Question about JVC GR-DF570 DV Digital Camcorder
Lens cap it is saying remove lens cap, but lens cap is not on.
Posted by ferchaud on
  • mrdrs Dec 01, 2007
    I have a model D53AA with the same problem. The message appears and I cannot record.
  • abhishek_921 May 16, 2009
    All of a sudden it all comes up black and says I still have the lens cap on...it plays back fine but will only record the darkness....
Anonymous
    Problem Solver:
  • 6 Answers
I had the same problem on my GR-D750U and JVC will fix it.  See
http://www.jvcservice.com/service/CustNoticeCamcorder.asp?PgReq=DspDtaDtl&MdlNbr=GR-D750US&Pgm=CCD
If you have a different product, try replacing the GR-D750 in the URL above with your product and see if a valid warrantee page is returned.
Posted on Jul 13, 2008
kstahly
    Novelist:
    Scholar:
  • 53 Answers
Apparently this same problem exists on many different models. I have a JVC grd72u. I called JVC @ 800-252-5722. I selected the "Corrective Action Program" prompt from the automated attendent. I spoke to a customer service rep. They are aware of the problem and are fixing it for free, but only until 12/31/07. I suggest you call ASAP and get your name in the computer. If the problem is something besides the CCD sensor, they will call you with the estimate to repair.
Posted on Dec 28, 2007
2 Related Answers
Anonymous
  • 6 Answers
SOURCE: lens cap
Anonymous
  • 6 Answers
SOURCE: it says lens cap when lens cap is removed
KEEP UR HAND CLOSE TO THE LENSES, FACE DETECTION IS ACTIVATED OR U RA MAKING PICTURES OR VIDEOS IN THE NIGHT. TRY WHERE THERE IS LIGHT
Posted on Aug 09, 2009
Why does it say remove lens cap when trying to record?
Because the camera can not record when the cap is on just like u cant see with ur eyes closed. So remove lens cap.
Dec 13, 2015 | Video Cameras
What does remove obstruction mean
Is mirror in locked up position? In manual mode? Especially if the lens is irised down to a high f-stop.
Aug 24, 2014 | Fuji FinePix Cameras
Remove stuck rear lens cap
The first thing I would try is using one of those rubber pads that are used for removing stubborn lids from jars. If that dose not work, I would use the fact that the Nikon rear lens caps are made out of soft plastic to my advantage. If you have a Dremel rotary tool with a disk cutting tool, you may be able to CAREFULLY and slowly cut away the lens cap. You didn't say which lens this is, but since with most lenses the telephoto position moves the rear element away from the back of the lens, I would set the lens to telephoto before starting to cut. I would start by cutting through the back of the lens cap. Cut a little at a time and try to take off the cap. Proceed slowly periodically trying to remove the cap. Hopefully, the pressure will be relieved and the cap will release before it becomes necessary to cut across the lens flange. When you are done, I would carefully clear the lens of any debris.
Jul 05, 2014 | Nikon Cameras
Lens cap
place the lens cap back and then off the camera. after that turn onn agin and remove safely
Apr 25, 2013 | FUJIFILM FinePix S4000 / S4050 Digital...
Kodak digital camera z990 lens obstructed remove lens cap
It seems that many people think that sending a camera back to the manufacturer is helpful. Most of us want help to fix it ourselves. If it is under warranty most know enough to send it back. If it is out of warranty the repair cost for most problems is more then it cost to replace it.
Feb 15, 2012 | Kodak Cameras
Cannot record, says lens cap needt to be removed
I would sugest removing the lens cap (protective cover over the lens) and see if that does the trick.
Dec 03, 2010 | JVC GR-DA30 Mini DV Camcorder
"Remove lens cap"
Lens damaged or grit/sand in it. If the lens is out at all then whoever was using it will know what happened, as it was going at the time.
If you think it's sand/grit, try tapping it on the bottom, while holding it lens downwards 1 foot above a piece of white paper, see what falls out.
I fixed these units for 4 years and we used to collect sand and tape it to the camera because customers would deny taking them to the beach. LOL.
Sep 24, 2009 | Panasonic Lumix DMC-FZ5 Digital Camera
It says lens cap when lens cap is removed
Aug 09, 2009 | JVC Everio GZ-MG20 Camcorder
Camcorder keeps asking me to remove lens cap
Contact JVC, they fix this error FREE. They fixed my GRD-50. It's a common fault with lots of them. Give it a go. Good luck.
Dec 07, 2008 | JVC GR-D20EK Camcorder
Lens error nikon coolpix 4300
This error occurs if camera is turned on before lens cap is removed. If you are removing the lens cap before turning the camera on and still getting this message, camera should be serviced by a qualified technician.
May 17, 2008 | Nikon Coolpix 4300 Digital Camera
JVC GR-DF570 DV Digital Camcorder Logo
111 people viewed this question
Top JVC Video Cameras Experts
Ekse
Larry Stiles
Larry Stiles
Al Rush
Are you a JVC Video Camera Expert? Answer questions, earn points and help others
