Question about One For All URC-3021 Remote Control
NEED CODE I Need the tv code and steps to program my URC-3021 B00 remote to a toshiba tv please...thank you
Posted by jakeatafua on
  • 11 more comments
  • donaldc3 Nov 05, 2007
    i tried to program it but i can't figure out the code
  • Anonymous Nov 10, 2007
    i do not have the manual to the remote control
    cannot program without codes
  • leesgirl21 Nov 21, 2007
    i need codes lost my codes
  • georgebush Nov 25, 2007
    how do try the program
  • Anonymous Dec 11, 2007
    need
    code for charter box
  • deboomer Dec 11, 2007
    need code for a charter box and instructions how to program remote
  • frigemall Dec 23, 2007
    I put in the code listed in the manual for my television but it does not work. Can I get another code or what should I do?
  • beesgirl3 Feb 22, 2008
    need to program remote for a jvc tv
  • sammi68 Feb 22, 2008
    IF THERE A CODE FOR SHARP 25R-S100?
  • krb1223 May 07, 2008
    need code for urc- 3021boo, rca tv and magnavox
  • Anonymous Mar 13, 2014
    codes for toshiba tv
  • Anonymous Apr 01, 2014
    i have a Haier tv.
    need the code for the remote please.
    Thank you
Rafael Ortiz
  • 259 Answers
Celera 0765
Magnavox 0054, 0706, 0030, 1454, 1254
SEARCHING FOR YOUR CODE
If your device does not respond to the remote control after trying all codes
listed for your brand, or if your brand is not listed at all, try searching for
your code.
NOTE: Before performing a code search for a DVD player or a VCR, turn on the device and
insert the required media.
For example, to search for a code for your TV:
1. On the remote control, press TV once.
2. Press and hold SET until the LED (red light) blinks twice,
then release SET.
3. Enter 9 - 9 - 1.The LED will blink twice.
4. Aim the remote control at the TV and slowly alternate
between pressing POWER and TV. Stop when the TV turns off
(after pressing POWER). If the device does not have a Power
key, you can substitute another function, such as digits 0 ~ 9 ,
CH, or PLAY).
NOTE: In the search mode, the remote control will send IR codes from
its library to the selected device, starting with the most popular code
first.
5. To lock in the code, press and release SET.The LED will
blink twice.
6. To search for the codes of your other devices, repeat steps
1 through 5, but substitute the appropriate device key for
the device you are searching for.
here is the maual for your remote:
http://www.ofausa.com/remote_manual/URC4...
Posted on Dec 12, 2007
Changing remote to another tv lost my owners manual dont know what to do fist going from a philips tv to a toshiba tv
I can help you with your URC-3021 Universal Remote Control issues.
The codes for Toshiba TV's are: 0154, 0156, 0060, 1356, 1656,
1704, 0650 & 1256.
For complete instructions on entering the URC-3021 remote codes, please refer to my posted Fixya Tip One For All URC-3021 Code Entry.
I hope that helps.
_______________________________________________
One For All URC-3021 Manual
One For All URC-3021 Code List
One For All URC-3021 Code Search
One For All URC-3021 Reassign Key
May 20, 2010 | One For All URC-3021 Remote Control
I need to program the remote to my Memorex tv. How do I go about doing this?
The codes for Memorex TV's are: 0154, 0250, 0463, 0150, & 0178.
I hope that helps.
URC-3021 Remote Control: How do i program this remote to a sansui tv?...
I can help you with your URC-3021 Universal Remote Control issues.The code for Sansui TV's is: 0463.For complete instructions on entering the URC-3021 remote codes, please refer to my posted Fixya Tip One For All URC-3021 Code Entry.I hope that helps._______________________________________________One For All URC-3021 ManualOne For All URC-3021 Code ListOne For All URC-3021 Code EntryOne For All URC-3021 Code SearchOne For All URC-3021 Reassign Key
May 18, 2010 | One For All URC-3021 Remote Control
URC-3021 Remote Control: i need a code for rca remote...
Without knowing what brand of TV you would like to control, may I recommend using the URC-3021 One For All URC-3021 Code Search, or refer you to the One For All URC-3021 Code List?
I hope that helps.
May 16, 2010 | One For All URC-3021 Remote Control
I need to program my remote and to do so i need the tv remote code tv modelis 27E-S3900
The codes for Sharp TVs is : 0093.
I hope that helps.
Reassign URC-3021 Device Key
Urc-3021 Code List Download
May 01, 2010 | One For All URC-3021 Remote Control
Looking for tv code for remote
The codes for Toshiba TVs are: 0154, 0156, 0060, 1356, 1656,
1704, & 0650.
I hope that helps.
Apr 06, 2010 | One For All URC-3021 Remote Control
Need code 2OAF45 toshiba TV using all for one remote control model URC-3021
1704, 0650 & 1256.
I hope that helps.
Mar 03, 2010 | Toshiba 20AF45 20" TV
Programming
Without knowing what brand of TV you would like to control, may I recommend using the URC-3021 One For All URC-3021 Code Search, or refer you to the Urc-3021 Code List?
I hope that helps.
Jan 03, 2010 | One For All URC-3021 Remote Control
What is the code on my URC 3021 B00 remote for Citicen Tv
To control a Citizen TV with a One for All URC-3021, follow these steps:
1) Turn on your TV.
2) On the remote, press the TV key once.
3) Press and hold SET until the LED blinks twice, then release SET.
4) Enter the first four-digit code from the following list:
0060, 0030, 0092
If it does not blink twice, go back to step 2 and try the same code again.
5) Aim the remote at the TV and press POWER.
The device should turn off.
If it does not turn off, repeat steps 2 through 5 with the next code in the list.
Hope that helps.
Oct 18, 2009 | One For All URC-3021 Remote Control
Urc-3021B00 need codes for Symphonic tv
If you have the owner's manual for the remote, try the codes under "sylvania" or "Funai"
Feb 27, 2009 | One For All URC-3021 Remote Control
One For All URC-3021 Remote Control Logo
372 people viewed this question
Top One For All Televison & Video Experts
Christopher Stearns
Are you an One For All Televison and Video Expert? Answer questions, earn points and help others
