Question about Brother Wireless Color Laser MFC-9340CDW All-In-One MFC9340CDW
DRUM STOPPED BROTHER 9340CDW
DRUM HAS STOPPED WORKING
How do I empty and reset the waste toner box WT-220CL in a Brother Printer MFC-9340CDW
On most color machines emptying the waste toner cartridge isn't an issue because the auger system dumps it into the waste toner. The brother machines before this a different way and have a cleaning blade in them. This blade wears out over time and needs to be replaced. Those waste toners last forever in that machine so your better off just replacing it. Other wise you probably are going to make a huge mess just to have problems once you get it back together.
Jun 25, 2018 | Brother Office Equipment & Supplies
Brother MFC not printing in color
go into printer properties and set the colour as default.
normally when you go to print something there is a tab section that will get you there before you actually press print
May 24, 2015 | Brother Wireless Color Laser MFC-9340CDW...
Default passwords
If you contact the manufacturer, they should be able to provide this needed default password. Best Wishes
Sep 01, 2014 | Brother Wireless Color Laser MFC-9340CDW...
Brother mfc-9340cdw does not print nothing in spool
Sir/Madam
Please Go To Official Hp Printer Website To resolve You Hp Printer Issue Below Link URL:
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c02205477&cc=us&dlc=en&lc=en&product=5199463#N93
Or
If You still having Problem Then Follow Us On for HP Printer Online Assistant On:
HP Printer Support
Feb 10, 2014 | HP PHOTOSMART 7520 E-ALL-IN-ONE
Drum error dr-420
Sir/Madam
he following error messages will continue to appear if the drum counter was not reset when you replace the drum unit with a new one.
  • Replace Drum
  • Drum End Soon
  • Drum Near End
  • Drum Stop
To clear these error messages, you need to reset the drum counter,
Or Visit official Brother Printer website For Brother Printer Troubleshooting Page Url Below:http://welcome.solutions.brother.com/BSC/public/us/us_ot/en/faq/faq/000000/002800/000037/faq002837_000.html?reg=us&prod=mfc7340_us_as&c=us_ot&lang=en
Or
Still Having Problem then follow Us On For
Brother Printer Support
Jan 14, 2014 | Brother Office Equipment & Supplies
How to reset the drum counter on a brother printer HL5270 DN
There should be a way to reset the drum setting. Call Brother they will help you are look in your manual.
May 21, 2009 | Brother HL-5270DN Laser Printer
Paper starts to feed then stops after feeding about 2 inches
Drum is on an internal counter in the printer, so it will work fine on another printer. If the print quality is fine, then you can fool the machine into 'thinking' you replaced it. The instructions are here:
http://welcome.solutions.brother.com/BSC/public/us/ca/en/faq/faq/000000/000100/000054/faq000154_014.html?reg=us&c=ca&lang=en&prod=hl2030_all&Cat=7
please rate solution ;)
Apr 16, 2009 | Brother HL-2030 Laser Printer
Changing Drum
The drum is where the image is applied before being transfer to the paper. If the drum is wearing down the image will become poor. Changing the drum unit will make the image like new. So, yes you can run the drum catridge until you get a poor print out.
Apr 24, 2008 | Brother MFC 4800 All-In-One Laser Printer
Brother Wireless Color Laser MFC-9340CDW All-In-One MFC9340CDW Logo
50 people viewed this question
CheckitRight
CheckitRight
James Cagle
James Cagle
Norman  J Weimar Jr
Norman J Weimar Jr
