My ice make had ice in the line that dispenses the water into the tray. it is not making any ice, could the ice maker have burned itself out beacuse it was trying to get the water but could not?
It either is the water vavle burned out or the ice make went out usualy that is a common problem when the line freezes up to test the ice maker there take the front cover off ice maker then there should be two holes in the front a hole that has m and the on next to it put a jumper wire in that hole if it dont rotate the ice maker is bad. or if it is the other kind of ice maker take a flat head screw driver and turn the screw with on the motor gear clock wise keep turning it until it runs on its own you should get the same results like the above if ice maker test good the water vavle is bad check make sure you have no restrictions in the water line take the line off the vavle and let it run in a bucket to see what kind of water pressure you have it should come out fast
Hello Jim czyryca - From what you are describing if the ice maker is not making ice but is dispensing water, sounds like the refrigerator has a frozen water line, faulty ice maker valve or bad component that sends power to the ice maker valve when needed. The ice maker cycles internally to call for water so I strongly suggest contacting a professional to move forward accurately to assist with the repairs.
