Doesn't turn on at all .. Even with new batteries
SOURCE: USB port doesn´t work...
You will have to reinstall the usb drivers again from http://www.samsungpc.com/products/x05/x05_supporteddrivers/x05_supporteddrivers.htm
SOURCE: Canoscan Lide 30 compatibility with Windows 7.
There are no official drivers for CanoScan Lide 30 for Windows XP, so your problem is obvious. I suggest you sending an e-mail at Canon including details about your scanner (date purchased, serial number in text form or scanned) asking them to develop driver set as this model is very trade and at shops since 2006 or 2007.
In case of a problem or clarification, don't hesitate to post.
Thanks and regards
Please kindly rate this solution
Stelios
SOURCE: My GC doesn't complete boot
the application software of your GPS got corrupted I would suggest to bring it to the credited service center they are the only one have the data for your GPS.
In the fuse panel under the hood of the vehicle on the passenger side there is a "main" 80 amp fuse that pretty much is your main power source from the batery. Below is a diagram of the fuse layout. I marked the fuse you need to check (number 30). Be glad it was there or you could have had some major electrical problems. I hope this helps you and good luck.
