The battery compartment for the display on the Vitamaster 8711 treadmill is typically located on the underside of the display console. You may need to unscrew or unclip the console to access the battery compartment. Once you have access, insert the required batteries according to the polarity markings (usually indicated by a plus and minus sign). Make sure to replace the battery cover securely before reattaching the console. The specific battery type and number required for your treadmill's display should be listed in the user manual or on the console itself.
Hi Yuri,
Hope so you're doing well, the distance unit from miles to kilometers on the Life Fitness Club Series+ treadmill, there are a few steps you can try before contacting Life Fitness support:
Warm reset: Press the CLEAR key twice, and then hold down the ENTER key. The treadmill should perform a "warm" reset and beep three times, indicating that the USER MENU has been activated. After the reset, check if you can access the distance unit setting.
Manual access: Alternatively, you can try holding down the ENTER key while turning on the treadmill. The message "USER MENU" should appear, and after a second, the MESSAGE CENTER will display the first menu item. Navigate through the menu options using the appropriate keys until you find the distance unit setting.
Hope so this will work for you!
Regards,
Bryce June
downloadallthingsnow.com/ebooks/vibelife-7117-treadmill-manual.html Jun 4, 2014 - Vibelife 7117 Treadmill Manual In our tests, we were able to access the PC beyond the unrestricted period. Whats new in this version Version 4 ...
Hold down the PAUSE Key and press CLEAR Key twice. Continue to hold the PAUSE Key until the SERVICE MENU appears. Use the Speed UP/DOWN key to scroll through the menus and the ENTER key to make a selection. Once finished CLEAR button twice will reset the machine for use.
go to the menu, and select the languaje. however read your instruc manual or download from www.fitness.manualsonline.com or www.iconservice.com and proceed according.
To get to the service menu start by pressing the pause button and keep it held down as you hit the clear button twice. The treadmill will reset and go into the service menu, and now you quite pressing the pause button.
