Question about Reddy Heater-170,000 BTU Kerosene Deluxe
How to determine a model/serial on bad boy mower
Lawnboy model 10415 serial number 5901752 correct spark plug
Joe, Factory Lawn Boy SPARK PLUG 614009, replacement plugs champion CJ14, NGK plug # BMR4A.
Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Lawn Boy 10415 Lawn Boy Gold Series Walk Behind Mower 1995 SN 5900001...
614009 Spark Plug
Which spark plug for Lawnboy engine
https://www.shoplawnboy.com/Comergent/en/US/adirect/Toro?cmd=ToroLBOnlineModelLookup
Aug 04, 2016 | Garden
What year is my mower
The serial number alone is not enough to determine the year unless you also include the maker and the model number. Even then it may not be possible, but without that information there is not enough criteria to figure it out.
For example, if the tractor was made by Sears then you probably could narrow down the year based upon the years of production of that particular model at Sears.
Sometimes the year is embedded in the serial number, but the algorithm for determining that is based upon the maker and the model...there is no universal serial number to model year conversion... And in some cases the serial number has nothing to do with the model year... It literally can be a randomized number that's ensured/verified to be unique... However in that case the company may have a database that they can look it up and tell you.
my recommendation is to call the company that manufactured it and give them the model number and the serial number and they will probably be able to tell you... If they can't, chances are there is no easy way to figure it out.
May 23, 2016 | Garden
S.n. s7ky00254 is it a gt dyno blaze and its worth
No way to tell from serial number, and if it's repainted (no model decals left) then it's worth is determined by equipment, appearance and mechanical condition.
I’m happy to help further over the phone at https://www.6ya.com/expert/donald_f2ed37026a3ac881
Apr 06, 2016 | Huffy BMX 20" Boy's Rock It Bike
How do adjust for Speed stability on Lawn-Boy mower. It hunts up and down.
Speed control for motor is controlled by an automatic governor, so there isn't any adjustments. Surging is caused by an air leak. Has the air filter been changed? Spray card cleaner around that side of the engine to find the air leak. Does it have a choke adjustment? Make and model would be handy in answering this question!
Oct 18, 2014 | Toro Lawn Boy Self Propelled CARB Walk...
Where is the egine model number located on a Lawn
Go to www.lawnboy.com and input the model number of the MOWER and probably any of the serial #'s if you don't have yours. More options and info will pop up and you may get your engine model info from there. I hear that the Duraforce engines are all the same model?
Jul 10, 2010 | Briggs & Stratton Lawn-Boy Insight Series...
Mower surging silver serieslawn boy 6.5 h.p. tecumseh motor model lev 120 spec 362006a. I cleaned out carb bought a rebuild kit replaced o rings in center jet and another under float also little metal...
let it surge, it will usually get better as it warms up. These 6.5 Hp engines are fine except they have an cheap badly designed carburator. Nothing can be done about this problem. They all surge eventually.
Jun 07, 2009 | Tecumseh Lawn Boy Push Mowers Insight...
Reddy Heater-170,000 BTU Kerosene Deluxe Logo
51 people viewed this question
Top Reddy Heating & Cooling Experts
Paul Carew
Marvin
Marvin
Fahr Quad
Are you a Reddy Heating and Cooling Expert? Answer questions, earn points and help others
