Question about Polder Hardware & Accessories
Reset clock Unable to reset clock
1 Related Answer
Anonymous
SOURCE: panasonic dmr-eh50 Clock setting greyed out
To resolve this issue follow the steps below:
(1) Remove all discs from the unit.
(2) Set the unit to DVD Mode
(3) From the front panel of the unit, open the middle door to display the up and down channel buttons
(4) Press and hold both the up and down channel buttons until the unit displays "BYE" and then flashes "12:00 A"
(5) Release the up and down channel buttons
(6) This will clear the unit and you will be prompted to reset the TV Guide Settings
(7) Setup your TV Guide according to the on screen display
(8) From your remote select "SETUP"
(9) Scroll down to "Setup", right arrow to the options on the right, and down arrow to "Clock Settings"
(10) Select "Set Clock Manually" if your TV Guide Function is not providing you with the proper time
Good luck!!!
Posted on Nov 24, 2008
My set button wonk work.
you have to hold the reset in for 15 seconds or 30 sec or maybe even watch the light change colors. but if your still having issue with it, then the unit is dead, ive seen caps goes bad in these type of routers..
I’m happy to help further over the phone at https://www.6ya.com/expert/david_92c86cbc79e9b552
May 24, 2015 | Computers & Internet
I need help!!
unplug power for a couple of hours to reset it's memory.
Sep 14, 2008 | Durabrand W375-K Clock Radio
I want to know how to reset my clock in my 2005 Honda inspire car. the dash is all set out in Japanese.
Don't know your car but clock on a lot of cars is controlled by the other button near the odo reset - press and hold till clock flashes, these buttons are normally near speedo and rev counter normally ignition on engine off then sometimes your button turns left or right to adjust. Either that or search for images of your car and it's clock.
Jan 01, 2015 | Honda Cars & Trucks
I replaced the lamp on my NEC LT280, but am unable to reset the lamp so that the projector works again.
Whe the lamp exceeds 2100 hours (up to 3100 hours in ECO mode) of service, the projector cannot turn onand the menu is not displayed. If this happens, press the HELP button on the remote for 10 seconds to reset the lamp clock back to zero. When the lamp clock is reset to zero, the LAMP indicator goes out.
Here is the URL for the User Manual:
http://www.necdisplay.com/documents/UserManuals/LT380_user_manual.pdf
Dec 14, 2014 | NEC LT280 LCD Projector
The reset button on my FZS1000 is not working. Is there a way of fixing this?
Yes, but without being there I'm not sure of the correct procedure. The easiest way is to disassemble the cluster and attempt to clean the contacts or reset the position of the button.
Aug 31, 2014 | 2005 Yamaha FZS 1000 Fazer
Unable to reset digital clock
Best/quickest thing to do is remove the negative battery cable for a couple minutes, it should reset on its own. Then set the time as usual
Oct 30, 2009 | 2007 Toyota Yaris
Setting of clock
You need to examine the timer settings. Perhaps you could turn off the power to the oven for a few minutes - this might reset the timer.
Jun 30, 2008 | Cannon 10476G Dual Fuel (Electric and Gas)...
Computer clock
By changing the clock, you are unable to get files back.
There is a difficult workaround
http://articles.techrepublic.com.com/5100-1035_11-5054599.html
But Im sure, you wont get any emails back.
Good luck.
Mar 31, 2008 | Computers & Internet
How can I reset radio stations?
please try timex; Timex Corporation 555 Christian Rd. Middlebury, CT 06762 CT Tel. 203-346-5000 Fax 203-346-5139 i have been unable to find one online - best thing to try is see if you can find a dealer who is selling it and ask if you can copy a manual - they may oblige. Hope this helps a bit :)
Mar 11, 2007 | Timex T601GT Clock Radio
Hardware & Accessories Logo
22 people viewed this question
Top Polder Hardware & Accessories Experts
Gene Haynes
Terry
Terry
Attique-ur-Rehman
Attique-ur-Rehman
Are you a Polder Hardware and Accessory Expert? Answer questions, earn points and help others
