The water dispenser has a slow drip, enough that it fills the little drip tray and drips water down the front of the refrigerator. Any ideas on how to fix this?
SOURCE: water dripps
IF THE WATER IS DRIPPING OUT OF THE DISPENSER NOZZLE THEN YOU NEED TO REPLACE THE SOILINOID BECAUSE IT IT LEAKING THROUGHT THE VALVE..
SOURCE: RF266AB, 3 months old, water dispenser continues
The unit comes wih a one year warranty, if you call Samsung they should send a tech to your home free of charge for that first year of ownership. I don't think for the amount of money you would have paid for this fridge you should not be completely happy with it. The problem is that air is getting into the water lines when you use the dispenser at one of the connection points in the water lines. This creates extra pressure so the dispenser spout keeps dripping. you can follow the lines to each connection and make sure they are all tight or dial 1800Samsung to schedule an appointment.
SOURCE: Water dispenser drips on my Samsung side by side.
That really has to be bothersome! I can imagine a leaking roof and pails and buckets everywhere tying to collect the water. On your refrigerator the problem could be related to a defective water control valve, air in the water lines like after adding a new filter and having to purge the air out before the water flows freely. You mentioned lime as a element in your water supply and sounds like you may have well water. Lowes or Home Depot see nice in-line water filter to pre-filter the water before getting to your refrigerator. As for the water control valve tat may be stuck open like a dripping faucet, it may need replaced. Try to see if turning the water supply off to refrigerator before refrigerator and see if water continues to drip. If yes then I belie a new dual water control valve will be needed. Let me know what happens and do get a pre-filter they are really helpful, Sea Breeze
SOURCE: Samsung RS267TDRS Refrigerator -- no water coming
The most common reason water stops are 1. The water line has frozen, but its not the part in the freezer door. Behind the crisper bins in the fresh food section, you might not see it but it behind the back wall. Heat up that area with a hair dryer, or if its not full shut it off for 24 hours and it will do the trick. 2. The pump that sends the water to the dispencer is dead, it will be located behind the ref lower left hand side behind panel (follow the water line) part # DA74-40149D, you can order it at marcone.com for about 27.00
Good luck, if those dont work let me know
SOURCE: The ice maker in my samsung fridge is putting too
Either the icemaker support is broken, DA61-02205A
or the ice tray is damaged or has lime buildup. The ice tray is
supposed to twist when it flips: an off-center stud on the tray is supposed to catch
the support, while the tray is still turning. If it does twist but does
not release ice - replace or clean the ice tray, DA63-01453B
Good luck,
Vlad
First Choice Appliance
