SOURCE: panasonic microwave no working at all
H95, H97, H98 or
H99 mean that there's a problem with your inverter,
magnetron, or digital programming circuit.
Due to the lethal
voltages used and produced in inverters, I do not recommend that an
inexperienced person work on these.
In Canada, you can find an authorized Panasonic servicer here.
We're
happy to help you with free advice and we'd appreciate your thoughtful
rating of our answer.
SOURCE: ERROR CODE H98 ON MY PANASONIC MICROWAVE OVEN.
H95, H97, H98 or H99 mean that there's a problem with your inverter, magnetron, or digital programming circuit.
Due to the lethal voltages used and produced, I do not recommend that an inexperienced person work on these.
You can find an authorized Panasonic servicer here.
If you're not in the US or Canada, see Panasonic.net.
SOURCE: Error Code
You can find an authorized Panasonic servicer here. If you're not in the US, see Panasonic.net.
SOURCE: H98 code on a panasonic microwave
Go back to the manual, and read the whole thing or just look at the Chapters names, and find teh right one, and hopefully that will answer your problems.
I am a myth, a myth surround by spirit and souls.
- Myth12 [ i love blogs]!
SOURCE: panasonic genious sensor inverter 1300w nn-t664sfx
Mine did this once and it was the magnetron. Once replaced, it worked fine. Repair is an option if it is still under warranty or someone will do it on the cheap. Otherwise, just get a new microwave, since this is the main part.
This oven is
programmed with a self diagnostics failure code system which will
help for troubleshooting, H97, H98 and H99 are the provided failure
magnetron and inverter circuit problem areas. This section explains
failure codes of H97, H98 and H99. H97, H98 and H99 appears in
display window a short time after start key is pressed and there is
no microwave oscillation.
There is not a lot the layman can do except maybe to try a new magnetron.
It is a job for an experienced Panasonic Microwave repair man.
