Question about Sony DAV-S300 System
Pre-set sony s300 tuner
I moved into a house with a sony s300 and I need to pre set tuner .Can anyone help please?
Posted by metz1076 on
  • metz1076 Jun 15, 2009
    Thanks but no I do not.It was left behind wtih remote and speakers.
Shahid Electronics
  • 10,594 Answers
Do you have instruction manual of DAV-S300 to get to know about tuner presets?
Posted on Jun 13, 2009
  • Shahid Electronics
    Shahid Electronics Jun 15, 2009
    Copy and paste following Sony Support link in browser bar to download instruction manual of DVA-S300 that has all necessary details about tuner preset.
    http://www.docs.sony.com/release/DAVS300...
How is program?
It's explained in the manual...
http://audio.manualsonline.com/search.html?q=sony+DAV-S300
Tuner Programming Page 17
Disc Play Programming Page 26
Feb 10, 2011 | Sony DAV-S300 System
I have a sony BDP-S300 Blu-Ray Disc Player and it takes forever to load movies and at times shuts down the process and reboots can you please help
Try cleaning the laser lens with a Q-Tip and Rubbing Alcohol. You'll probably have to take the case off and then there's probably a cover over the Disk Player you need to take off to expose the laser lens. Here's a link explaining how to clean a laser lens:
http://www.ehow.com/how_6764537_use-alcohol-laser-lens-cleaner.html
If it still doesn't work then check to see if you can move the laser assembly back and forth on the metal rails. If it seems very difficult to move then you can put white lithium grease on the metal rails and on the plastic gears that move it back and forth.
Feb 06, 2011 | Sony BDP-S300 Blu-Ray Disc Player
When plugged in to amp and eq switch on or off no volume through amp.turn amp full up and very low volume.cd ant tuner fine.just turntablethis is the ps-lx250h
Do you have a phonograph input on your amp? If not you may have to purchase pre amp. What type of cartridge do you have installed on the turntable? Do you have a moving coil or moving magnet cartridge? If you have a moving coil your amp needs to have an input for a moving coil cartridge or you must use a pre amp.
Jul 20, 2010 | Sony PS-LX250H Turntable
Sony BDP-S300 blu-ray player>No Disc
try cleaning the lens first.use a lens cleaner if available
May 18, 2009 | Sony BDP-S300 Blu-Ray Disc Player
How to program pre-sets on a Sony tuner ST-S100L
Tune in the correct station with the big +/- buttons. Then press "memory" then type in a number with the pad (it will do double digits, but normally a single digit is preferable) then press "enter"
Now typing in that number then pressing enter will take you to that station.
Good luck.
Dec 12, 2008 | Sony ST-SA50ES 2 Channels Tuner
Tuning radio without remote.plese help....
You need to have remote control to perform tuning for radio because unit has no control buttons to do so.
You can get remote from Sony Accessories. Please write model number DAV-S300 in search box to get result.
Remote details are as under...
141883811 RM-SS300 REMOTE CONTROL Approx $70
Nov 10, 2008 | Sony DAV-S300 System
Could Anyone Tell Me, How To Unlock Region Free A BDP-S300 Player??
http://www.stegen.com/product_info.php/products_id/1019?osCsid=daccaf0338a597dd1985e0ad70ac277a
Jan 23, 2008 | Sony BDP-S300 Blu-Ray Disc Player
Code to enter on remote
i have new Sony BDP-S350 Blu-ray disc player. i want to connect it to E-net and some other devices, Camcoder, Pc, Laptop. i have got all HD ready cables,
I want to use the Universal Remote from my Sony Bravia LCD 42'' TV and Blu-Ray. can anyone help me?
thanks
omar
Dec 10, 2007 | Sony BDP-S300 Blu-Ray Disc Player
AM tuner steps
You can download the manual from the link below: http://support.sony-europe.com/manuals/manuals.aspx?l=en#m=ICF-C1200 Please update the question & let us know if the information given was useful to you - Good Luck!
Aug 24, 2007 | Sony ICF-C1200 Clock Radio
Sony DAV-S300 System Logo
250 people viewed this question
Top Sony Audio Players & Recorders Experts
ThaMp3Doctor
ThaMp3Doctor
Muntejaya Ginting
Muntejaya Ginting
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
