Question about Xantrex Technology Trace Series Inverter / Charger 1500w
Solar system, 2 SW5548 inverters wired for 220v. Have worked fine for 10 years til last week. Now only one will regulate to my 118v line. The other goes to 84-90 volts and just sits there. Any ideas?
Posted by jbcompton on
wwlvictoria
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 1,001 Answers
Chornic Solar panel power
Solar panel power
14 watts Mono-crystalline
output:5V/2.4A+5V/2A(Max)
Unfold size:245×780mm/9.5×31in
Folding size:245×165×45mm/9×6.5×2in
Weight:650g/25 oz
Package Including Content: 14W Solar Charging Panel, Micro USB Cable. Chornic 14W Foldable Solar Charger with 2 Port USB Charger Build with High...
Posted on Nov 28, 2016
Anonymous
    Problem Solver:
  • 5 Answers
I assume both inverters connect to the same battery bank so any problem with batteries would effect both inverters the same way. You say one inverter "regulates" to the AC input and the other "goes to 84-90 volts and just sits there" I'm not sure what you're describing but If you mean the defective inverter only puts out 84 to 90 volts, I would suspect a defective MOSFET (power transistor) Use an oscilloscope to look at the output waveform and see if there are missing steps to the staircase waveform.
Posted on Aug 28, 2009
Craig Butler
    President:
  • 1,730 Answers
How are the batteries for that inverter? Have you got a dead battery in the loop?
If you need further help, I’m available over the phone at https://www.6ya.com/expert/craig_3fa289bf857b1a3c
Posted on Jul 03, 2009
2answers
I have solar panels that put out a little more voltage then they are rated at,and they keep faulting out my grid tie inverter.I need a resister to knock down the voltage about 8 volts, got any ideas?
I like to ask, is the voltage from the solar panel messure with some load connected or is open circuit, normally solar panels produce high voltage than the working system, the reasson for that is to have Amperes in of to charge the batery, these is related to the size and power generated by the panel.
No need a resistor or in any case use a voltage regulator to prevent over charge.
How long a solar pannerl converter last ? WATTNODE WNA-1P-240-P
Normally several years (5-12) unless there is a wiring problem (short). If you have a seperate voltage regulator, check it first.
My inverter seems to be producing too high a voltage when solar input increases, causing the system to shut down and re-cycle many times during the day. I do not see fluctuations in the grid voltage wwhen...
hi
yes there is a voltage regulator of an electronic kind .
I suggest the inverter is well ventilated( if not) and not positioned in direct sun light and shaded as inverters do get quite hot their function better when kept cooler
Red fault light comes on after about 10 mins and
Had a similar problem with the same inverter BUT to include a failing cooling fan.
NOTE:
Take it back and get your money back as soon as possible.
Replaced it with a pure sine inverter 1500 watt that is kicking **** 24 seven days a week on my solar / wind power system.
RECOMENDATIONS:
UPGRADE.
Hope this tip helps.
R/
David
2answers
I have a trace inverter DR 1512, I am having a problem with my system, which includes a 5000 watt gen, and solar power. When I am dry docked and have solar, system functions fine, when I lose solar and go...
the solar panel is just to charge your inverter,if it is charging and the inverter is on it will drain the current the solar panel is supplying to the batteries,this makes it look like it is not charging ,so i advice you to switch off you inverter when charging it,get another set of batteries connected to your solar panel then charge both, let them be separated so that the new one is not in use so that when solar is out you can switch to the other set of batteries
2answers
I have 46 solar panels which is a 9.2 kwh pv system which feeds 3 sunpower solar inverters which are the 3200 series. Of the three inverters, one constantly goes out for about 4-6 hours from 10-4 in the...
are your inverters rated at 60 cycle full sinusoidal wave form or 60 cycle square wave. while both will be tolerated in a transformer, the square wave tends to heat up because it isn't a sine wave. the peaks of a standard sine wave are cut off if observed on an oscilloscope.
2helpful
3answers
200AMP Breaker trips same time every night
Something doesn't sound right here. You indicate 2 200Amp breakers. With a single service entering the house, this is not possible. The "sub-panel" to the pool house is more likely a 100Amp setup, yes? If not, you have a bad setup and it should be corrected. I would suspect that you are attempting to pull too much current to the pool and that is what is tripping the breaker. Also, these breakers should not be run over about 80% of their capacity for the long haul. If they are, they tend to age and get either real sensitive causing tripping when it shouldn't or you can run 500Amps through it and it won't trip.
My suggestion is to revisit the setup. If the pool house is fed from the main panel, make sure that the breaker for it is not 200Amp. Second, try disabling the pool house breaker to see if that is the source of the problem and look more closely there.
Keep us posted.
Dan
Tatronic inverter problem
Tightened up battery connections
Xantrex Technology Trace Series Inverter / Charger 1500w Logo
Top Xantrex Technology Electronics - Others Experts
Tom Chichester
Are you a Xantrex Technology Electronics - Other Expert? Answer questions, earn points and help others
