T-Mobile MDA Logo
Posted on Jun 13, 2009
How can i restore my contact on mda vario 3 after mistakenly ending patnership with my pc
Anonymous
Level 1:
  • Contributor 22 Answers
  • Posted on Jun 14, 2009
Anonymous
Contributor
Level 1:
Answers
22
Questions
0
Helped
6968
Points
98
If you have bluetooth on your pc set it up, or usb connect, or usb connect and run cd that came with phone
Smashed my screen on my mda vario got a new phone now want to active sync in but cant remember my pssword is there a work around?
Yes, you need to perform a hard reset.
To perform a hard reset
1. Press and hold the Comm Manager button and Voice Command
button on the device. At the same time, use the stylus to lightly
press the RESET button.
T-Mobile MDA Vario hard reset soft reset hardreset softreset
2. Keep the Comm Manager button and Voice Command button
pressed, and the following message will appear on the screen:
3. Release the two buttons, and press the Send button to perform a
hard reset
T mobile mda vario 2 of USA and now I want to use it in india so for that i need network unlock code
u can find info via this thread!
http://forum.xda-developers.com/forumdisplay.php?f=254
My phone the MDA Vario wont installm on my windows
download activesync
http://www.microsoft.com/windowsmobile/en-us/help/synchronize/device-synch.mspx
1helpful
How do i unlock htc wiza200 mda
There is a very straightforward solution now, thanks to some helpful peeps at xda-developers forum. Simply download a zip file called lokiwiz3a.zip (Google is your friend).
I used it yesterday and had generated the unlock code within minutes of connecting the MDA Vario with my laptop.
2answers
My pc is not detecting my T-Mobile MDA
in windows, right click on the CD player with you cd in it.
click explore and look for USB Drivers.
Install the drivers and try hooking your phone up again.
Try using a fast USB 2.0 port on the computer.
If this helps please leave a vote
1helpful
2answers
Active Sync. on an MDA Vario 3
i had this problem, everytime i refreshed the mda the pc showed that the phone was connecting then once the mda vario had stopped the connection was lost, what i did notive was that the com port for active sync showed up on my pc as com port 4? which isnt a choice on the mda as there is only 2 ports available com 6 and com 7, what i did was to add new serail services to the pc until i was given com 6 as a choice,(because by default the pc starts off as com 4 then com 5 etc, so goto the bluetooth configuration then click on client apps and keep adding new service until you get com 6 then try and sync via activesync on your phone, if that doesnt work make sure that you have added new bluetooth device which gives you options of what services you would like the phone to use with the pc, click activesync then configure it to connect on com 6 voila that should work fine iv just updated mine to netframework 2.0 and can now run all the apps i want, any problems email me on [email protected] il be happy to assist any way i can as i was stuck on this problem for ages and ages until i finally solved it hope you succeed.
Mark
MDA Vario died - HELP
hi. i have had the same problem and have had to change the battery twice in the three years i have had it. sometimes the batteries that you can buy off ebay are quite cheap but go off without any warning fairly quickly.last one i have bougt has lasted me 1.5 years without any probs.
my other advice would be to back up your contacts/other sensitive information somewhere safe( your phone SIM for example- which has to be done one at a time for the mda vario)as well just in case.
hope it helps
T-Mobile vario
another problem if anyone can help is how to send contacts from mda vario to mda vario III??????? its getting me down!!!!
also having problems with sync so cant load onto pc then copy but it used to wk!!
Top T-Mobile Computers & Internet Experts
Mohammad Abumuailek
Mohammad Abumuailek
Grand Canyon Tech
Grand Canyon Tech
john h
Are you a T-Mobile Computer and Internet Expert? Answer questions, earn points and help others
