be many systems in the car.
but can be broken down to :
Ever did the 60k mile tune up,ever? if not why not.
never skip 60k\'s or the motor will run like garbage.
1: lost electrical power. to EFI .
2: bad engine, in that when it gets hot , it loses compression.
3: lost park. 1 or more cylinders, 4 or 6 you never said.
4: bad injection. 1 or 6 of them, flooding or starving.
5: bad fuel.
6:EGR sticking , usually this happens just before a stop sign.
7: if the stall was a bog and the fast right foot saved the stall, easy
the ISC is sticking closed.
Sep 30, 2013 | Suzuki XL7 Cars & Trucks
1997 honda accord oxygen sinsor
how many miles/km on your car. Part of regular service is to replace the timing belt. Most cars is every 100000Km. When timing belt goes will still crank but won't start.
Apr 05, 2012 | Cars & Trucks
Truck cuts off while driving down the road.
Replace the TFI module. Ford back in 1986 thur 1993 had problems like the one you wrote about. TFI module gets hot and shuts car or truck off then when it cools sometmies starts and sometimes not.
Jun 14, 2009 | 1993 Ford F150 SuperCab
Overdrive light on my 99 f150 never comes on...replaced switch already...could it be the harness?
If the over drive is located on the shift lever on the column it should be on with no light. The only way the light comes on is if you turn it off. Over drive button is located on the end of the shift lever. Drive it down the road and count how many times it shifts it should only shift 4 times. Start 1, 2, 3, 4OD with light off and 3 times with light on.
Mar 26, 2009 | 1999 Ford F150 Regular Cab
1999 f150 4.6 liter engine triton 4 wheel drive auto
first off you can not de driving down the road and shift into 4 wheel dr. ...... yah have to STOP put in park ,shift into 4 hi then drive do this and let me know how it works for ya........
inastuctions are or should be on the back of drivers side sun visor.......
rank my solution ty
Dec 13, 2008 | 1999 Ford F150 Regular Cab
Metra Ford F 150 Truck 1999 Logo
80 people viewed this question
Top Metra Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
jdthefixer
Are you a Metra Car Audio and Video Expert? Answer questions, earn points and help others
