Attempting to find out why washer is spinning slowly. have watched many videos on removing the cabinet, but our model has the tubes attached to the cabinet and the back. there is a little plastic tab on top of the machine under the control panel that needs to be removed to remove the tubes. no video help anywhere for our bizarre model.
F.Y.I., the Kenmore product line is made for Sears by leading appliance manufacturers and branded with the Kenmore name. Sears does not manufacture any products themselves.
Whirlpool is the manufacturer for this particular model of Kenmore since the prefix number before the period (or dot) in the full model number is, 110.
Kenmore: http://www.searspartsdirect.com/partsdirect
service/repair manuals: http://www.appliancerepair.net/washing-machines-forward.html
Best regards
SOURCE: How do I remove the cabinet on a Kenmore Model 11022882101 top loading washer?
You need to remove 2 screws in console. They might be in back, on ends or in front ends. If you can't see any, they are under the console end caps. To remove end caps, pry off by pulling caps towards outside from center part of cap. Pry toward you and towards outside. Then remove 2 screws and flip console up and back. Unplug connector to washer cabinet. Remove 2 gold colored clips by inserting straight screwdriver in them and prying back. Make not of their position first. Now tilt cabinet toward you and slide forward and off base.
To replace, tilt cabinet and slide under frame in front. Now lower cabinet on to frame, making sure cabinet is on frame on sides. Re-install clips by placing them in position and pushing down with palm of hand. Plug in connector, lower console and install screws.
SOURCE: Removal of front cabinet panel of washer section
Should be two screws on each side of the bottom of the front panel. Takes those out and push the panel up and out. (There are two "tabs?" in the middle of the front panel that lock into the side panels, so you have to push up and then pull out.)
SOURCE: kenmore washer
No need to remove the back panel on this model. You can access everything by removing the washer cabinet. Here's how:
1. Unplug washing machine.
2. Remove console. This can be accomplished in one of two ways depending on which type of console you have.
a. If the console has removable end caps, the caps lift off by prying on the top from the back of the washer. The cap will pull off towards you as you are facing the unit from the front of the washer. There will be a screw under each end cap that you will need to remove.
b. If the console does not have removable end caps, you will need to slide a putty knife under the front corner of each side and push in while lifting up. There is a retaining clip under each side that has to be released.
3. Once the console has been released it will lift up and fold back over the back of the washer in its resting position. Use care not to stress the small plastic hinges that hold it on. They can break easily.
4. Under the console will be two large brass colored clips. Take a large flat blade screwdriver and place it in the groove of the clip on the washer top. With the screwdriver firmly in the groove, push away from you towards the back of the washer. This will release the clips.
5. Disconnect the lid switch connector plug. This is the white colored plug on the washer top under the console.
NOTE: The washer will NOT operate with the lid switch connector unplugged. If you wish to attempt to test the washer for leaks with the casing removed, you will need to by-pass the lid switch. This can be accomplished by jumpering the two black wires together at the lid switch receptacle. CAUTION: DO NOT attempt to jumper the wires with the washer plugged in! Attach jumper, then plug the washer in.
6. Remove the washer casing. Open the lid of the washer. Using one hand, grip under the front rim of the washer opening. Do not grab the wash tub, just the casing. Tilt the washer case from the back first towards you, slide forward slightly, and then lift up. The entire case comes off exposing the wash tub and components.
Now, you stated your washer leaks during the rinse cycle. Double check all hose connections on the water pump (located directly in front under the wash tub). The pumps have also been known to start leaking along the seams. NOTE: If the pump leaks, it is NOT serviceable and must be replaced. They do not come apart.
To re-install washer case:
1. With the lid of the washer open, place grasp case under front rim and place it on the washer frame. While looking down through the washer lid opening, make sure the front lip of the case is placed UNDER the washer frame and rocked back onto the frame to ensure that the small cleats on the frame fit into the slotted grooves on the washer case base. If you do not get the case seated correctly it will rattle and vibrate while the washer is in operation.
2. Make the back of the washer fits into the washer casing on each side and reinsert the brass clips. Place the clip into the slot on the back of the washer first, and then forcefully push it into the opening on top of the washer. It will snap back into to place.
3. REINSTALL LID SWITCH CONNECTOR. It is easy to forget. If you do not reconnect it, the washer will not work correctly.
4. Reinstall console.
I know it seems like a lot, but it is an easy process if you take your time and follow the steps as written. Let me know if you need further assistance.
SOURCE: Removing Back Panel of Kenmore Washer Model 11020902990
if its less than 15 years old its a direct drive whirlpool, no belt, remove the cabinet, not the back panel. look up direct drive whirlpool washer cabinet removal on internet, and replace the coupler, most likely, if it drains.
SOURCE: How to remove knob from panel
If there is a black tab on the back of the timer, it needs to be pulled out of the timer before you can remove the knob
