Question about Danby DWC283BLS Wine Cooler
The fans in my cooler stopped working. how can I fix, or replace them ? I have an DCW283BLS Model
Posted by Ric Meza on
Genrylee
    New Friend:
  • 5 Answers
There are 3 fans in this unit. One high up in the back panel for defrost (which should seldom run), and two inside the box with the LED's that divide the compartment into upper and lower areas. All are interchangeable. Replacement parts are available through Sears Parts Direct.
If you intend to do the repairs yourself, make sure the cooler is unplugged when working on it. To gain access to the two fans in the divider box, remove the wine racks to give you more room, and just remove the four screws holding the top of the divider box on and lift it off. One of the fans is directly behind the PC board and the other is inside the 8x10 foam box to the rear of it. Be careful with this foam box, it is delicate. To gain access to the fan inside, use a thin bladed knife or razor blade to delicately separate the top from the sides.
Before replacing fans, try tracing the leads from the fans to the PC board and swapping the plugs for the fans on the PC board and plugging the cooler back in to see if any of the fans are working. Make sure you restore the plugs to their original positions. If all three fans are not working, the problem may be the PC board or the thermocouples.
Posted on Mar 16, 2014
Semi conductor electric cooler
These people have a similar fan motor.
http://www.appliancepartspros.com/search.aspx?model=dts%20181%20cr%20dr%20ww
some semi conductor fridges use mains operated computer-type case fans.
Aug 06, 2015 | Furniture
MODEL #HAW18ABB
www.haier.com/us/servicesupport/overview
Jun 11, 2014 | Haier HVTS18DABB Wine Cooler
Fans stopped working
go to sears parts direct and enter your DWC283BLS you will have the plan and number parts you need
Mar 15, 2014 | Danby DWC283BLS Wine Cooler
Stopped cooling no humming or nothing digtal reading are working but nothing else
you need to replace the fan at the back of the unit. no noise means the fan is not working. The fan removes the heat from inside the unit to cool it. no fan, no cool. Your local appliance repair can fix it. the fan does not cost much and there isn't much labor involved. If you want to tackle it yourself then take your model number to the appliance store and order a fan, remove the back and replace the fan. Some fans are plug and play, some are not. if yours is not plug and play then you will have to splice wires. either way, the fan is your problem.
Nov 23, 2010 | Oster 12-Bottle Wine Cellar - Black
I have a model 5645 and it has stopped cooling
the outside fan can be replaced with a 92 x 25 mm computer cooling fan. Inside fan is a 60 x 10 mm. Remove the cover on the inside by pulling straight up. Plug it in and check if the metal heat sink on the inside is getting cold. If it does, then the problem is one or both of the fans.
Mar 15, 2010 | Coleman Electric Cooler 40 Beverage Cooler
I broke my cooler :(
You can solder the two open ends of the wires/base together. Generally, it doesn't hurt at all to have the yellow wire not connected. As long as the fan is still running, you will be fine. The yellow wire gives information about the fan RPM. You just won't be alerted if the fan stops working.
Jan 25, 2010 | Foxconn CPU Cooler Fan CPU Fan
Danby DWC283BLS Wine Cooler Logo
484 people viewed this question
Top Danby Furniture Experts
Dennis Boxerman
jdthefixer
jasbo
jasbo
Are you a Danby Furniture Expert? Answer questions, earn points and help others
