Question about Magic Chef MCWC30MCG Compact Wine Cooler
Eff code Eff blinks in the display
I have a Panasonic TC-P65ST50 which recently began shutting down and displaying 7 blinking lights and 8 blinking lights. Most of the time 7 blinking lights are displayed.
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
http://electro-medical.blogspot.com/
Feb 25, 2016 | Panasonic TC P65ST50 - 65" Class 64.7"...
I need to pass emissions and have 4 codes to solve.
Your doing your own diagnostics?
The codes are on the internet
Aug 15, 2014 | 2005 Toyota 4Runner SR5 V8
Stumble @ 30-40 MPH under ligh acceleration
Problem sometimes is with cheap parts they are bad.Good wires,good plugs,good coils.
May 05, 2013 | 2004 Mitsubishi Endeavor
I have a whirlpool duet washer/dryer. Large capacity i think. When I wash my husbands work clothes (dirt, grease, etc) I'm not sure if they are getting clean. They come out smelling just like they...
Hello
Could be the wash soap your using.You need to use high eff soap with this washer.
Tide makes a high eff soap,you will see it on the lable marked high eff.
Also check your drain line for any debris or blockage and remove.
Aug 01, 2011 | Whirlpool Washing Machines
Error code eFF
This normally indicates that you're using a lens with an aperture ring, and the ring is not locked in position. Turn the aperture ring on the lens to its smallest setting (largest f/number) and lock it if the lens has a lock. Control the aperture from the body, just as with a lens without an aperture ring.
If the lens doesn't have an aperture ring, could you reply to this post and specify what lens you do have on the D100?
Dec 05, 2010 | Nikon D100 Digital Camera
P=160 r=30 s=11000 eff=1
<span class="sectionbodybold">P= 160 R= 30 S= 11,000 Eff= 1 </span>
Aug 20, 2010 | Heating & Cooling
My kenmore washer showes sud code
If it is similar to the Whirlpool duet,
Try using less soap (hi eff machine)
try using more fabric softner
to clear the occasional Sud warning, I run the machine on "quick wash" with no detergent/additive. gives it two more quick spin cycles in 30-35 minutes, usually clears it.
Jul 14, 2010 | Kenmore Elite 45986 Front Load Washer
Error code eFF
hey,
which lens are you usuing?
it means that the F is not set, and you neet to set in manually. usually there is a tiny button in the backside of the lens.
May 19, 2008 | Nikon D100 Digital Camera
Magic Chef MCWC30MCG Compact Wine Cooler Logo
Top Magic Chef Furniture Experts
Sheldon Dedek
Muntejaya Ginting
Muntejaya Ginting
Are you a Magic Chef Furniture Expert? Answer questions, earn points and help others
