I found this picture, if that is correct? Probably a three wire connector, ref voltage--ground--signal. I did see another picture, I wasn't sure? This picture said dfi.
Temp switch - Under hood, center, upper engine area, front of intake manifold, driver side of distributor, mounted in engine block,
Coolant temp sensor - Under hood, center, front engine area, passenger side of distributor, mounted in intake manifold,
There is no water sensor
Hello, try this way: How to Easily Save Photos to SD Card Just plug your LG phone into computer, and open the software on computer, then you can see the phone files and choose the photos as you like.
Improve the Fixya.com experience for everyone by voting!
Your knock sensor on your 3.8 litre engine is under the hood, passenger side, rear engine area, below exhaust manifold, mounted in engine block.
[I'm not alloted enough space to show you a picture of the knock sensor]
Your EGR valve is located under the hood, center, driver side, mounted on upper center driver side of engine [I'm not alloted enough space to show you a picture of the GR valve] All the best,
Your sensor (the device that absorbs light and transmits that data into a picture) has gone bad. Thats why all the photos seem to appear blank, but they are just black. It can be repaired and its usually the cheapest at a Canon center,but depending on the camera the fee is as much as getting a new camera. Sorry about your camera.
If you are refering to the coolant level sensor (causes low coolant light to turn on), it is located on the radiator near the battery on the passnger side. It is on the radiator tank, just below the radiator cap and the upper connection for the transmission line. Heres a picture of the sensor on my 2002 Impala when I removed the radiator (it's the square thing in the center of the picture):
The crankshaft position sensor is located on the transmission bell housing on the right side (if you're facing the engine from the transmission side). The camshaft position sensor is towards the top center of the timing cover on the front of the motor. They both have 3 wire connectors that are virtually identical.
